Go Back   MBWorld.org Forums > Mercedes-Benz Coupes & Cabriolets > CLS Coupe (C219)
Thread Tools Search this Thread Rate Thread Display Modes
Old 11-14-2008, 10:03 PM   #1
daytime running lights not working
i have an 09 cls550.i am trying to activate the daytime running lights.in the manual it says to keep the headlamp in the constant mode.but the lights dont seem to work.in the constant mode the headlamp turn on but not the DRL.is it something i have to take it to dealership and have it programmed ?
saala is offline   Reply With Quote
Sponsored Links
To remove this ad, register today or login if you already are registered!
Old 11-15-2008, 10:17 AM   #2
konigstiger's Avatar
Headlamp switch to Auto
MFD: Settings – lighting – headlamp mode – to constant (DRL)
__________________
konigstiger is offline   Reply With Quote
Old 11-15-2008, 01:27 PM   #3
I'm not sure if the setting is the same as my 06, but they did not work when I got my car also. Check your owners manual. There was a setting in lighting options that allows them to operate. It was easy and I changed the setting myself using the steering wheel controls.
Kirkdob is offline   Reply With Quote
Old 11-25-2008, 04:51 PM   #4
i did change the setting to the constant mode(drl) but i dont see the lights coming on.the same xenon bulb stays on.
Old 11-25-2008, 04:52 PM   #5
i did try that setting but the same low beam xenon lights come on in that setting.
Old 11-25-2008, 05:31 PM   #6
Quote:
#2 should be activated - DRL designed to operate at about half their normal power during daylight hours conserving energy and improving bulb life.
__________________
Old 11-26-2008, 01:51 PM   #7
Super Moderator
Kar don's Avatar
yeah if you have xenon the low beam xenon is your DRL. CLS I had in canada the low beam xenon was on all the time. If you have halogens then the high beam operates at low power as your DRL.
konigstiger, you should know that! Come on!
__________________
08 Mercedes-Benz CLS550 Iridium Silver/Black Leather - P2, AMG pkg, Parktronic, Ipod
07 Lexus GS350 Smoky Granite Mica/Ash leather - NAV, 18's, Sirius, AFS, ventilated seats, & Rear spoiler (gone!)
Kar don is offline   Reply With Quote
Old 11-26-2008, 08:49 PM   #8
thanks guys now i got it.the reason i was confused was because my previous car 06 bmw 330i had xenon lights.but when i activate the DRL it was halogen bulb next to xenon which served as a DRL. but i guess MB uses same xenon at less intensity rather than the halogen bulb next to the xenon.
Old 11-27-2008, 12:26 PM   #9
Quote:
A moment of clarity “bi-xenon”
__________________
Old 11-27-2008, 12:46 PM   #10
Super Moderator
Kar don's Avatar
saala, actually the xenon runs at full intensity. You can't run them at partial power.
__________________
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
