| Home | Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Vendor Directory |
| C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG. |
| Welcome to MBWorld.org! |
Welcome to MBWorld, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today! |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | |||
So, I'll be needing front brakes soon...
__________________
Lenneth's Mods: Performance: Resonator delete, Green Air Filters, ECU Flash through VRP, Code 3 Pulley Aesthetic: Promax 8000K HID Kit conversion |
#2 |
i use akebono pads with excellent results. great price and no dust! no squealing either
for pads i chose to turn the oem rotors as they had a lot of life left. cost was 8$ per rotor at oreilly's auto parts. this can be done by you for less than 350$ inc. a complete brakes flush and stainless steel lines. the pads were 149$ shipped 32$ for the rotors to be turned 40$ for the fluid and 80$ for the lines. i also went ahead and painted the calipers while i had everything apart. g2 caliper paint 37$ shipped |
#3 |
Drives: 06 C55
IIRC Green stuff were environmentally friendly pads I think the red ones are better. Also check to make sure your green filters are not falling apart
__________________
Resonator + Rear Cats Deleted |
#4 |
Drives: 2002 C32
I read somewhere on here that people have had problems with the green stuff pads on our cars. Apparently, they made a second version of the green stuff and that too had problems. Everyone that i have talked to has loved their Red stuff pads though.
__________________
Once you go 040; you never go back! C3P SC Pulley, Full SL55 Intake w/ BMC's, C3P HE, CM30 icp, Magnecors, NGK IX's, RacingBrake Rotors, Akebono Pads Waiting to be installed:PTE Thermo |
#5 |
Drives: 03 C32 AMG
I also have the Akebono brake pads, I bought them from Tirerack.com. They are awesome! Like 320 mentioned no dust, no squealing and good stopping power.
__________________
Black '03 C32 AMG Mods: Stage 1+ 185mm Eurocharged Pulleys | Eurocharged ECU Tune | K&N Filters | Phenolic Spacers | LET Heat Exchanger | Johnson CM30 IC Pump | Bi-Xenons |19X8.5 & 19X9.5 DCR Hockenheim Forged wheels | Resonator Delete | Smoke side markers | CL Grille | Flat badge | C55 rear spoiler | Akebono ceramic brake pads Coming Soon: SL55 Airbox Setup | Wires and Plugs | Headers For Sale: Set of Goodyear F1 All Season tires 18" Staggered set 90%-95% tread left! |
#6 |
Drives: without using his blinker
No you don't necessarily have to replace the rotors. Measure for minimum thickness.
EBC green and red are garbage. I wouldn't put those on a lawnmower. Stock, made by Jurid will give you excellent street performance but they dust quite a bit. Akebono Ceramics perform well as a street pad (slightly less bite than stock) and is nearly a no-dust pad.
__________________
2006 C350 Sport Sedan | Iridium Silver Metallic • Black interior • 7G-Tronic • Sunroof package • Lighting Package • 6-Disk Changer • Heated Seats • Split Folding Rear Seats Mods | MP-Design CF interior • HID high beams • HID fog lights • Full LED Tail light conversion • Euroteck CF lip • MB iPod integration kit • Staggered 19” Bremmas • CCFL License plate lights • 2007 Chrome SmartKey • MB Side Fixed Sun Blinds
#7 |
Drives: 2002 s430
Agreed on EBC. I had EBC Red Ceramic on my Porsche 911 and they had no cold pad bite at all. On the track with some heat in them they were fine but for a street pad, they were dangerous.
I used Hawk HP+ and they worked well on both track and street. None of the issues with the EBC. |
#8 | |
Drives: 2004 S600
Quote:
Being a SCCA road racer for over two decades, I can say without ANY question EBC red stuff are a GREAT pad. They NEVER faded on the track on my C32, after the stockers quit SEVERAL times. No noise, no dust, what more could you want. E1000 after MANY meetings, I have to ask just what is your background? You have ALWAYS voiced MANY heavy opinions that I have NEVER seen you back up ![]() PS: Even tire rack does NOT recomend Akebono Ceramics for heavy use, just FYI |
#9 | |
Drives: 2004 S600
Quote:
![]() I have NEVER heard or seen ANYONE question Reds on the street before. Just curious as the yellows are a track pad, which could give a novice driver a bad impression. AKA as poor cold pad bite |
#10 |
Drives: C32
#11 |
Drives: 2002 s430
I think it was the red stuff ceramics on my 996
#12 |
Currently using EBC Yellow. At first, **** load of dust and made painful sound at low speed braking..
However, it feels a lot responsive than stock (when its fully warmed up).. even at high speed.. It produces less dust / sound after break in period. Cheaper than others as well...
__________________
05 AMG C55 Green Filters Flat Hood emb
#13 |
Drives: 05 C55
#14 |
Drives: 2005 C55
I thought you cannot turn rotors on a Mercedes, only replace.
