Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > E-Class (W124)
Thread Tools Search this Thread Rate Thread Display Modes
Old 11-08-2008, 11:41 PM   #1
m103-w124's Avatar
SRS won't go off
My SRS light comes on and stays on when I apply the brake. I don't see any relationship between these two systems. If I start the engine without pressing the brake pedal, light does not come on. As soon as I step on the brake, it comes on..Any suggestions??
FGG
__________________
m103-w124 is offline   Reply With Quote
Sponsored Links
To remove this ad, register today or login if you already are registered!
Old 11-09-2008, 12:00 AM   #2
ohlord's Avatar
Try
to start it without your seat belt on and step on the brake pedal.If the lamp does not trigger something has gone amiss in the crash detect system.Could be a bad sensor or just a bad brake switch,whatever it is your SRS is not active.So if replacing the brake switch or trying to adjust it does not fix the issue you need to have it diagnosed.Hate to lose you as a member on the forum
__________________
"The Edge... there is no honest way to explain it because the only people who really know where it is are the ones who have gone over."
ohlord
ohlord is offline   Reply With Quote
Old 11-09-2008, 04:13 PM   #3
STLe320's Avatar
My SRS light has been on for 2 years, all of the time.... My mechanic cannot diagnose what it is, so I said screw it.
__________________
Speed Limits are Overrated
STLe320 is offline   Reply With Quote
Old 11-09-2008, 04:37 PM   #4
careful don't have that stupid airbag go off in your face while your driving down i80 doing 75! well my front flex disc broke and hit the SRS sensor that is right under the center console when the stupid thing went off I had no idea what the hell happened I pulled over and got out of my car totally disoriented and confused.
__________________
1969 230 70k Miles 2nd Owner, 1980 300SD 200k?, 1982 300SD268K, 1986 300E 165k, 1987 Jaguar XJ6 Vanden Plus 115k, 1991 Jaguar XJ6 Soverign 170k, 1971 GMC 1500 (52k Original Miles) 2nd Owner, 2001 GMC Safari 150k, 1996 Dodge Neon 90k to many cars !!!
pmally is offline   Reply With Quote
Old 11-09-2008, 05:13 PM   #5
m103-w124's Avatar
Is there a way for me to check for "error codes" , blinking LED under the hood, showing what could be causing this stupid SRS light to come on? I mean I'd like to diagnose it myself before taking it to Mr. Rip Off. This car has been working perfectly for a couple of years (155k miles), red SRS light on the dashboard is just driving me crazy! Electrical diagram does not show any relationship between brake circuit and SRS circuit, unless something screwy is happening.
FGG
__________________
Old 11-09-2008, 06:15 PM   #6
just do what i did,take out the instrument cluster and remove the bulb
__________________
Old 11-09-2008, 11:01 PM   #7
I had the same issue. Turned out it was a switch, contact ring, in the steering wheel. When I applied the brakes it gave just enough inertia to turn the light on.
Odd but true.
__________________
ACD
NSX-T
300CE Mercedes, CL500 Mercedes...
Harley Deuce, All Black-black, totaly black.
SpiderAce is offline   Reply With Quote
Old 11-10-2008, 09:28 PM   #8
m103-w124's Avatar
This is weird... I found out the one of my brake lights was burn out. After replacing it...SRS light went out!!! Thanks for all your ideas.
__________________
Old 11-11-2008, 09:26 PM   #9
vanwiek's Avatar
Send a message via AIM to vanwiek Send a message via Yahoo to vanwiek
I'd bet you money that your SRS and bulb out warning indicators are switched.
__________________
'94 E320 with 184,000 miles.
Mods: TomTom GPS in place of ash tray, Memory seat, DEI 545T Auto lamps, DEI 530T Auto Up/Down Windows, DEI Remote Start, Motorola Bluetooth® Car Kit, Built in phone charger using factory phone wiring, RainTracker Rain sensing wiper, Keyless Entry, Ambient lighting of center storage compartment. Soon: factory heated seats, REST
Mercedes-Benz is my addiction of choice.
vanwiek is offline   Reply With Quote
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
