Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > C32 AMG, C55 AMG (W203)
C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG.
Welcome to MBWorld.org!
Welcome to MBWorld,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 05-15-2007, 01:06 AM   #1
Eurowow's Avatar
Drives: Amg C32
C E L po715
Need some help guys, i just got back from the shop. My cel went on and i was stuck in traffic, i went to my friends shop and use a OBDII computer the reader gave me a code po715 Input turbine speed sensor ? has anyone encounter this problem before ? and i had my friend reset the code, and on the way to the shop the CEL turn off on it's own My question is does mean i can leave it alone? or i should replace it ASAP ? To remove this ad, register today or login if you already are registered!
__________________
present
Eurowow is offline   Reply With Quote
Old 05-15-2007, 01:35 AM   #2
MBWorld Fanatic & SPONSOR
Drives: ...
all i know is that it has to do with your transmission...not really sure what it means exactly though
http://www.bba-reman.com/content.asp..._transmission1
is your speedometer malfunctioning at all?
1FASTC32 is offline   Reply With Quote
Old 05-15-2007, 01:47 AM   #3
Eurowow's Avatar
Drives: Amg C32
My speedometer works perfectly fine and the CEL turn off on the way to the shop and after reading the code its a p0715 Input/Turbine Speed Sensor Circuit Malfunction. But the thing is my cluster shows NO Malfunction whatsoever . should i seek to this problem right the way? or This could be a computer error ? Thanks 1fastC32 for your quick response thanks a lot !
__________________
present
Old 05-15-2007, 01:51 AM   #4
Drives: ...
Quote:
couple of thoughts:
1. check your radiator fluid level...if it is low, you might have a bad radiator that is leaking coolant into the transmission and starting to cause problems.
2. if you are not losing coolant and the light stays off, then i would leave it alone...if it comes back on, then i would definitely have it checked out...
Old 05-16-2007, 01:52 AM   #5
Eurowow's Avatar
Drives: Amg C32
yeah
couple of thoughts:
so far the radiator level is normal, does not seem like its leaking. And the CEL is gone. I will go back to the shop tomorrow have a look at it close up. Hope everything is going 2 be ok. Again thanks for the INfo 1fast.
__________________
present
Old 05-16-2007, 01:58 AM   #6
Drives: ...
no problem...let me know what they find out...
Tags
amg, c32, circuit, code, coolant, error, inputturbine, losing, malfunction, malfunction01, mercedes, p0715, po715, po715inputturbine, sensor, speed, transmission
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
