E-Class (W211) 2003-2009
Old 06-10-2015, 12:33 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Exterior Guides
Print Wikipost
Question: My Xenon headlights are not as bright
Old 08-09-2008, 06:57 AM
Tom T's Avatar
2017 E300
Hello All,
It seems to me that my headlight are getting dimmer and dimmer every day. When I bought the car back in '04, these Xenon lights were amazing. They were the brightest lights I have ever seen. But now,*they are almost as same as regular headlights. I don't know that they can go dim. I thought bulbs are either work or don't work.
Old 08-09-2008, 08:11 AM
raymond g-'s Avatar
99 E320
no, in the case of HID bulbs, they age....and color shift. if you replace them
(be sure to buy in pairs and matching lot numbers), you'll be back to new look
and Kelvin temperature. if you replace with 5000 degree Kelvin, model 81522+
you'll be even more impressed. OEM 4300 degree bulb should run you approx
$80/pair, whereas the 81522+ will be about $150/pair.
Old 08-09-2008, 07:34 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
Is this the part number you were referring to?
http://www.pqlighting.com/viewproduc...qrySTARTROW=41
Where can I find that part?
I also agree with the above post - as these bulbs get older they are not as bright and turn purple. This is especially apparent with some older Acuras with xenon DRLs that have been run every day for many years.
If you replace one of the bulbs the difference will be even more apparent as they will be very different in color (from experience).
Old 08-09-2008, 09:58 PM
raymond g-'s Avatar
99 E320
good one. had me going for a few seconds wondering what i bungled.
sorry, poor eye/hand coordination. it should have been 85122+ not 81522+
Old 08-09-2008, 10:41 PM
starbrite's Avatar
2004 E320
Wow ! What a difference transposing just 2 numbers can make.
Old 12-30-2010, 12:12 AM
Tom T's Avatar
2017 E300
I finally got around and replaced the bulbs with Phillip 85122+, very disappointing. They light brightness is about the same, but now they shine a bit yellow on the road. I'm thinking about putting the original one back in.
Old 12-30-2010, 03:26 AM
Dexion's Avatar
03 E320, 03 Lexus RX300
Your headlamp may need restoration, if it becomes foggy aka oxidized it will block a good % of light.
Old 12-30-2010, 04:00 AM
AP-123's Avatar
E550
What is the approximate lifespan of the lights? Or when should replacement be considered?
Old 12-30-2010, 11:55 AM
starbrite's Avatar
2004 E320
Gee Tom...it only took 2 years !! Remember, new Xenon bulbs will look yellow for the first 100 hrs or so.
Old 12-30-2010, 12:04 PM
Tom T's Avatar
2017 E300
Hehe, what can I say, I am a cheap a$$. They really do look yellow for the first 100 hrs? even with these 85122+?
My lenses aren't that perfect. I used the Plastic X cleaning them every now and then. No, I am shopping for a good lens restoration products.
Any suggestion?
Thx
Old 12-30-2010, 01:26 PM
starbrite's Avatar
2004 E320
Any suggestion?
Thx
Yes they do....see attached DTB bulletin from MB.
My '04 lenses are still clear as a bell so I havn't researched how to "clean" them up.
Edit: BTW, this is the best price I could find on this bulb : Click Here
Old 12-30-2010, 06:16 PM
djrabbi's Avatar
CLS550 4Matic, C43, E350, ML350
so for my w211 85122+ will be good? only asking cause I smoked my headlights a bit so i lost a bit of visiblity
Quick Reply: Question: My Xenon headlights are not as bright
