Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > C63 AMG (W204)
C63 AMG (W204) Discuss the C63 AMG
Forum Sponsored by: Kleemann USA
Welcome to MBWorld.org!
Welcome to MBWorld,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 09-19-2009, 09:20 PM   #1
Drives: c63
Goes to the red line and doesn't shift
When I put the car either on s or c mode and presss the gas full when it's on 1st it sometimes over revs once then shifts really hard to second, it ussually happens when the ground is not very even, anyone have the same problem? To remove this ad, register today or login if you already are registered!
akreidie1 is offline   Reply With Quote
Old 09-19-2009, 09:29 PM   #2
Drives: BMW E34 M5, 09 C63 Palladium with Black leather interior
When "c" mode you cannot start off in 1st. It only starts off in 2nd. In "s" mode it will start off in 1st.
Fangster is offline   Reply With Quote
Old 09-19-2009, 10:32 PM   #3
Drives: C63
I think you might want to have that checked. when i floor mine in s mode it always shifts right at redline and its pretty smooth going into second and beyond, but I would never floor it on uneven pavement.
dmyrick is offline   Reply With Quote
Old 09-19-2009, 10:45 PM   #4
gsrjc's Avatar
Drives: 2010 ML350, 2008 C63 AMG
yeah, you should get that checked out
__________________
2010 ML350
2008 C63 AMG
gsrjc is offline   Reply With Quote
Old 09-19-2009, 10:46 PM   #5
Drives: c63
Say the road is flat and suddenly there's a little hill at aroun10 degrees and I floor it would stall a little on 1st before it goes to 2nd
Old 09-19-2009, 11:42 PM   #6
Drives: 2007 SRT8 Charger, 09' C63
Quote:
Is ur esp on?? Thats probabyly why, its trying to grip but can't at that moment, after a second eventually it'll grip thats why ur getting that stall(lag). imo
REDSRT is offline   Reply With Quote
Old 09-19-2009, 11:52 PM   #7
Drives: c63
Quote:
Originally Posted by REDSRT View Post
[/b]
But the triangle sign Doesnt come on,
Old 09-20-2009, 05:41 AM   #8
Drives: C63 AMG, Escalade EXT.
I have hit the rev limiter a few times in sport mode in first. Probably 3-4 times in 19000km.
Merc63 is offline   Reply With Quote
Old 09-20-2009, 02:33 PM   #9
Drives: c63
Quote:
I'm about the same in miles, 13,500 miles, Its weird
Old 09-20-2009, 03:10 PM   #10
Timeless's Avatar
Drives: 2005 E55 ///AMG
Quote:
If he is going WOT, then it will go back to 1st even in C mode...at least it is supposed to.
__________________
[x] K&N Filters
[x] Resonator Delete
[x] ECU Tune (PowerChips) www.powerchipgroup.com
[x] PTE 160* Thermostat
[x] StealthAuto Clear Side Markers and Stealth 8000K Headlamp Bulbs
[x] [STAR] Lowered, Keyless Go Chime Removed, and 10* Mod
[x] DPE 19" SL-5 Rims
[x] Upgraded DTM Style Steering Wheel
Timeless is offline   Reply With Quote
Old 09-20-2009, 04:21 PM   #11
soldier2304's Avatar
Drives: c63 AMG, 2010 S550 Majestic Black, 2006 c230
This has happened to me too on S mode and always on 1st
__________________
C63 AMG Black/Black
-Valentine V1
-Kleemann K1 Tune
-Resonator delete/straight pipes
-6000k D1S bulbs
-Ctgilles 5000k LEDs
-Phillips Crystal Foglights
-H&R Springs
-Evosport Side Lenses
-K&N Filters
-JL Audio 10W7
-All black Taillights
-Euroteck CF Diffuser
-Euroteck CF Front Lip
-RevoZport CF Front Vents (For Sale PM ME)
-Roof Spoiler
This week 6000k HID Fog Kit
06 C230 White/white
A lot of mods...
soldier2304 is offline   Reply With Quote
Old 09-20-2009, 04:25 PM   #12
Drives: C63
maybe it hasn't happened to me because when i floor it i kind of roll into the throttle a little, so i don't do burnout's
Old 09-20-2009, 04:27 PM   #13
Drives: C63, A4
This happend to me the other day as well. Getting onto the highway I got into the throttle pretty good in S mode, ESP ON, as it reached redline it felt like it over reved, throttle cut off kicked in, lag, then boom hard shift into 2nd. Did not feel normal at all, but I think REDSRT is right, I think the ESP was kicking in and just throwing the timing off. In reality what probably happend was I lost traction, ESP kicked in causing the lag (which happend to be right at the top of the RPMs), then a hard shift into 2nd.
__________________
C63 V1 3.864, 19" Multi Spokes, 35% F1 Tint, KW V3 Coilovers, Front Strut Brace, Carbon Fiber Airbox, MHP V3 ECU/TCU, Long Tube Headers, Mids and High Flow Cats
nrgy is offline   Reply With Quote
Old 09-20-2009, 11:08 PM   #14
Drives: C63
Me as well. Seems like when there is some unpredictable change in the road like a hill or a dip, the engiene hits the limiter before the transmission expects it.
This was discussed once before.
cyberorth is offline   Reply With Quote
Old 09-21-2009, 02:40 AM   #15
Drives: SLK280, C63
Happened to me a few times on 1st gear at WOT.
dumpsta is offline   Reply With Quote
Old 09-21-2009, 03:55 AM   #16
Karo's Avatar
Drives: 2006 C350 SS
This has happened to me once. Something happens at that split second where you over rev and the rev limiter kicks in and bounce back then it shift. This is why you feel the hard shift. Because for a split second your car stalls (rev limiter) then kicks back up then it shifts to second.
Sort of like when you are going to redline let go of the gas (so it doesn't shift) and hop on the pedal (no more than 1 second) and you will get a jerk.
That's what it seems like it is happening.
I would say maybe you need a flash but this happened to me after a new flash I had. But like you said it was when I was going up hill.
I know our cars have a position sensor (it recognizes when we go downhill or uphill) so I am guessing it has to do with that.
Nothing really you can do unless you can constantly replicate it.
By the way on mine it wasn't the ESP. The ESP has never kicked in when that happened. I don't know about you guys I mean 450 VS 268 is a huge difference
__________________
Karo is offline   Reply With Quote
Old 09-21-2009, 04:00 AM   #17
Karo's Avatar
Quote:
+1
C or S doesn't matter. It starts off in second but if it feels the throttle is being pressed hard it will automatically kick in to 1st.
Put it in C and do full throttle it will start off in 1st.
__________________
Old 09-21-2009, 04:40 AM   #18
Drives: C63
If you are in "C", you can down click with the left paddle to first before you take off. It's a neat feature for the "C" lovers.
Tags
2006, 2009, amg, c230, c63, car, ecu, flash, issues, lag, ml350, redline, rev, shift, throttle
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
