Go Back   MBWorld.org Forums > Mercedes-Benz Coupes & Cabriolets > CLK-Class (W209)
Thread Tools Search this Thread Rate Thread Display Modes
Old 10-28-2008, 07:17 PM   #1
06 Navi/ AC control unit work on a 2003 clk 55amg
Hi I have a 03 clk amg 55 it had navigation. but someone broke into the car and stold everything cut / ripped the wires. ****ed up the dash a bit. So i bought a brand new one straight from a 06 clk 55 amg it has the newer navigation/ ac controls/ heater controls with all the harnesses would everything be fine let me know
heatfan5 is offline   Reply With Quote
Sponsored Links
To remove this ad, register today or login if you already are registered!
Old 10-28-2008, 07:44 PM   #2
i doubt it but im not sure. someone mind stepping in?
__________________
ZEEK is offline   Reply With Quote
Old 10-28-2008, 10:07 PM   #3
it fits perfect in the dash I would just need to have everything intalled.
Old 10-29-2008, 12:53 AM   #4
MARK CUMMINS's Avatar
On a Early 209 CLK The LATE 209 NavComand will NOT Work... different systems...Early Cars have a CD based system..Late Cars have a DVD based system Canbus vs Most..
One would have to rebuild the entire car with late components to make it work
__________________
Why is there the Need to Eliminate Responsibility for ones Actions by Blaming Everyone Else
MARK CUMMINS is online now   Reply With Quote
Old 10-29-2008, 01:06 AM   #5
so if we tried putting a 05 clk nav/command onto a 04 it wont work, correct? because as far as i remember 03 and 04 clks were same and 05 and up were same, right?
__________________
Old 10-29-2008, 07:29 AM   #6
fourml8r's Avatar
Quote:
that is correct it won't work. the 05 and up models use the DVD based command system. 04 and earlier use the CD based system.
fourml8r is offline   Reply With Quote
Old 10-30-2008, 07:55 AM   #7
Ok I don't get it . won't it at least install and powerup and have full radio controls? it would be like installing an aftermarket indash except its a mercedes stock dash.
Old 11-07-2008, 08:00 AM   #8
Different electronics on these cars!
Newer w209/w203 are on a MOST ring, older vehicles (prefacelift) have D2B!
http://www.benzworld.org/forums/audi...-d2b-most.html
iliaspope is offline   Reply With Quote
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
