Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > E-Class (W124)
Welcome to MBWorld.org!
Welcome to MBWorld,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 11-04-2009, 08:45 AM   #1
Drives: 91 300 te
92 124 4matic: could centrifugal governor cause slip in all gears?
92 124 4matic:
This just started slipping in all gears, It will firmly engage into all gears and accelerate if done gently, but more throttle will induce slippage. Trans shop said pressure are good and rebuild is required. I don't buy this because the trans was a complete reman unit 30k ago.
I have literally been searching everywhere for a week but it seems the transmissions are some kind of black art. Since this is NOT a diesel, no one has had my same problem or has not posted a repair other that either scrapping the car or rebuilding the trans.
I have gleaned from a trans shop that sticking valves in the valve body can be a cause hydraulic flow restrictions so I plan to clean that out, but along the way read a description of the centrifugal governor and it sounds like a possible factor.
Comments?
To remove this ad, register today or login if you already are registered!
scirocco75 is offline   Reply With Quote
Tags
4matic, 92
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
