Go Back   MBWorld.org Forums > Mercedes-Benz Coupes & Cabriolets > CLK-Class (W209)
Thread Tools Search this Thread Rate Thread Display Modes
Old 11-06-2008, 11:49 PM   #1
Location: Fremont, CA/ University of California San Diego
Send a message via AIM to KwlAznKid Send a message via Yahoo to KwlAznKid
what's the stock spring pad size?
for a clk500? does anyone know how many mm it is? and has anyone here removed their spirng pad completely before? is the sound really annoying?
thx
__________________
Mine: 2003 Mercedes Benz CLK500, BMW 2001 E46 325 CI (TOTALED)
2007 Mercedes Benz S550
1993 Mercedes Benz 400 SEL
2003 Infiniti FX45
KwlAznKid is offline   Reply With Quote
Sponsored Links
To remove this ad, register today or login if you already are registered!
Old 11-07-2008, 01:01 AM   #2
by removing the spring pad completely you wont hear the sounds, as long as it is sitting properly. You can probably call the dealer and ask what pad it is stock?
__________________
ZEEK is offline   Reply With Quote
Old 11-07-2008, 02:58 AM   #3
coin's Avatar
Quote:
thx
From my understanding, we have to remove spring pads completely if we install coilovers. But keep them if we install just aftermarket springs.
__________________
Feeler: 19x8.5F 19x9.5R Authentic Lorinser LM6
coin is offline   Reply With Quote
Old 11-07-2008, 03:36 AM   #4
Klinh's Avatar
You will not 100% sit the spring properly on the top of the spring if you remove the pad completely. There's no pad on the bottom of the spring because the control arm designed with the groove for the spring to sit onto. As for the top, Mercedes designed a "cup" like looking with just flat bottom to hold the spring. The pad is not just used for adjusting ride height but the groove on the pad is designed to sit the spring properly from sliding. Without the pad, there's about at least 5mm of free play.
Dealer is not gonna know the exact pad on any given car without checking physically. It very easy to check the pad number. All you need is a flash light. Jack up your car and use the flash light to look around the edge of the pad and you will see how many "dot"/ "knot".
Klinh is offline   Reply With Quote
Old 11-07-2008, 03:42 AM   #5
Klinh's Avatar
Quote:
How's the spring gonna sit properly if you remove the pad? Why even need to remove the pad when the coilover kit ride height is adjustable?
Old 11-07-2008, 03:48 AM   #6
Klinh's Avatar
thx
Not all Mercedes models pad numbers are in same mm thickness. The pads number are the same but the thickness in mm are difference from models to models (weird huh?). The numbers listed below are for my car.
#1 5mm
#2 don't remember
#3 don't remember
#4 17mm
Old 11-07-2008, 04:12 AM   #7
Quote:
#1 5mm
#2 don't remember
#3 don't remember
#4 17mm
thanks for the replies, you seem very knowledgable about this subject, my car is dropped on aftermarket springs right now but i went to lower the front more, i heard a ez way to do this is to change the spring pad, which is why i'm asking this question, would you say it's better to just completely remove it? based on what i'm getting from what you posted it doesn't really matter to take it off right? any clanking that might happen or creeks that might happen from removing it? i might just remove it completely then
thanks
__________________
2003 Infiniti FX45
Old 11-07-2008, 12:23 PM   #8
completely removing the pad will make noise...i frankly dont like the noise, so i opted to get the pads shaved.
You can completely remove the pad, and add in a thick rubber hosing, and that will keep the noise down, but there still will be play.
Its entirely up to you; do you want looks and sacrifice comfort?
__________________
19'' old School Lowenhart LD1 (wintershoes)
19" new School Carlsson 1/16 BE (summershoes)
19" MRR GT1 (springshoes)
235/35/19 + 275/30/19
2" drop on H&R with #1 Pads.
Supafly is offline   Reply With Quote
Old 11-07-2008, 12:28 PM   #9
Nah I hate noise I guess a thinner pad is the way to go then thx
__________________
2003 Infiniti FX45
Old 11-07-2008, 04:10 PM   #10
Klinh's Avatar
but i went to lower the front more, , thanks
Got bad new for you. The W209 Clk came with struts for front and shocks for rear. Which mean, there's no pad in the front (just a thin rubber to prevent rubbing from metal to metal), only pad in the rear. The W208 Clk came with came with shocks and pad all around.
Old 11-07-2008, 04:48 PM   #11
nooooooooooo
thanks for the heads up though
__________________
2003 Infiniti FX45
Old 11-07-2008, 05:10 PM   #12
but if you take that rubber seal out, and you will get 'bout a quarter inch drop...its not that thin.
you can shave it if you really want to get that extra drop, but there will be play and noise.
__________________
Old 11-07-2008, 06:54 PM   #13
Klinh's Avatar
Taking the top rubber out is a no no because the top strut plate move when the steering wheel turn. This is why the also have a bearing plate that goes between the chassis and the strut top plate to allow the whole strut to move. Without the rubber, is like metal to metal gridding from the spring and the plate.
Shave it wouldn't worth the labor you have to pay for a few mm drop that you can't tell the different.
Old 11-07-2008, 07:12 PM   #14
of course, thats why i put mine back in. but it sure did look good with it out. I just shaved mine down a bit with a CNC machine at work. A few mm is always worth it. haha
__________________
Old 11-07-2008, 07:25 PM   #15
Klinh's Avatar
It worth it if you don't have to pay for the labor.
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
