Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 |
KW suspesnions and 285-30 19
Hi everybody I haven't post here for a while
I jsut put on KW V2 suspension on and try to fit 285-30 19 at the rear 285 fit in with a bit of fender roll and car is lower with no gaps between fender and the tires. I only put about 50kms with this set up I will post pictures and more update after alignment is done. BTW I have full Brabus suspension for sale. spring and shocks for 320 and a set of used 275-30 19 about 70% thread left. contact me if you want more informations. teryps2@Hotmail.com
__________________
Brabus bodykit, Brabus muffler, Lorinser deck lid, Fikse Profil 10 19" with PS2 F/235 R/285, Brabus suspension, Brabus sway bars, front splitter, K&N filter, 5000K HID, Renntech performance package, SCHRICK camshaft, NGK 9degree race sparkplugs, Racing Cat, Odyssey Light weight battery, Wiechers front and rear Strut Bars, Evosport UD pully, stright pipe, Recaro SPG with OMP harness, AMG brake, kleemann header, carbon fiber hood. |
| Sponsored Links |
#2 |
Man show pics I just put 19's on with 265/30 in the rear with the H&R/Bilstein sports shocks set up with no spacer but feel I could hold a little more rubber. I think I'll wait till it settles a little more since its been less than a week and see about some spacers.
#3 |
How do you like the KW's? I love mine. Damn, you actually fit 285s back there! Wow
__________________
Pump gas, full interior, no nitrous (Sig courtesy of racetested) QUICKEST/FASTEST no nitrous CLK; Best Mercedes 60'; Most axles broken |
#4 |
I love those KW V2 !!
I went through almost every brand except for kleemann. KW is the best so far. It breaks down the bump every well. I am trying to play with different alignment setting. here is what I ask the shop to set up today front and rear toe at 0. front camber -2 rear -2.5. It seems far from OEM spec but the car drives great. speically the initial turn in. I will try to get some camber kit and play around with it. everybody on the fourm welcome to share their experince and setting with us.
__________________
#5 |
I have 285's right now also
__________________
"If everyone thought the same when it came to modding there would be no thinking" |
#6 |
awesome... cant wait for your pics.. i love your 208...
btw, off topic Tery... have you ever gotten your car on a Dyno? From all the "320" owners I think you have got the most modified N/A ... I think the only two things you are missing are the TVT fuel injectors and thermostat...
__________________
#7 |
some quick pix to share, I will take some better one from outdoor.
I never got the car dyno yet, the car was pretty much sitting in the gerage for the passed 2 years. can you give me more information about the injectors ? ![]() ![]() ![]()
__________________
#8 |
god damn thats hot... i wish i could do 285s in the rear... im on 9.5 with 245s...anymore rubber than that and I rub with my drop ...
TVTdesign (crossfire-known tuner) has a Stage-1 Injector / Software re-tune package for something like $900 ... they have a bunch of dyno's showing a 35hp(crank) improvement... they call it the TVT250 package.. it ups the power from 215bhp (stock) to 250bhp with software, filters and Injectors. PM me and Ill show you links and everything..
__________________
#9 |
That looks hot tery. what do you drive when thats put up for two years?
#10 |
Looking good Tery...very clean and not overdone
__________________
#11 |
I used to drive a W202 230Kompressor and last year I got an A3 3.2Q
Here is some pictures of my A3 ![]()
__________________
#12 |
Even your daily looks dope. Good job
#13 |
more pictures but too bad the rain in Vancouver
__________________
#14 |
__________________
#15 |
if I was to step up to a 285 will it fill in my wheel gap more or will it make the rear sit higher?
#16 | |
Quote:
It depends on the tire brand and if you are going to be mounting it on a wide enough wheel. If the wheel is not wide enough for a 285 the tire will look bulky and the car will sit a tad bit higher but if the wheel is wide enough to pull out or stretch the tire the car will not sit higher and the tire will not look bulky
__________________
#17 |
and the offset of the wheels is important too.
__________________
#18 |
Thanks I feel like I can get more tire on the back but don't know my offsets. I guess I wait till its time for some new rubber and decide then.
#19 |
any pics of the Wiechers front and rear Strut Bars installed?
I was only able to find this pic...
__________________
18x8x225x40@et31, 18x9x265x35@et35, #1 front, 0 rear, bilstein sports, resonator delete, flat hood emblem Last edited by sfclk; 11-17-2008 at 01:24 AM. |
#20 |
Wiechers struct bars are here
hope this help. it was back at 2004 I was still using very old school camera.
__________________
#21 |
your car looks siiiick!
__________________
________________ ![]() ________________ |
| Display Modes | Rate This Thread |
