Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > CLK55 AMG, CLK63 AMG (W208, W209)
CLK55 AMG, CLK63 AMG (W208, W209) Discuss the past, present and future CLK55 AMG and the CLK63 AMG.
Welcome to MBWorld.org!
Welcome to MBWorld,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 01-11-2003, 08:39 PM   #1
Drives: CLK55 Cab
Send a message via AIM to trock3155
Suspension changes with new rim size
In a couple weeks I will be swapping my stock CLK two piece 17" rims to a new set of 19"s. I have realized that people often modify their suspension for bigger rim sizes. My question is, will i need to drop my car? I know that the entire wheel(with tire) will be about the same height, but where the rim meets the axle will be higher(by an inch i guess). I guess I wouldnt have to change anything, but I dont want there to be a gap in the wheel well or a loss in handling. Any input so i can start looking for new springs(if necessary) would be helpful.
Asa
To remove this ad, register today or login if you already are registered!
trock3155 is offline   Reply With Quote
Old 01-11-2003, 11:39 PM   #2
Send a message via AIM to Mach430
The entire wheel/tire combo will not be the same height. The diameter when changing from a 17 to a 19 is much greater than before. IMO, you will need to lower your car, just to bring it back down to spec. Otherwise, your car will look like it is floating.
__________________
Mach430 is offline   Reply With Quote
Old 01-14-2003, 03:31 PM   #3
scorchie's Avatar
Drives: Aston Martin Vantage V8 / Range Rover Supercharged
Quote:
I can't believe that Ben actually wrote those sentences.
Unless he knows something about this guy's setup that wasn't posted... otherwise the idea is to keep the same diameter for the entire wheel/tire combo?
I understand there may be nominal differences in the actual tire specs, maybe 1/4" or so, but that's hardly noticeable from glancing at the tire.
-s-
scorchie is offline   Reply With Quote
Old 01-14-2003, 11:02 PM   #4
I wrote it based on every day experiences. Yes, the idea is to get the same diameter, but it's not going to happen. The diameter will increase, and it is definetely noticable (at least by myself). Find a CLK with stock suspension and 19" wheels, and then compare it to another CLK with 17" wheels. The one with 19s will look like it's floating. My CLK is much higher, now that I have 19" wheels.
__________________
Old 01-14-2003, 11:07 PM   #5
Petie's Avatar
Drives: 2000 CLK430
Send a message via AIM to Petie
-s-
lets say 1/2", because thats closer to the truth. So your car sits 1/4" higher off the ground based on this 1/2" assumption. But then you factor in the aesthetics of a 19" wheel on a stock suspension as compared to the 17" wheel on stock suspension. Im not an expert on how eyes work, but even though its not that much taller, it definitely looks it. When i went just to 18s, my rolling diameter was hardly changed, yet the car still looks much more in need of suspension work now. Its not so much the numbers, its the way the eye perceives the change....
__________________
2000 CLK430 Glacier White
Kleemann two-tone interior
Carlsson Staggered 2/5 Brilliant
Kleemann Big Brake Kit
Eisenmann Exhaust
EvoSport Underdrive Pulley System
EvoSport PrePainted Side Markers
Illuminated Door Sills
Custom Painted front grill & Custom flat hood badge
///Alpine ICE System
5% Tint
Petie is offline   Reply With Quote
Old 01-14-2003, 11:08 PM   #6
LowRydeR's Avatar
He's right, my car raised about an inch when I switched to 19s. I hated it so much that I cut my springs.
-Bruce
__________________
Seventeen
to Fifty-Five Millimeter F Two-Point-Eight IS on
Twenty D
LowRydeR is offline   Reply With Quote
Old 01-15-2003, 12:38 AM   #7
Quote:
-Bruce
u had ur spring cut already bruce?! lets see some pics!
__________________
Merry X'mas and a Happy New Year
tango is offline   Reply With Quote
Old 01-15-2003, 02:48 AM   #8
scorchie's Avatar
You guys need to buy the right tires (or vary the brands you use).
My 19" tires are smaller than the 18" tires I use, according to manufacturer specs.
