Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > CLK55 AMG, CLK63 AMG (W208, W209)
CLK55 AMG, CLK63 AMG (W208, W209) Discuss the past, present and future CLK55 AMG and the CLK63 AMG.
Welcome to MBWorld.org!
Welcome to MBWorld,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 02-24-2007, 01:00 PM   #1
clkal's Avatar
Drives: 01' CLK55
Send a message via AIM to clkal Send a message via Yahoo to clkal
HELP! Please.....
The last 2 days, I've been having problems w/ my shifter. When I pull into a parking spot and try to park my car, the shifter will get jammed in the Neutral position, and will NOT want to shift up to the Park position. At first, the problem was intermittment. Now, I need to wiggle it and "get lucky" for it to go into park.
Has anybody experienced something similar, or know what to do to correct this problem?
Any help would be appreciated =)
To remove this ad, register today or login if you already are registered!
clkal is offline   Reply With Quote
Old 02-24-2007, 01:25 PM   #2
Drives: 01 Kleemann CLK55, 99 CLK430
A few pennies fell into my CLK430 a long time ago and was giving the same symptoms. I had to "fish" them out after taking off all the covering pieces.
__________________
Run Your Car Not Your Mouth
This is how we roll
blackbenzz is online now   Reply With Quote
Old 02-24-2007, 03:23 PM   #3
Drives: '02 CLK55
Quote:
Is that your 2 cents worth?
__________________
Dr. Jekyll .................&............. Mr.Hyde-brid
Zoom On is offline   Reply With Quote
Old 02-24-2007, 05:31 PM   #4
clkal's Avatar
Drives: 01' CLK55
BB. do all the covering pieces just snap off, and then snap back into place? and do I need to remove the shift knob first? if so, how does the shift knob come off?
thanks,
AL
Old 02-24-2007, 06:02 PM   #5
Quote:
thanks,
AL
I dont remember, I did this like 2 years ago. If possible, see if you can get some long tweezers and try to pull out whatever is in there without removing the covers. I believe the bottom piece of the shift knob twists off and then the top part you can just pull straight up off of it. Hope that helps a little.
__________________
This is how we roll
Old 02-24-2007, 08:32 PM   #6
Drives: 00 KLEEMANN CLK 430. Stares at: 88 Euro AMG 560 SEC Widebody
If it's not the $.02 problem, maybe it's like the $197.83 problem I had when my shifter started sounding like something was loose in the area under the console and shifted like it was going to stop shifting soon. The fix - $2.03 shifter bushing, installed at dealer for $195.80 in labor.
__________________
Enjoy yourself - Marco
lowphat is online now   Reply With Quote
Old 02-24-2007, 10:39 PM   #7
clkal's Avatar
Drives: 01' CLK55
Quote:
thanks for the input. i really don't hear any loose noises coming from the shifter ... it just gets stuck. I'm going to try to open up the coverings tomorrow morning and check to see if anything happened to fall in there.
i'll take pics and let everybody know how it goes.
AL
Old 02-27-2007, 05:22 AM   #8
clkal's Avatar
Drives: 01' CLK55
update. I had my friend take off the shift knob, the wooden panel where all the window/sunshade/esp/airbag buttons are, the black plastic ring which goes around the shifter plate, and the wooden shifter plate itself. I still could NOT see anything jammed or stuck in the shifter.
Old 02-28-2007, 12:44 AM   #9
mbenzman's Avatar
Drives: All of them!
Visit your Mechanic! This is more than likely a shifter control module failure. A new module will have to be coded so not a DIY job. But will get worse and have to be towed.
Rich
__________________
mbenzman is offline   Reply With Quote
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