#15 | |
Quote:
Is anything that I said in my previous post not true? Even others on this forum agree with me that certain aspects of EBC pads don't live up to thier marketing claims. As you can see, my original post is unedited, and I never suggested that the stock Jurid pads should be used on a track. I specifically stated that as a street pad, the Jurids perform better. I also said that Akebono's were a good street pad as well, never mentioned anything about track use. How about a little bit of history. EBC has actually completely re-forumlated the Redstuff pads once. I believe they used to be kevlar. Back then they made the same claims they do now. Great initial bite, semi-track formula, blah blah. The dirty little secret was that they were very hard on rotors and left all kinds of pad material on the rotor as well. EBC didn't fess up to this until they decided to re-formulate the pad as a ceramic pad. I've tried them and personally, I think they are STILL hard on rotors, not nearly as bad as before though. Again, this is all considering that we are talking about a street application. I will admit I've never tried them on a track. As far as my background, I'm a guy that drives a car who tried Redstuff pads and didn't like them. That's all you need to know.
__________________
#16 |
Ok so I have to admit this is bothering me a bit. Please give me some examples and I'd be more than happy to back up my claims. Better yet, give me ONE example where I've given a "heavy opinion", was questioned on it, and was later proven to be wrong.
__________________
#17 | |
Drives: 2002 C32 AMG Kompressor - Silver
Quote:
__________________
![]() 2002 Silver C32 AMG Kompressor Sedan [91,000 Miles] Clear Side Markers - CL Style Grille - Flat Hood Emblem Silencers Removed - NGK Iridium IX - Magnecor KV85 185MM LET - LET Stage 2 ECU - NeedsWings PSK Custom Y-Splitter Intake - Boost & A/F Ratio Guages |
#18 |
Drives: 2006 C55 AMG White/Ash
You can get German made Zimmermann drilled rotors for $100 each. That's what I plan on when mine need replacement. EBC wouldn't be my choice for pads or rotors.
#19 |
By the way, I went with Duralast Gold for the front pad change on my C32. They produce a lot less dust, and seem to be very high quality so far. Not to mention the local purchase at Autozone made things a little easier. Previously I had used the Duralast C Max Gold on my 2004 350z, and they too have been working great. I would have to say equal if not slightly better stopping power than OE. I do get a a loud brake noise at around 5% pressure, but other than that no problems. That's with the regular gold on the C32. The ceramic Max on the 350z have never made any sound.
__________________
#20 |
Drives: 02 C32, G60 Corrado
I used Porterfield RS4s and they were absolutely great. However unfortunately I just received the EBC redstuff that I ordered a week ago. Just wanted to try something different. I guess I should have done more research on them. I guess I will try them and see. I also received Zimmerman front rotors. I got them from www.autopartswarehouse.com, they seem to have pretty good prices and free shipping, which was very fast.
#21 |
Drives: 02 CLK 55 AMG,95 C36 AMG
You can't go wrong with Hawks! I love my Hawk Perf Ceramics! Much less dust then OEM and cheaper too.
__________________
2.1 60ft 13.1@108.6 |
#22 |
Drives: 02 c32
i have akebono ceramics on my car and i love them. As for rotors, others have told me the same thing, not to turn mercedes rotors and just replace them. I decided to error on the side of caution and not turn them.
__________________
2004 ex civic coupe = sold 1994 Integra gsr jdm front = sold 2002 Mercedes c32 amg = the new project My carputer http://forums.mbworld.org/forums/sho...d.php?t=237456 My tsx retrofit project http://forums.mbworld.org/forums/sho...d.php?t=242212 TemjinX2's rides http://forums.mbworld.org/forums/sho...=1#post3053382 TemjinX2's $20 seat control module fix http://forums.mbworld.org/forums/sho...55#post3068555 |
#23 |
Some shops will not be able to turn slotted or cross drilled rotors, because this type of rotor causes vibration during the grinding process. However, it is possible to turn the rotors...
__________________
#24 |
Drives: 2002 C32 ///AMG
I just put the akebono ceramics on my car from tire rack about a month ago. Like everyone said they're great for no dust and no squeaking, and also stop just as good as OEM. Although, I did encounter a little Brake fade when things got hot and you hammer on them a few times from a little bit higher speeds. Not to say this wouldnt happen with OEM or any other pads as well, but I expected a little better.
__________________
![]() -Jeff- Car: 2002 C32 ///AMG: Brilliant Silver || Lighting Package || Navigation || Cold Weather Package || Mods: Matte Black TSW Bremma 19x9.5R 19x8.5F || Netherlands Mod || OEM Flat hood emblem || 15% Tint || Painted Sidemarkers || Black Grill || Black Hood Vent || Black Badges || Resonator Delete || KW Variant 2 Coilovers || VRP Tune || Sport Pedals || Johnson CM30 pump || MORE TO COME || |
#25 |
Drives: 2002 C32
I've heard a lot of really good things about Hawk pads. Unfortunately they don't make a front pad for the C32.
__________________
| Tags |
| amg, brake, c32, front |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
