Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > CL55 AMG, CL65 AMG, CL63 AMG (W215, W216)
CL55 AMG, CL65 AMG, CL63 AMG (W215, W216) Discuss the CL55, CL65, and the CL63 AMG.
Welcome to MBWorld.org!
Welcome to MBWorld,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 11-08-2009, 02:41 AM   #1
02cl55amg's Avatar
Drives: 2005 cl65 & 2006 ZO6
vrp cl65 vs. cammed 540rwhp c6 zo6...who wins?
from a 60mph roll to 160+
i currently own a modified 2006 c6 z with cam, intake, exhaust and tune.
(540/495). i have been wanting a cl65 for a few years now, i just dont think with it modded with the vrp825 it can beat my z. the car is nasty from a 60-160mph roll. i know the 65 has a nasty top end especially when modded. i know of only 2 vrp c65's- jody's and markos running high 10's@130. is the
vrp825 kit a night and day difference from just an ecu tune?
i have 1 run in my z after the cam swap on street tires-
da +3500ft 75 deg in vegas
60ft-2.0
11.4@128
there has only been one modded cl65 here in vegas that i know of running a best of 11.6@121 with full exhaust and kleeman ecu.(you have all seen it racing the red c6z on youtube bridge to bridge)
To remove this ad, register today or login if you already are registered!
02cl55amg is offline   Reply With Quote
Old 11-08-2009, 04:51 PM   #2
Drives: SL600
A VRP'd 65 should do some work on your Z. Markos ECU, last I heard, wasn't even set-up properly on the 10s run. Wonder what the progress with that is...
Akademiks is offline   Reply With Quote
Old 11-08-2009, 04:55 PM   #3
Drives: ES300/LX470/240SX
Well, I know Marko's and Jody's cars are nutsa as theydid 10.7 and that was nuts. Im a Corvette fan as well and a Cammed 06+ Z is no joke. On a power to weight ratio scale, you're what 3,175lbs, that shell really helps, putting you at 5.87lbs/rwhp. Marko's car did 692rwhp/912rwtq, if the CL65 weights 4700lbs, its at 6.79lbs/rwhp. You definitely got the weight advantage but insane torque is on the side of the V12 TT, it would be a good run b/c traction, gearing (auto vs. your wide 6 speed) and weight all make up a great race. On paper though the 10.7 second CLs should be ahead of your Z basing it on 1/4 mile runs, it would be great to see the race.
BTW, I find it scary that a 7.0L V8 can get close to 30mpg on the highway when cruising and 16-18 city. The C6 and especially the C6Z is a beast on all levels. Great car, incase the race doesn't turn out what you want, I've seen SC'ed C6s and Z06s hit 600+rwhp with ease from SC Kits without the use of a cam and on pump gas.
E55AMGFan is online now   Reply With Quote
Old 11-08-2009, 06:50 PM   #4
Dsmed's Avatar
Drives: E55
I have video of a lingenfelter stg3 ZO6 running Marko's CL. Waiting to fill up the mini dvd and than I'll edit and post links. Gonna have some sick vids with couple other cars too.
Dsmed is offline   Reply With Quote
Old 11-08-2009, 08:09 PM   #5
Drives: W211
Send a message via AIM to BenzoBoi
Quote:
Look forward to it!
__________________
4 door sedan with a couple "go fast" mods and some wheels...
BenzoBoi is offline   Reply With Quote
Old 11-08-2009, 08:42 PM   #6
Sounds good!
Old 11-08-2009, 10:24 PM   #7
V12Godspeed's Avatar
Drives: E55
60ft-2.0
11.4@128
Got your PM, sorry for the delay. I think the 65 should have the upper hand as it is a torque monster. The 65 pulls very strong uptop and at those speeds weight will not be an issue.
I did not get to dyno my 65 since dynos don't mean much to me. The best dyno I have seen is the 1/4 trap and ET's. Marko or Marcin did dyno the 65 witht he VRP kit and put out close to 700rwhp with nearly 900rwtq, we ran nearly identical times so power should be somewhat hand in hand.
__________________
Current:
04- E55- White/ Pano w/all options/ Stock for now...
Previous Rides:
05- CL65- "The Black Bison"
VRP 825 - 10.72 @ 128.08
http://www.youtube.com/watch?v=caoztJbtaZA
"Capo Regime North (Member# 3)"
Gone but not forgotten....
2004 E55 Evotech Stage 4+ - Silver
11.5 @ 120.96
http://www.youtube.com/watch?v=AgNFUdDMQHw
2002 C32- Black
V12Godspeed is offline   Reply With Quote
Old 11-08-2009, 10:50 PM   #8
Drives: E55, Renntech CL600(sold), GL450
Quote:
Originally Posted by E55AMGFan View Post
On a power to weight ratio scale, you're what 3,175lbs, that shell really helps, putting you at 5.87lbs/rwhp. Marko's car did 692rwhp/912rwtq, if the CL65 weights 4700lbs, its at 6.79lbs/rwhp. You definitely got the weight advantage but insane torque is on the side of the V12 TT, .
I'm not a huge fan of the hp/lb argument. You have to look at how the engine performs over the entire rpm range and not just the peak hp. The V12 tt will be producing more power/lb over 95% of the rpm range looking at the engine's power output. The only point the Vette will have a greater hp/lb will be at the very top end of the rpm range.
Given that, you have to look at gear ratios as well as lbs/hp. That will tell you the true picture of how well a car will perfrom against another. Driver competency will also play a big part of the race between the Vette and the Mercedes.
BlownV8 is offline   Reply With Quote
Old 11-09-2009, 03:49 AM   #9
02cl55amg's Avatar
i tip the scale @ 3100lbs and have a 100 shot on tap if needed. i just installed 345 mt et streets so i think with a good 60ft i should see very high 10's. the reason i ask is that i want to get rid of the z and get the 65. i would like to sell the z first then pickup a 65, but their are not too many clean, low mileage, black ones left. i would like to have both, but that would be costly
get those vids up!
Tags
2006, c6, cammed, cl65, mb, vs, world, youtube
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
