Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > C-Class (W203)
Welcome to MBWorld.org!
Welcome to MBWorld,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-23-2009, 07:20 PM   #1
Drives: 2001 C320
P0410 Secondary air injection malfunction
Hello, I'm wonder if anybody out there has a C320 that is throwing this code. Air pump and relay are both working upon cold starts, then shut off as normal. I replaced the check valve along with the air pump change over valve. A few days after erased, it throws the code again. It does not relate to the Clk,Ck models. Mine is a 2001 C320. Thanks Tim To remove this ad, register today or login if you already are registered!
timmified100 is offline   Reply With Quote
Old 08-11-2009, 07:34 PM   #2
Drives: 2001 c240
i have a 2001 c240. just started getting that error code along with both cats. i replaced the o2 sensors but still getting the cat error. i dont even know what the secondary air injector is or where it is. also looking for help on here
Malsor13 is offline   Reply With Quote
Old 08-11-2009, 08:59 PM   #3
Drives: 2001 C320
What are the exact codes you are throwing? The secondary air injection is basicly a smog pump. It only comes on for 30 seconds or so in the mourning upon cold starts. Mine is located easy access on top of the motor however some are located at the bottom. It's an electric motor located in a black plastic housing. It's job is to oxygenate the cats on cold starts for less polluntion.
Old 08-12-2009, 05:56 PM   #4
Zeppelin's Avatar
Drives: C32
So how do you know the relay is working ok? If your relay has not been replaced then replace it. It is a $20 part that is intermittent when the contacts become pitted.
Zeppelin is offline   Reply With Quote
Tags
2001, air, c32, c320, change, check, cost, error, injection, injector, malfunction, p0410, pump, secondary, valve, w203
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
