NO SOUND FROM RADIO
NO SOUND FROM RADIO
Took the dog to the "Bark Park" this evening. Was listening to the radio, everything normal. Shut the car off, let the dog run around, got back into the car, started it, no sound from the radio. Pressed the Mute button a couple of times, nothing. Everything else is normal -- finds stations if I press "Seek", etc. I have the standard radio, no Command.
As this forum seems to have the world's leading authorities on everything Mercedes, hope someone can help by pointing me in a direction of what might be wrong.
Thanks!
Thanks!
2002 Mercedes Benz C230 Coupe
This happened to me once on my 02 coupe. I turned up the volume using the know on the unit (as opposed to the steering controls) and it started to work again. Worth a try
JCNash, thanks for the suggestions; however, tried it and nada. Is there a separate fuse for the speakers vs. the radio itself?
Super Moderator
ok just wanted to make sure you didint have the hk with the plain hu. well i don't know what could be wrong but you are lucky you don't have the hk becasue the amp is really expensive. hope someone can help you
So, Im realy not sure what could be wrong. Good luck.
There are some other links on this issue. I've had this happen a few times now with my HK system in my '06 C280. First time, they replaced the amplifier (luckily, it was still under warranty). It was fine for 6 months, then just happened again last week, but started working the next day. I will have them look into it next time I take it in.
It's not the fuse (I replaced those the first time, made no difference). There's some other issue, but no one seems to have an answer for this (and on this fantastic forum, that is VERY strange!!).
This kind of thing should not be happening with any car, much less an MB. Car stereos have been around for a very long time--it ain't rocket surgery.
'05 C320
I have the HK system. The very same symptom happens about once a year. I wait a day or two and the sound comes back on its own. I have taken the car to a dealer while under warranty but they couldn't tell what was wrong because sound was always back by the time the car was in.
For those of you with Harman/Kardon Logic7 systems - if you're having on again/off again issues you most likely have a bad amp. This has been fairly common. The amp is expensive ($1000).
Chuck, you have the Audio 20 standard 6-speaker system? I've not heard of that failing before. Whatever it is will hopefully be a reasonable repair price wise. Dealer retail on a speaker is about $85 last I checked.. for reference.
1 Post
2005 c230 S.S.
theres a couple of "fixes" in this thread for the hk system. i'd give them a shot first https://mbworld.org/forums/c-class-w...-system-2.html
2012 C300 4Matic
None of the fixes for the HK system are going to work for you. The standard audio system is quite basic as far as the amp / speakers are concerned. If none of the modes on the head unit (radio, cd, etc) are producing audio on any of the speakers then your head unit is likely toast. Sounds like a good excuse to buy a COMAND unit to me. If you can get your hands on a Star Diagnostic computer the head unit can be tested that way.
Thanks everyone for your time in replying. I thought of something else that MAY have contributed to this: About a week or so ago, I pressed the TONE button and it came up with Bass, Treble, then a choice for "Standard" "Speech" and "Surround Sound." I set it to Surround Sound. It continued to work until it just stopped as mentioned in the first post. Now when I press the TONE button, I only get the Bass and Treble options and it doesn't progress to the Standard, Speech or Surround Sound modes.
Everything else about the radio works fine, press the MUTE button, and the word "Muted" appears, the seek function works, the preset radio stations work, which makes me think that the head unit isn't completely toast. I'm going to take it to the dealer and see if they can hook up the Star system.
Is it possible there is a connection in the back of the radio where the speaker wire plugs in? The reason I ask is because the dealer did have the dash apart a couple months ago fixing an A/C outlet servo that wasn't opening. I'm sure they had to have the radio out to get to that fix.
Will keep you all up to date.
2012 C300 4Matic
Thanks everyone for your time in replying. I thought of something else that MAY have contributed to this: About a week or so ago, I pressed the TONE button and it came up with Bass, Treble, then a choice for "Standard" "Speech" and "Surround Sound." I set it to Surround Sound. It continued to work until it just stopped as mentioned in the first post. Now then I press the TONE button, I only get the Bass and Treble options and it doesn't progress to the Standard, Speech or Surround Sound modes.
Is it possible there is a connection in the back of the radio where the speaker wire plugs in? The reason I ask is because the dealer did have the dash about a couple months ago fixing an A/C outlet servo that doesn't opening. I'm sure they had to have the radio out to get to that fix.
Super Moderator
Samaritry, I'll be darned, but it does have a HK system, but it has the standard head just like you have in your pictures. I guess this changes everything. Is there a separate fuse for the amp on this system? If so, where do I look for it?
Super Moderator
no clue on fuse consult your fuse guide if you don't know where it is i will go take a pic for you because i am in a helpful mood. ok didn't you say something about the cd changer not responding or something because the fiber cable could have come undone. also you said that the surround thing is gone which leads me to believe your hu cannot talk to your amp and cd changer through the fiber cable. or because a fuse blew. or because the dealer put the hu back in a crushed the fiber cable. or sadly enough the amp blew up. i will go take the pic for you right now.
Super Moderator
even better just saw this https://mbworld.org/forums/c-class-w...e-box-map.html. should be the same for your car because the person that posted it BabyBenz6spd has a 05 c230 so i assume he took the pic himself. looks like 26 is what you need to check. also to find the map/fusebox you need open the drivers door and their is a door to the left of the dash. here is a pick it is a rh drive but looks the same on the correct side of a proper rhd drive car. btw it is the guys face i got carried away with paint the best program ever!!
The conclusion of this post reminds me of that old saying KISS -- Keep It Simple Stupid. In this case, I'm the "stupid." I went to the owner's manual, found the location of the fuses. One for the radio is on the left side of the dash where it meets the door. The second is under the hood on the driver side near the firewall. Anyhow, located both fuses, they looked fine, reinstall them, and (drum roll please), the radio works fine. Can only figure that one of the two fuses was loose.
Thanks again to everyone for their help on this. I did learn one thing, I do have the HK sound system.
Efren Orozco (05-06-2020)
Super Moderator
i am glad everything turned out good for you hopefully you don't have an amp failing which would make more sense then a loose fuse but lets hope i am wrong. now go enjoy your hk system
1 Post
2005 c230 S.S.
swapping the fuses worked for me too. i think its worth giving it a try before you automatically assume its the amp. glad to hear everything worked out, now cross your fingers it doesnt happen again
This kind of repeated failure of the HK system makes me glad my car doesn't have one. I can't understand Benz dropping their contract with Bose. I never read of a failing Bose system on here.
2012 C300 4Matic
To the original poster - I doubt the problem is a loose fuse. You probably have a lose or kinked fiber causing the MOST loop to shut down. Pulling the fuse reset the radio until the next time the fiber loop craps out. Hopefully it was just a fluke.
Problem with Bose is that most of their speakers (with the exception of the wave radio) sound like crap. This is especially true of their car audio. Our 02 E class has bose and everyone agrees that the stock audio on the 05 C sounds far superior (the bose has no highs and no lows as they saying goes).
I've never owned a Benz car with Bose. But I've owned Acura and Infiniti and I was always very impressed.
