Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > E-Class (W124)
Welcome to MBWorld.org!
Welcome to MBWorld,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 08-13-2009, 01:07 PM   #1
Drives: German Taxi (1987 300E)
Send a message via AIM to fernan_b Send a message via Yahoo to fernan_b
Car not starting in Park (87 300E)
Does anyone else have this problem? I just replaced the battery and the OVP relay (actually, the OVP relay was replaced first, and the battery was jumped after that--could that be a problem?), but now, the car refuses to start in park in the morning. I have to move it to neutral to start. Has anyone had this problem? After starting it in neutral the first time, it is able to start in park. To remove this ad, register today or login if you already are registered!
__________________
RIP, Mary Magdalene!
fernan_b is offline   Reply With Quote
Old 08-13-2009, 04:41 PM   #2
Drives: 1986 300E Benz 1991 300te 4matic
Jumped meaning you gave it a jump start? Mercedes never ever get jumped. If you need to jumpit swap batterys start car swap back. I have not had that problem but if you did jump start it the ovp is probably bad. Good to have 2
epowers777 is offline   Reply With Quote
Old 08-14-2009, 07:51 PM   #3
PeterGunz's Avatar
Drives: 1988 300CE Coupe
Interesting, I have an 88 300CE and have jumped it and used a fast start charger with no issues. My car stopped starting in park and I replaced the neutral safety switch... No problems with starting in park since.
__________________
1988 300CE Coupe - Anthracite Grey Metallic
PeterGunz is offline   Reply With Quote
Old 08-16-2009, 08:17 PM   #4
Peter, where is the neutral safety switch located? Was it an easy switch, or did you have to take it in to have it done?
__________________
Old 08-16-2009, 08:51 PM   #5
PeterGunz's Avatar
Brought the switch online, was cheaper, I was having a lot of other work done - brakes, drilled rotors, shocks, so I had the mechanic do it at that time. I believe it is on the driver's side of the transmission.
__________________
Old 08-18-2009, 01:15 AM   #6
Drives: 1995 E420
Its the neutral safety switch like state above, I just had to have mine replaced as well.
geoshu is offline   Reply With Quote
Tags
300ce, 300e, 91, car, jump, jumped, mercedes, neutral, ovp, problem, relay, safety, starting, switch, top
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
