Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > 190E (W201)
Thread Tools Search this Thread Rate Thread Display Modes
Old 10-25-2008, 04:36 PM   #1
ed-E300TD's Avatar
Location: Washington DC / No. Virginia; and Cape Cod, MA
Driver's Door Lock Stopped Working
The central locking system on my daughter's '93 190E was working perfectly until recently.
Now, when she tries to lock it from the driver door nothing happens at all. Yet, the passenger door and trunk both still work to lock the entire car.
Any thoughts?
Thanks,
Ed
__________________
'99 E300D (US Spec), 153K mi.
"Not your father's Mercedes-Benz" - not even close!
ed-E300TD is offline   Reply With Quote
Sponsored Links
To remove this ad, register today or login if you already are registered!
Old 10-25-2008, 07:03 PM   #2
probably the lock actuator. both of mine are dead. id check the vacuum hoses first though. pump some air into the line that goes into the pump under the rear passenger sides side and see if it hold the psi, if it doesnt just find the leak
__________________
1996 C36 ///AMG
Tinted, avantgarde, euro headlights & corners, HIDs, smoked LED tails, Rieger window spoiler, AMG pedal kit, AMG stem caps(woo!), interior mods, carbon fibered bay covers, eibachs, Brabus V's, W210 LED mirrors, CF gruppeM intake, many mods to come...
1986 2.3-16 Cosworth 5 speed
Monos, Momo, Euros, smoked crap, !Need seats pref. Sportlines!
also many mods to come...(whoosh)
AMGC is offline   Reply With Quote
Old 11-21-2008, 10:45 PM   #3
190 drivers door lock
I had the same problem with my '93 and I replaced the door lock which solved the problem. By now though you probably have already solved it too!
Pasha95 is offline   Reply With Quote
Old 11-23-2008, 07:21 PM   #4
I have the same problem as well on my '93. My dad fixed it cause the wires broke that connected to the lock. It broke again after 3 years. Not bad for a jury rig job. So just gotta find time to open the door panel and do it again.
Runninrebel211 is offline   Reply With Quote
Old 11-23-2008, 08:35 PM   #5
ed-E300TD's Avatar
My daughter has had the car away at college. She'll be back this week, and I'll try to take a look at it if it's not too cold.
I may be back in touch with you gents when I tackle this project. Are there any diagrams of the door's insides on the net?
Cheers,
Ed
__________________
Old 11-23-2008, 10:00 PM   #6
190E door lock problems
Cheers,
Ed
Once you remove the panel replacing the door lock mechanism is pretty straight forward.
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
