Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > CLK55 AMG, CLK63 AMG (W208, W209)
CLK55 AMG, CLK63 AMG (W208, W209) Discuss the past, present and future CLK55 AMG and the CLK63 AMG.
Welcome to MBWorld.org!
Welcome to MBWorld,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 09-19-2005, 03:08 PM   #1
aintME's Avatar
Drives: Mercedes-Benz
Send a message via AIM to aintME
Shift optimized gear feature
I found this blurb on the MBUSA site, it was in reference to the W163 ML.
Shift optimized gear feature added for MY02 to allow driver to find optimized performance gear by holding lever to left or right to down/upshift to best possible gear.
Does anybody know when/if this feature became available for the W208? I was driving my brother's 208 55 the other day and thought that it had this feature, but, it didn't seem to work?!? I *thought* it was adapted to the 208/210 in 01?
To remove this ad, register today or login if you already are registered!
aintME is offline   Reply With Quote
Old 09-19-2005, 03:16 PM   #2
Chappy's Avatar
Drives: AMG
I have it on my '02.
__________________
W208 CLK55 - 2002 (Silver w/Charcoal - 43K miles)
1 of 3,381 W208 AMG Coupes Worldwide
304WHP / 321TQ - Stock!
W124 Estate - 1995
MBWGCM #71
Kombi's Uber Alles Member #3
Chappy is offline   Reply With Quote
Old 09-19-2005, 03:24 PM   #3
aintME's Avatar
Thanks! my sister has it on her 02 208 as well. Maybe I read wrong? does anyone w/ an 01 208 have this feature?
Old 09-22-2005, 09:04 PM   #4
Drives: 01 CLK 55
I have an 01 55 and I have not had that feature work on my car so I would say that it does not have it.
shan12 is offline   Reply With Quote
Old 09-26-2005, 04:17 PM   #5
Drives: 01 CLK 55
I stated earlier that the shift opti feature did not work on my 01 w208 and I was misinformed. I used it last night in a race with a Lancer EVO. Yeah it worked.
Old 09-26-2005, 05:17 PM   #6
aintME's Avatar
Quote:
did you hold the shifter to the left while on or off the gas? meaning, did you floor the pedal at the same time, or did you let it drop the gears first? my bro thinks it works in his, but, he says he simultaneously floors the pedal. if that's the case, i'm thinking it was just kicking down as a reaction of pedal movement.
I'm trying to determine if there is a problem with his car. Thanks to all for the input.
BTW, what was the outcome of the run w/ the EVO?
Old 09-26-2005, 07:21 PM   #7
Drives: 01 CLK 55
Beat the EVO but he didn't stay in it for long...maybe 5 blocks. I floored it and at that time it jumped from 4th to 2nd and after the run I did it again and it went from 4th to 3rd. When I just hold it left and decelerate it don't do jack. This is my first benz and I don't know all the little tricks so you tell me. So if it is supposed to do it on deceleration no the 01 w208 does not have it but if it is only supposed to do it when you floor it then yes it does have it. I dunno. You tell me.
Old 09-26-2005, 07:32 PM   #8
aintME's Avatar
It sounds like the 01 doesn't have it then. I'm pretty sure even when you aren't on the gas, if you hold it to the left, it will drop down to the lowest possible gear.
btw, good kill
__________________
No Sig here...
Old 09-26-2005, 08:26 PM   #9
Drives: 01 CLK 55
Just to let you know. I messed with it some more and if you hold the stick left it will start down shifting like at 10mph and then at a dead stop it will go from 4 to 1. If in drive under normal accel it will shift to the best gear to go like mine went from 4 to 2. Hope this helps. It will pick the best gear to start from when you hold it left. So I believe it does work but you have to shift it up.
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
