Go Back   MBWorld.org Forums > Mercedes-Benz SUVs, Trucks, Vans, Diesels, Other > Diesel Forum
Thread Tools Search this Thread Rate Thread Display Modes
Old 06-11-2008, 03:19 AM   #1
Why does my 1980 300SD start in 2nd Gear? No, it's not supposed to.
My 1980 MBZ 300SD starts in 2nd gear and WILL NOT kick down in to 1st gear, although all other kickdown functions are normal. In other words, something is preventing the trans from its normal starting point (first gear) and making this a 3 speed tranny, not a 4 speed. I do notice that the tranny seems overfilled, could that be a cause? All other aspects of transmission operation are normal. Car runs perfectly (has ony 134k miles).
All replies will be appreciated.
Thanks,
Norm
gtl diesel is offline   Reply With Quote
Sponsored Links
To remove this ad, register today or login if you already are registered!
Old 06-11-2008, 04:20 AM   #2
Send a message via AIM to Untertürkheim
Are you sure that it is a 4-speed transmission in the car i.e. have you been able to use all 4 gears at some point? It is possible that the transmission was replaced with the 3 speed from the 450 engine model.
Untertürkheim is offline   Reply With Quote
Old 06-11-2008, 03:50 PM   #3
All of MB's post 60's Diesels came with a 4-speed.
Overfilling will cause foaming and valve body problems.
240D 3.0T is offline   Reply With Quote
Old 06-11-2008, 04:48 PM   #4
[quote=240D 3.0T;2877434]All of MB's post 60's Diesels came with a 4-speed. QUOTE]
I know the car came with a 4-speed, but is it possible someone replaced it with the 3-speed from the M117 model?
Old 06-12-2008, 02:24 AM   #5
[quote=Untertürkheim;2877649]
OK, thanks for the replies. This car still has the original transmission 722-120. Verified. It is a 4 speed designed to start in 1st. I drained and readjusted the fluid level and it made no difference at all. My suspicion is that there is either a clog or a broken element (piston? spring?) inside the valve body. Any tranny guys out there care to comment? Anyone know where I can get a diagram or a tech book on this transmission.
Thanks.Norm
Old 06-27-2008, 06:15 PM   #6
So the four-speeds in W123 and all W124 until about 1990 were designed to start in 2nd.
You're saying the S-class got this feature 10 years earlier?
__________________
Kent Christensen
Albuquerque
'07 GL320CDI, '06 E320CDI
lkchris is offline   Reply With Quote
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
