Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > CL55 AMG, CL65 AMG, CL63 AMG (W215, W216)
CL55 AMG, CL65 AMG, CL63 AMG (W215, W216) Discuss the CL55, CL65, and the CL63 AMG.
Welcome to MBWorld.org!
Welcome to MBWorld,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 07-19-2009, 09:32 AM   #1
Drives: CL 65/LX470
CL65 When do I add oil?
The other day I recieved the add 1 quart oil message twice. The alert did not stay on for more than a few minutes. I tried to get an oil level reading after I switched off the engine but I kept getting other messages besides a reading of the level.
1. W/O digging through the manual, is there an easy method to get the oil level sensor reading?
2. Am I correct in assuming that I am probably very close to a quart down on oil and that is why the alert is intermittent?
To remove this ad, register today or login if you already are registered!
GoodBeach is offline   Reply With Quote
Old 07-19-2009, 12:26 PM   #2
JDB
JDB's Avatar
Drives: 2008 CLK63 BS, 2004 CL55, 2006 C350, 1999 E430
Your engine is worth thousands of dallars.
Take the vehicle to a dealership or a qualified independent repair shop and have them show you how to properly determine whether your CL needs oil or not.
Then, make sure to keep your oil level maintained properly, and note the mileage that it takes for the engine to consume a quart of oil. it will be one indicator of the general health of the engine.
You own a very complex, expensive machine that requires proper routine maintenance. If you don't maintain it, it can lead to extremely expensive repairs.
JDB
JDB is offline   Reply With Quote
Old 07-19-2009, 01:03 PM   #3
Drives: CL 65/LX470
I broke out the manual. The engine has to be off at least 5 minutes before the oil measurement will begin if at operating temperature otherwise it is 30 minutes. I was down 2 quarts to maximum fill. Interesting that the add one quart warning is triggered at this level. I added Mobil 1 0W40 and remeasured after starting the engine. All is well.
Old 10-30-2009, 06:53 PM   #4
MrStyle25's Avatar
Drives: CL55 AMG
Nice to know that there is a low oil sensor. Seems these cars have a sensor for everything!
__________________
Zoom Zoom!!
MrStyle25 is offline   Reply With Quote
Old 11-01-2009, 03:35 AM   #5
m_berman's Avatar
Drives: 06 CLS55 w/ P030, 05 Jag S Type R, 05 TBird-68 Dodge Charger R/T-440 w/4speed I'm original owner
Quote:
0W40 Mobil 1 is not compliant to MB 229.51 Specification. 5W40 is and is called European Formula on the label. This is the only approved oil that MB says is to be used.
__________________
06-CLS55 w/ 030--the beast at birth
m_berman is offline   Reply With Quote
Old 11-01-2009, 11:19 PM   #6
Totalman's Avatar
Drives: '05 CL65, '07 Pathfinder, '97 SL600 (sold), 23 other cars (sold)
That's odd, since I specifically called a foreman in our NJ MB service to verify that and he stated that 0W40 is used on all AMG's. I had him fill in the maintenance slip specifying the oil and sign it, since I also thought 5W40...
Totalman is offline   Reply With Quote
Old 11-03-2009, 01:34 AM   #7
m_berman's Avatar
Quote:
Mobil 1 0W40 is not 229.51 compliant but is MB 229.5. Check it out at:
https://www.mobiloil.com/USA-English...l_1_0W-40.aspx
Mobil 1 5W40 is MB 229.51 and 229.31 compliant. This is Mobil 1 ESP formulation. Check it out at:
https://www.mobiloil.com/USA-English...a_M_5W-40.aspx
__________________
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
