Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > C-Class (W203)
Welcome to MBWorld.org!
Welcome to MBWorld,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 07-29-2009, 09:25 PM   #1
Drives: 06 C230 Sport
M272 CAI: Graphic images, viewer beware :P
First off, this is going extreme intake, not K&N insert and i am afraid to touch anything else because its a Mercedes and its expensive!!!! This attempt is made with years of experience in this field. Parts altered are cheap to obtain used and replace in case you need them too. Again this isnt a sissy mod, beginners beware lol!
Well, after 2 hours of measuring, cutting, fabrication, bending and fitting , the so called " nothing better then Mercedes ,ram air, design" intake is born. At the present time, im doing final touches and photos. Give me few minutes here.
FIRST TEST DRIVE: I believe quite noticeable amount of power was gained. Not to mention engine , feels like is soo much smoother.. Beautiful V8 mercedes growl after 3500rpms.
Advantages: - weight reduction- lighter than stock OE intake parts.
- temperature control - not only intake inhales cold air , but because the stock intake was removed , now the air that is being forced through the "ram-air" left over ducts if flowing around engine bay and most importantly INTAKE MANIFOLD , which isnt covered up anymore!
Disadvantages ( so far):
- sound - because the filter is located in the same bay that the fresh air is being sucked into the cabin, you will have sound of your engine sucking in air heard from that area in the passenger compartment. Its sort of like the engine sound tube design, but you hear it LIVE, LOL......
- cutting - some cutting is involved to run the pipe into the neighboring bay. While i was fitting it my way, i took a little detour in my work and tried to see if ram-air could be utilized in another variant of the intake. and the answer is YES, but more brackets must be fabricated to attach it to the valve cover bolts, the other problem is , nobody on the market makes a shielded cone filter ( like K&N makes Apollo ) with a 4" inlet. Our throttle body is 3.5" so it is useless to step down to 3" ( btw Apollo is 2.75" inlet )
- battery - smaller battery required. Which also helps you to knock off another 45lbs
Disregard the blue hose and filter, i didnt have any black hoses lying around, tomorrow, it will be fixed
To remove this ad, register today or login if you already are registered!
__________________
2006 C230 Sport::almost stock::
NegroC230 is offline   Reply With Quote
Old 07-29-2009, 10:18 PM   #2
Drives: 07 c230 sport
where'd you get the materials?
howardyudoing is offline   Reply With Quote
Old 07-29-2009, 10:20 PM   #3
advans's Avatar
Drives: C55 ///AMG, 535xi
Send a message via AIM to advans
lol where in NYC are u from? I need to hear this to see if this is legit.
__________________
from c320 coupe to C55 ///AMG __________________________________________________ _____on mbworld.org
advans is offline   Reply With Quote
Old 07-29-2009, 10:22 PM   #4
Queens...Maspeth area
__________________
Old 07-29-2009, 10:25 PM   #5
well that's one question answered. lol
Old 07-29-2009, 10:27 PM   #6
Material was ordered from internet from various stores. Before any job is performed, you take a look at it what you need, measure it , and then you shop around
__________________
Old 07-29-2009, 10:30 PM   #7
you have a 4" pipe bender? crazy!
Old 07-29-2009, 10:30 PM   #8
omg its nate's Avatar
Drives: 06 C230 6 Speed FTW
Hmm I think I will keep mine stock.
__________________
Search button is for n00bs.
omg its nate is offline   Reply With Quote
Old 07-29-2009, 10:54 PM   #9
Drives: '01 C320
So you now have no cabin air filtration, excess unburned vaporized fuel and any battery gasses entering the cabin, cabin air/climate being sucked into the engine, and a sub standard battery. What are you thinking?
mleskovar is online now   Reply With Quote
Old 07-29-2009, 10:56 PM   #10
yeah, that paper filter really helps im thinking i am faster then you , LOL
__________________
Old 07-29-2009, 10:57 PM   #11
Drives: 2003 C230, 1986 560SEC, 1986 190E, 1981 300SD, 1964 230SL
he's thinking mods. lol! good job on the ram air. but i dont think you'll be getting much cold air for your intake at that spot. also like mleskovar said no more cabin filter.. you'll get dizzy allot when the a/c is on.. cheers! still a good looking DIY!
EDIT: bro just thouht about it. make a strait pipe going to the right headlight! lol! remove the headlight and make a housing there for the pipe! now thats cold and fresh! hehe!
Patrick LowKey is offline   Reply With Quote
Old 07-29-2009, 11:01 PM   #12
Quote:
That paper filter in the first place, isnt even charcoal, so it really doesnt do anything except for filtering dust. Secondly, this battery is SEALED, unlike the OE unit where its actually vented, and YOU , my friend are inhaling it! Thirdly what fuel are you talking about????
