| Home | Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Vendor Directory |
| E-Class (W124) 1984-1995: E 260, E 300, E 320, E 420, E 500 (Includes CE, T, TD models) |
| Welcome to MBWorld.org! |
Welcome to MBWorld, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today! |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | |||
Drives: 1993 400E, 1992 300TE 4Matic , 2000 E320 Wagon 4Matic
PLEASE HELP ! W124 92' Wagon 4 Matic trouble
#2 |
Drives: 1986 300E Benz 1991 300te 4matic
Have u replaced ur ovp relay what year is it?
#3 |
Drives: 1990 300ce supercharged and intercooled
What you need to repl. is the pressure dampening sphere on the rear valve block. What happens is that the fluid pressure builds up and the system does it's self tests. When the self test gets done the pressure drops below the specified value and the system shuts down and the light comes on. Then the pressure builds back up and it starts over again. If you rev up the engine after start up then this should not happen as the pump is able to provide enough pressure to get through this process. I would not recommend not fixing this, it is just a good way of diagnosing the problem. You can also put a pressure gauge on and watch the pressure go up and down. The pressure dampener is pretty easy to repl. and I do not remember it costs all that much. Maybe 100-150 bucks but I think it was less.
good luck.. |
#4 |
You wouldn't have the part no. or schematics by any chance ?
Thank you for the reply, what gets me is that the 4matic light gives me one flash all the time I guess on self diagnostics which means no trouble detected.
I will check it out for sure Thank you again |
#5 |
Its a 92' I think the OVP relay is fine since I have no check engine light on or no hard idling when cold start
#6 |
Where is is the pressure dampening sphere exactly located pls ?
#7 |
It is on the right rear under the car. Just in front of the wheel. There is a plastic cover that has to be unbolted. The 4-matic hydraulic valve block is there. All the solenoids and pressure sensor and the sphere is there. It is kind of hard to break loose though. Good luck
#8 |
Looks like its getting better on its own
Could all the trouble be caused because the 4matic was turned off for a very long time. Today I'm was driving the car and I'm was getting less off the quick 4matic light quick flash. It would go stop until I would stop at traffic lights, take off so it would give me like 4 flashes about 3-5 secons apart, then 3, 2, 1 and no more flashes so I'm hoping it will stay off for good now. Did anyone had the same experience. Is this a way for the computer to reprogram it self or any suggestions please ?
#9 |
You can set codes from the system being off. But you still need the pressure dampening sphere. All that is happening is that as you rev up the engine the pump is able to provide enough flow for the system to remain pressurized. When you come to a stop and take off the center diff is activated and that causes the pressure to drop again while at low engine rpm.
| Tags |
| 1992, 400e, 4matic, 92, benz, computer, dash, e300, flashes, light, mercedes, model, ovp, problems, relay, stays, w124 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
