| Home | Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Vendor Directory |
| Welcome to MBWorld.org! |
Welcome to MBWorld, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today! |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#51 | ||||
Drives: 2004 E500 Sport
#52 |
Drives: e320 cdi
please can any one help me,i have an e320cdi,i keep getting these bad knocking noise in the both front suspensions,ive have changed the obvious ball joint ect but the knocking is still there,its only happens under 40mph ,its really annoying,i have taken the car into mb even they cant seem to find whats wrong with it,please sum1 help me
#53 | |
Drives: 03 E500 and Corvette
Quote:
Bushings in the swing arms Loose strut Defective strut
#54 |
Drives: e320 cdi
i dont know ,even mb admit to the problem they can hear the knocking noise but cant find what the problem is,they suggest that i change all the ball joints arm bushes ect which is gone cost me over £1000....what else do u think it might be thnx for ur reply
#55 |
Drives: 2004 E500 4 Matic & 1999 230SLK
noise front end
Yesterday I installed 2 motor mounts and 1 transmission mount Iam very happy to inform that the clicking/ rattling noise at slow speeds from front end is gone. Dont get ripped off from the mb dealer to get this job done it took less than 2 hours to do . I got quoted 14 hrs. labour. Hope you get your problem sorted out. PS I also replaced the ball joints first. Regards Mike
#56 |
Drives: e320 cdi
to be honest its not a rattle im hearing,its like a severe knocking sound,actually yeah u could be right i also do get a rattling sound like as if u got a few stones in a plastic bucket and wen u shake the bucket with the stones in there that kinda sound too,lol hope ive explained it good enough thnx ru sure its more likely the two rubbers and trannsmission rubber
#57 |
#58 |
Drives: e320 cdi
its defo not the wheel bearings,its every time i go over a little bump or crack in the road,its defo at 40mph and below
#59 | |
Quote:
What you described earlier is exactly what I am getting for a year now - "sound like as if u got a few stones in a plastic bucket". Accept I don’t get it on speed bumps… Replaced a lot of stuff by now (not for fun, but because those needed to be replaced). Going for Link ball joints and bushings now. Motor mounts after that. And if all this does not help – for a new E class!
#60 |
Drives: e320 cdi
hello rostov ur right im having the same problems u was having and it pissing me off,its been like this over a year and know one at mercedes seems to know what the problem is,they want me to change everything and still not garnantee it will fix the problem and by the time they finish i will be bankrupt lol.its a shame the warranty has run out otherwise i would have worked them lol,so did u do anthing to your car to fix the problem or is the problem still there?thnx
#61 |
For some strange reason this noise has disappeared after tire change and alignment. But 1000 miles later it came back even stronger. After last check, I am going to replace those parts that I had specified in my previous post with picture, and will see what happens.
#62 | |
Quote:
#63 |
Drives: e320 cdi
really i will try and see if that works bigsmile
#64 |
Yes did it myself.This noise was really anoying. Iam so happy that its fixed now.The left motor mount was totally worn out. The aluminium housing was totally corroded. The car has approx 88000 miles. Thanks for all the info. Regards Mike
#65 | |
Quote:
It would be great if you could write up how you did it and a few pics might help others doing the same work. vettdvr
#66 |
Drives: e320 cdi
the thing that has pissed me off is my care broke down last 26th wednesday,with starter motor problems,got AA recovery ppl to recover my car to mercedes on a recovery truck,they have charged me nearly £800 for a new starter motor and they havge also mentioned that the AA recovery ppl have damaged my front suspension too,they show me the extent of the damage that was visible and im not happy,i have made a claim against the AA.any one here that can advise me about this situation?
#67 |
Remove plastic covers from under engine. Use a floor jack with a block of wood place under oil pan, Remove bolts from both engine mounts, remove air filter housing. Jack up engine carefully just enough so mounts are loose then slide out the mounts slide in new mounts then tighten everything back up then you are done.
#68 | |
Quote:
#69 |
The motor mounts that I replaced were from a 2004 E500 4 matic ( V8)
#70 |
Drives: e320 cdi
does any one know why my w211 blows THICK black smoke when i put my foot down,and every time i do that all i see is tons of black smoke..... pls HELP
#71 | |
Quote:
Do you have any computer codes. O2 sensors failing putting the system in open loop MAF failure Injector sticking Fuel regulator Just to list a few. To answer for sure you will need more data. Fuel mileage dropping is a good indicator of fuel rich |
#72 |
Drives: e320 cdi
thnx for reply,ive had the e320 cdi go thru a diagnostics and mercedes told me its ok and its normal for the e320 cdi to give out blck smoke when u put ur foot down,but ive heard different by other ppl that it shouldnt,someone mentioned its could be the egr valve,but the car drives ok,the power is there.....really dont know wat to do
#73 | |
Quote:
![]() One sure way fuel rich will show up is in increase fuel usage. This is normally black smoke. The engine does go rich under full acceleration to give it the power. So it is possible what you see is normal. Excessive fuel can also fowl plugs and dilute oil, but my guess is you have none of this and it "might" be normal for you engine. |
#74 |
Guys,
Is there any fluid in those engine mounts??? |
#75 |
| Tags |
| 300d, air, airmatic, ball, bracket, cdi, compressor, e320, filter, front, joint, loose, lower, mercedes, mount, noise, problems, rattle, weird |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