Also, the bigger the tire diameter, the lower the car looks because the wheel gap is smaller.
-s-
Old 01-15-2003, 02:01 PM   #9
Scorchie,
Between myself, Petie, and Lowryder we've used Michellin Pilot Sports, Yokohama AVS, Pirelli P-zero, Kumho, Bridgestone SO3, Dunlop SP9000, and Toyo T1s. What am I missing? Yes the fender gap looks smaller (another sign that the diameter has changed!), but the height of the car will change.
__________________
Old 01-15-2003, 03:41 PM   #10
Drives: CLK55 Cab
SO how much should i lower my car, and what kind of springs should I get. I would be glad to order them from evosport as you guys have more experience with my type of car than any other place I can think of.
Asa
Old 01-15-2003, 04:24 PM   #11
If you're only looking to do springs, I would recommend H&R. They will lower the AMG cars about an 1", which is not too much or too little. If you are looking to change your shocks at the same time, I would either recommend Koni Adjustables, or the complete Kleemann Suspension. In can explain either if you need me to.
__________________
Old 01-15-2003, 08:57 PM   #12
GBD
Drives: CLK55AMG
Michelin Pilot Sport 245/40ZR17... overall diameter 24.7 Michelin Pilot Sport 265/35ZR18.... overall diameter 25.3 only.6 taller. So this only raises your car one half of .6 wich is .3. That .3 on the top and .3 on the bottom and it is the bottom that raises your car no matter what your eyes are saying to you. The 265/35ZR18 are .9 wider than the 245/40ZR17 tires or just about 1 inch wider. These figures are correct and right off of the Michelin spec sheet.
GBD is offline   Reply With Quote
Old 01-16-2003, 06:01 PM   #13
He's asking about switching from 17s to 19s. Using the Pilot Sports (to stick with your example) in a 275 (no 265 made):
275/30/19 gives an overall diameter of 25.7, a 1" increase.
This will add .5" to the height of the car, which is noticable. The AMG is only about 1" less than a 430 to begin with... Try doing this to a 430, then you have a CLK 1.5" higer than the CLK55> that's a truck!
__________________
Old 01-17-2003, 08:46 PM   #14
LowRydeR's Avatar
Quote:
This was a while ago when I still had my 18" mono and cut H&R.
-Bruce
__________________
Seventeen
Twenty D
Old 01-17-2003, 08:48 PM   #15
LowRydeR's Avatar
A better pic showing how low she was, the very last CLK is mine.
-Bruce
__________________
Seventeen
Twenty D
Old 02-01-2003, 04:56 AM   #16
f1vu's Avatar
Drives: Mercedes 2001 CLK55 AMG, 2000 ML320
Send a message via AIM to f1vu Send a message via Yahoo to f1vu
I have 19" Carlsson 2/5 and Yokohama on my CLK55. 235 in front and 265 in the rear. I lowered the car with H&R sports springs and love the the way the car sits. My car was lower than my friends car (he used Eicbach). Springs pas #2 up front and #1 in the rear.
I had one problem with my set up though but has been corrected. After the Springs were installed, the camber in the rear was squating too low. MB does not provide adjustable camber bolts OE with the car for the rear. I had to buy a set of the KMac camber kit to bring the camber back out.
All is great now. I love the way it looks and rides like it's on rail around cornners.
Go for it and lower the car... :-)
__________________
2001 CLK55 ///AMG, Brilliant Silver
Carlsson 2/5 19", Lorinser tail, H&R sport spring, Sport Grill, K&N filters, AMG aluminum pedals, AMG hood emblem, black birdseye door handle, black birdseye & leather arm rest, black birdseye shift knob, aluminum bezel trim, aluminum shift gate/frame, "AMG" illuminated door sill, Chrome headlight rings.
2000 ML320, Brilliant Silver
f1vu is offline   Reply With Quote
Old 02-01-2003, 04:59 AM   #17
f1vu's Avatar
Lowrider,
Did / do you have camber problems with the front and rear after lower the car down that low? If so, what did you do to fix the camber?
__________________
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
