Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > CLS55 AMG, CLS63 AMG (C219)
CLS55 AMG, CLS63 AMG (C219) Discuss the CLS55 AMG and the CLS63 AMG.
Welcome to MBWorld.org!
Welcome to MBWorld,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 07-06-2009, 05:28 PM   #1
Drives: cls 55 amg
Red face CLS 55 AMG POWER LOSS
Hi i have a 2005 cls 55 amg
after it warms up and i drive it a little hard the s/c cuts out and then sometimes comes back on when i drive slow for a while
i've pluged it in and it comes up with coolant pump, charge-air cooler
error detected.....i have changed the pump and the same happens so i take it it's not that
any ideas ?....
thanks chris
To remove this ad, register today or login if you already are registered!
1londonboy is offline   Reply With Quote
Old 07-06-2009, 06:04 PM   #2
jturkel's Avatar
Drives: 02 C32 AMG
Send a message via AIM to jturkel
so you have the error, you changed the i/c pump, and STILL have the the s/c cutting out and driving slow problem?
__________________
| 02 C32 AMG | SL55 Intake w/K&Ns | LET 185 Pulley | LET Tune | LET Heat Exchanger | Eurocharged Headers | Res Delete | NGK IX Iridiums | Magnecor KV85s | NW Pulley Saver | NW ISO Kit | Valentine1 | DashDyno SPD | CF Trunk Lip |
Waiting Install: NW oil catch can
Next: secondary cat delete, retune, coolant reservoir, intake/tb project, hooley button
jturkel is offline   Reply With Quote
Old 07-06-2009, 06:07 PM   #3
Drives: cls 55 amg
thats right there was no change
Chris
Old 07-06-2009, 07:15 PM   #4
JustPete's Avatar
Drives: CLS55 AMG 030
any ideas ?....
thanks chris
Possible solutions ...
Whats wrong with my New AMG
Intake tube system the same CLS55 vs E55 ? Simple mod ... great results!
DIY Heat Exchanger Prep
__________________
JustPete is offline   Reply With Quote
Old 07-06-2009, 07:44 PM   #5
PREMIUM SPONSOR
Drives: 07 RS4
Send a message via AIM to James@ACGSD
Where are you located?
Which did you replace it with? Where did you get it installed at?
If you replaced it with an OEM one, it is not unheard of to get a bad pump right out of the box.
__________________
Automotive Connoisseur Group Inc of San Diego
Now stocking all Euroteck Motorsport Products
WE STOCK VREDESTEIN Tyres
Now Operating from:
7924 Ronson Road Suite I&J
San Diego, CA 92111
877-422-4736/ 858-633-1017
Providing same day Kleemann and RENNtech ECU tunes
Top 5 RENNtech Dealer 2009
ACG New York Coming soon
East Coast Tuning event
DC Mov 30-Dec 2 2009
NYC Dec 2-Dec 5 2009
James@ACGSD is offline   Reply With Quote
Old 07-07-2009, 05:39 AM   #6
Drives: cls 55 amg
i rebuilt the one that was in it, and then still bought a brand new one from merc ...and still had the problem with both of them ...but they are running still when the s/c cuts out
Old 07-07-2009, 02:34 PM   #7
PREMIUM SPONSOR
Drives: 07 RS4
Might be a dumb question, but have you checked your coolant levels? Where are you located? Maybe I can give you a suggestion to where you could take your CLS
__________________
Now Operating from:
San Diego, CA 92111
Old 07-07-2009, 03:43 PM   #8
Drives: cls 55 amg
yes levels are all good...if i drive it slow s/c comes back online till i give it the beans again then it shuts off...i am going to change the relay on the coolant line tomorrow not sure if thats going to help but it's cheaper than that pump was ......i'm in sunny london England
Chris
Old 07-07-2009, 04:19 PM   #9
JustPete's Avatar
Chris
Air locked maybe?
Was the system bled?
__________________
Old 07-07-2009, 05:22 PM   #10
Drives: cls 55 amg
i have taken the small plug off from the top of the hose and coolant is coming out so i take it theres no air in the pump ....thanks chris
Old 07-09-2009, 02:37 AM   #11
Drives: All of them
theres really only two things that control that supercharger, the secondary coolant circulation pump ( wich is inline with the only coolant system and should be on the passenger side near the front bumper area, not like the 65s that have a seperate cooling system for the innercoolers) and possibly a bad intake air temp sensor or if you were in the area maybe disconnected. if it sees the intake temp too high it will shut off the supercharger sometimes too
MBTech221 is offline   Reply With Quote
Old 07-09-2009, 06:02 AM   #12
Drives: cls 55 amg
i have looked at the outside temp ...and it's showing -40 i know i'm in london but it's that cold ....is that what would happen if it has become disconnected ?...any idea where it is ?....