__________________
Old 07-29-2009, 11:03 PM   #13
why are you thinking i am not getting cold air at this spot??? if you look closely at the hood, that part of the hood is OPEN via duct on the hood
__________________
Old 07-29-2009, 11:06 PM   #14
yeah at the top.. at the same time theres still not too many air coming from there.. those fins serve as an escape for the heat coming from the engine compartment.. not going into the compartment.. well.. looks good man. by the way no ones attacking you here so take a chill pill.. lol.
Old 07-29-2009, 11:09 PM   #15
OFF -TOPIC here a little...just did a quick research and, i founf out that we have a charcoal filter in the cabin area right next to the heater, which means this air filter in the engine bay is solely for dust ....
i dont feel being attacked, just explaining my idea everybody is in title to debate
__________________
Old 07-29-2009, 11:11 PM   #16
k k.. by the way what size is that battery??? i really wanna switch mine to optima's but people say it cant be done..
Old 07-29-2009, 11:14 PM   #17
everything can be done this is very small and powerful battery ( not reserve time wise, but cranking ) its about 11lbs 8"x3"x9" ? 280cca 300ca very reliable, i had it for 2 years in my E46 M3
__________________
Old 07-29-2009, 11:16 PM   #18
280cca? that tiny??? what the? serious?
Old 07-29-2009, 11:18 PM   #19
i was off by a little
Voltage: 12 Volt Capacity: 19 Ah Type: AGM Warranty: 1 Year Shipping Weight: 11.00 Pounds Length: 6 7/8" Width: 4" Height:
6 1/8"
  • 19 Ah @ 10hr rate
  • 275 CCA
__________________
Old 07-29-2009, 11:21 PM   #20
well if any of you guys read my other thread, which i got flamed for...lol. there is a giant space under the passenger side headlight where you could route that fat 4 inch pipe down into. its filled with cold air. try it. after you drive your car, pop the hood, remove the passenger side intake pipe and stick your hand through the fat opening down under the headlight. hella space for any cone filter.
someone also said that it would get dirty... isn't that the purpose of a filter? even if you look at the underside of the front bumper, it's pretty much covered all the way with panels. so i doubt it'll get any dirtier than our current filters.
Old 07-29-2009, 11:52 PM   #21
Drives: '01 C320
Are you sure you have the charcoal cabin filter in your model? I don't think so. The unburned fuel I'm referring to is what is left over when you back off the gas following WOT and low rpm WOT. Those are worse cases, but it's always there and you don't want to be breathing it. How do you think the throttle body gets all mucked up? As well you are drawing air from a place that is hotter and more restricted than the normal high front facing intakes. Also, that piece that you hacked out is part of the unibody construction and has structural significance. If you do a lot of short hop driving that battery, along with your alternator, will crap out quickly. People on this forum have done extensive testing....read that dyno.....and no intakes or filters have surpassed the stock ones for power. None. One person even tested with NO air filter and the hood open for maximum intake and found no increase. It may look better to you but it's neither safe nor more efficient.
Old 07-30-2009, 12:16 AM   #22
splinter's Avatar
Drives: GMC
V8 growl from your M272?
Nonetheless, kudos for tinkering. One never knows for certain until he’s proven it himself.
photo credit AirFrcd
Not sure if that battery will crank it up after a hiatus during a Queens' winter.
Put a real one in the boot to help improve weight distribution.
splinter is offline   Reply With Quote
Old 07-30-2009, 02:59 AM   #23
TruTaing's Avatar
Drives: w203 m112
Is that a Heat Sink ontop of the m272?
To the OP: Only one way to prove your mod's worth. Dyno. (with the hood down) Post smore info about the battery too
Mig has done it. Its possible, I think he used a red top.
__________________
TruTaing is offline   Reply With Quote
Old 07-30-2009, 04:54 AM   #24
Karo's Avatar
Drives: 2006 C350 Sport
I don't get it. I have heard of intakes and know about them but, isn't our original design better? How can it get any colder? Sucks air from the grill as opposed to sucking air by the battery box?
The only plus I see is that it is shorter. Other than that I feel our stock intake is fine and may even perform better.
One thing I learned is on the w203 intake and exhaust hardly do anything. What is the max power you gained 2hp? If you even gained anything.
Can anyone chime in? You guys really believe there will be any gains? I'm not trying to argue or anything I just want an honest answer.
Good job, you should get points for doing it, but if you gain more power than
__________________
Karo is online now   Reply With Quote
Old 07-30-2009, 05:00 AM   #25
FrankW's Avatar
Drives: DirtyToo & Thrifty
heat sink indeed. it's the ECU sitting on top of the engine.
mig took his out after his aftermarket head unit drain it.. I still have mine. it's uptima red top.
FrankW is offline   Reply With Quote
Tags
84, air, battery, c230, c320, cold, compartment, engine, filter, graphical, images, inlet, m272, mercedes, mods, pipe, sports, w203
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
