Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > CL55 AMG, CL65 AMG, CL63 AMG (W215, W216)
CL55 AMG, CL65 AMG, CL63 AMG (W215, W216) Discuss the CL55, CL65, and the CL63 AMG.
Welcome to MBWorld.org!
Welcome to MBWorld,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 07-31-2009, 10:39 PM   #26
clevelandautowo's Avatar
Drives: cl500
quick question,do you know what size pipe they used?is it 2.5 or 3 inches?i m gonna do it tomorrow and not sure what size pipes i need to get from my parts store?! To remove this ad, register today or login if you already are registered!
clevelandautowo is offline   Reply With Quote
Old 07-31-2009, 11:25 PM   #27
Exotic-metal55's Avatar
Drives: 2003 CL55
I would be carefull on how they do this work .. The res. delete pictures shows the new pipes to be a smaller size pipe. They slipped these pipes inside your AMG pipes and created more restriction on your exhaust gases. They may sound louder/better to some but could be costing you power. More back pressure , also equals more heat.
Just make sure the shop uses a 2.75" or even 3" pipe and have them fit each end of the new pipe over the stock AMG pipes.
Enjoy!
__________________
CL55, 1/4 mile time 11.61@120.26mph,1.75 sixty(12/5/08). ASP 180mm pulley, LET tune, 82mm TB, CF airbox, Aux.Garrett H/E, Meziere 20 gpm I/C pump, filters, Nitto Invos 275/40/18 rear (street tires), Wiseco Forged pistons/Nikasil coated bore. New ET`s coming soon!
Exotic-metal55 is offline   Reply With Quote
Old 08-02-2009, 05:35 AM   #28
Drives: 2003 s55 ///AMG
Send a message via AIM to Viet_Amg408
hahah t3flondon you didn't see anything wrong with the pipe when you taking the pics.
obviously the pipe is alot smaller than the stock piping..
correct size is 3"...
__________________
Viet_Amg408 is offline   Reply With Quote
Old 11-02-2009, 01:58 PM   #29
MrStyle25's Avatar
Drives: CL55 AMG
Oh how tempted I am to have this done. I have a nice purrr on my H2, and would like the same thing from an AMG product. Some friends and I were going somewhere and they left a little before me, so as I was playing catch up I apaprently blew right past their truck at about 130 when they were doing 80, they both said the sound of the car while at that speed was the sweetest sound they've ever heard from a car. just a loud VRooooommmshhhh!!!!
my question is, will I loose any of the refinement from removing the resonators? I ultimately want a deep rumble and sound, but I don't want to sound like a 20 year old kid in his old camaro.
__________________
Zoom Zoom!!
MrStyle25 is offline   Reply With Quote
Old 11-02-2009, 02:50 PM   #30
Drives: 2003 CL55 AMG 2006 C230
Here are the links to the sound of my car, I did not care if the pipe was a little smaller because I figured the since I removed the resonators I wanted to retain some back pressure, so the smaller pike does that, but also either way 1/4 inch will not make a difference in speed or performance at all.
http://www.youtube.com/watch?v=9_7En-UWeqc
http://www.youtube.com/watch?v=JzSS4-emJiQ
t3flondon is offline   Reply With Quote
Old 11-02-2009, 08:14 PM   #31
so what's the point of removing it?
__________________
Old 11-03-2009, 04:36 AM   #32
Quote:
All about the sound, I have made tons of other mods for performance and just wanted a deeper sound I own a Lambo as well and going from a super loud car to the 55 was too much hehe.
"We are the music makers, and we are the makers of the Dreams!"
Old 11-03-2009, 07:16 AM   #33
AMG055's Avatar
Drives: CL 55 AMG Kompressor
Question for those with knowledge of exhaust systems.
In the second pic that shows the resonators in place there is a bracket that will keep the exhaust pipes in place should they happen to fall. On the right hand side above the bracket the exhaust pipe looks like its been crimped/squashed with a pair of pliers whereas the left hand side exhaust pipe appears to keep its diameter.
I'm no expert but I would have thought that the right hand side that looks like its been crimped/squashed would benefit if it was replaced with a piece of pipe maintaining the pipe diameter. The only reason I can think of of why the pipe would be crimped would be because there is not enough room for both pipes to maintain their diameter over the bracket so one pipe had to be reduced in diameter for clearance over the bracket as the pipe maintains its diameter up to the bracket and after the bracket.
If this section of pipe can be replaced so as the pipe maintains its diameter is it worthwhile doing this?
AMG055 is offline   Reply With Quote
Old 11-03-2009, 01:56 PM   #34
alx
Quote:
Originally Posted by Verooom View Post
Would removing the resonator void the factory or extended warranty?
no. most likely not.
however, if you ever fail smog test and they look under the car you might get flagged as "aftermarket exhaust" and they will not pass you until you return back to stock- regardless of fact that resonators have nothing to do with emissions.
also, regarding gains- i think there might be a tiny hp gain as resonators swirl exhaust gases and thus reduce speed... however, i have no data to back that up.
alex
alx is offline   Reply With Quote
Old 11-04-2009, 03:01 PM   #35
Drives: SL63 S600 C220
Sure I can hear a difference and it's better, but without resonators do you get more resonances inside the car.
sound 8 is offline   Reply With Quote
Tags
200, 55, amg, cl, cl55, removal, resonator, resonators
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