Thanks chris
Old 07-09-2009, 08:28 AM   #13
Drives: cls 55 amg
is the intake air temp sensor the same as the outside temp sensor ?....i've just seen the outside temp sensor has come lose and been ripped off ...off to go get a new one now ...
Old 07-09-2009, 10:59 AM   #14
Drives: cls 55 amg
dealer hasn't got one have to wait till monday to get it
Old 07-09-2009, 08:34 PM   #15
Drives: All of them
thats the outside temp sensor that should be in the front bumper it will read -40 when its disconnected or an open in the wiring, the intake temp sensor should be right before the throttle body. sholuld be a lil sensor with two wires. i havnt seen a outside temp sensor cause a supercharger not to come on. but it is possible. on the new c class w204 body if that is disconnect it will set a check engine light that outside temp doesnt correspond to intake air temp codes.
Old 07-09-2009, 08:53 PM   #16
Drives: cls 55 amg
thanks for your help on this i'm pulling my hair out...i've been out in it tonight and it cuts in and out all the time ...soon as i floor it for a minute it cuts the s/c then drive slow and it comes back on...can i plug in and read that temp sensor ...or should i just get a new one ?.....thanks chris
Old 07-09-2009, 09:00 PM   #17
Drives: All of them
wich pump did you replace. where was it located on the vehicle. i would def get a new outside temp sensor. but i would def take a second look at the secondary coolant circulation pump
Old 07-09-2009, 09:07 PM   #18
Drives: cls 55 amg
the pump is on the right behind the bumper i took mine apart and replaced the carbon brushes....and then even bought a brand new one from mb £230...both were running when the s/c cuts out....i have stopped the car and jumped under it to check the pump is running ....which sensor should i get?...i have to replace the outside temp one in the bummper anyway cause it's gone lol....but should i get the one on the throttle body?...thanks Chris
Old 07-10-2009, 01:31 AM   #19
PREMIUM SPONSOR
IngenereAMG's Avatar
Drives: SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
Send a message via Yahoo to IngenereAMG Send a message via Skype™ to IngenereAMG
This sounds like an IC pump issue.
When I replaced mine, I did the IC pump relay along with it. It is located behind the passenger seat, inside the box.
Did you bleed the system after the install?
When all else fails, bring it to the dealer!
__________________
Ciao...Dino
Aston Martin V8 Vantage
SL55 AMG... delimited & 569hp/575ft lb tq
Ferrari F40 (sold)
Ferrari 348 Challenge... Tuned to 350 hp
Ferrari Testarossa(sold)
Ferrari Mondial t
87 March/Cosworth Indycar
Ducati 916
BMW M3... tuned to 370 hp & delimited
G500 (4sale)
Mini Cooper S... tuned to 185 hp
www.VelocePerformance.com
IngenereAMG is online now   Reply With Quote
Old 07-10-2009, 04:08 AM   #20
Drives: All of them
def start with the known bad wich is the outside temp sensor. im not saying its impossible but i have seen crazier things. start with the missing outside temp sensor and report your findings
Old 07-10-2009, 02:48 PM   #21
Drives: cls 55 amg
i'm now waiting for the outside temp sensor and the coolant pump relay both here for monday ....how should the system be bled ?...i think theres a procejure but don't know it ?...thanks
Old 07-10-2009, 09:07 PM   #22
Drives: All of them
if the pump is turning on the relay is probably doing its job. but its good to replace just because whenever you do a pump. typicly to bleed the system just fill it up. warm it up and add coolant as it sucks it down. usually they dont get air pockets in the sytem. turn on your heater too. drive it and check it and top it off. the only the 65s have a seperate cooling system for the innercoolers that need to be bled with a special set up that pump the coolant through the system and pushes the air out at the same time
Old 07-11-2009, 04:49 PM   #23
Drives: cls 55 amg
ok i'm going to get the relay moday along with the outside air temp sensor and going on what you say there's no air in the system ...i'll put both those on and report back ...have a good weekend ..
Old 07-13-2009, 03:38 PM   #24
Drives: cls 55 amg
It works ....I changed both today and it works it was the outside air temp sensor believe it or not they must run the ecu from that one and not the block temp ?...wierd but true..happy to have my power back i need some new back tyres now.......thanks all
Old 07-20-2009, 05:28 PM   #25
Drives: 2006 CLS55 AMG
Send a message via AIM to Kenny Pollock
Wow, having the same issue, hopefully I can fix it- my outside temp is reading 90 degrees, which is about right.
Kenny Pollock is offline   Reply With Quote
Tags
55, amg, benz, c32, charge, cls, cls55, cooler, driving, exchanger, heat, intake, loss, mercedes, power, pump, setup, wiring
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
