| Home | Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Vendor Directory |
| Off Topic Use this forum to discuss non-Mercedes related items or anything that doesn't belong in the above forums. |
| Welcome to MBWorld.org! |
Welcome to MBWorld, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today! |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | |||
Super Moderator
Drives: 2011 E65 Black
Dishwasher woes..won't drain
__________________
MBWORLD Special - OEM Parts Wholesale. Inquire within. Price sheet now at www.keepandshare.com/doc/view.php?id=631973&da=y That's from March 2008, so is somewhat out of date. |
#2 |
Drives: 2003 CLK500
plunge the hole
#3 |
Super Moderator
__________________
#4 |
Drives: 2003 CLK500
keep in mind i am not a plumber or the maytag repair man.
#5 |
Super Moderator
Drives: K Car
I'm assuming that the pump is working, but the waste water just isn't flowing? I would remove the tube to make sure it isn't clogged up. You can try to remove the part from under the sink first, and if that doesn't help, get under the dishwasher and remove the other end. Some models come with a check valve as part of the hose, and some have the check valve as part of the unit.
If you do get it fixed, you might want to think about installing an air gap. It is code down here. At the very least, you should run the hose up as high as you can and then down to the drain. That will prevent a sink back up from flowing back to your dishwasher. |
#6 |
Drives: Fiscal Neo Con Express
my first thought was the pump but what rev said sounds right as well.
might be time to start rinsing off the leftover spaghetti before washing
__________________
--------------------------------------------------- "Liberalism is a mental disorder" "America has shown arrogance and been dismissive, even derisive." President Barak Obama "The trouble with our liberal friends is not that they're ignorant: It's just that they know so much that isn't so." - Ronald Reagan --------------------------------------------------- |
#7 |
Super Moderator
Get under it?? It's built in! I'd have to cut an access panel from the basement.
__________________
#8 |
Super Moderator
Drives: MPG+ ROLFCOPTER
Pull it out, disconnect and then get under it. There should be no need to cut into anything.
#9 | |
Drives: 04 C4S Cabrio
Based on your prev threads Brenton, I say sell the house and buy a new one with a washer that works
![]() +1 on AM's post-there should be two threaded bolts that keep it from tilting forward-remove those, and (carefully) begin to inch out from the build in (careful not to tweak the water supply hose if copper, ect)-my guess is the pump failed-I just went shopping last night at Warner for a new set up myself...Magic Chef just isnt going it for me anymore ![]() GL-let us know what happens!
__________________
http://www.mbworld.org/forums/c63-am...ml#post3641908 Quote:
Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, Torque is how far you take the wall with you. |
#10 |
Exactly. There should be 2 screws on the top that tack it into the bottom of the counter, and then just some spacer material on the sides between it and the cabinets on the side. Once you take the bottom panel off you may want to turn the feet screws a few turns to lower it. It will be easier to slide out....then pull it out slow, make sure the is enough play in the electrical connections.
__________________
#11 |
Drives: 04 Mercedes Benz C230K
Yupp, sounds like you have a clogged drain hose.
__________________
![]() 19x8.5F/19x9.5R BBS LM- Toyo T1R Tires 235/35/19F 265/30/19R -H&R Coilovers-Lensolo Camber kit- |
#12 |
Super Moderator
How can you tell if the pump failed? I was thinking that each new cycle brought in fresh new water, therefore some amount of water is being drained off, else the residual water in the tub would be more and more. Am I wrong?
__________________
#13 |
Drives: 09 Camry Hybrid
We had this problem as well a few months back, the culprit was the disposal, but you dont have that, so i am not sure.
#14 |
Hurricane Smasher
Drives: M6 Coupe
Dude I thought you were married?
__________________
![]() 08 IS-F | 04 360 Modena | 07 LX470 | 08 LS600 | 07 M6 |
#15 |
Drives: '03 C32
Are you suggesting that he forget the dishwasher and have wifey do the dishes by hand or that wifey intentionally broke the dishwasher so she could get a new $2,000 Bosch?!
__________________
#16 | ||
Quote:
__________________
#17 |
Drives: 2008 E350 4 Matic
Here are step by step instructions-
1. Get in your car 2. Go to your local/favorite appliance dealer 3. Select your favorite model 4. Stick your hand in your back pocket and retrieve wallet 5. Pay the clerk 6. Wait for delivery and (optional) If you spend an additional $400 to get a "green" model dishwasher, fill out the application so that Obama can send you $12.50 (some of which is our money anyway) for turning in your inefficient old model. I'd be careful leaving it like it is. Someone here might report you to the Green Czar and you might be arrested for wasting water.
__________________
The gene pool could use a little chlorine. Hypocrisy can afford to be magnificent in its promises; for never intending to go beyond promises; it costs nothing. -Edmund Burke |
#18 |
Super Moderator
Well I offset our water consumption by urinating off the side of the deck.
__________________
#19 | |
Drives: '03 C32
Quote:
I enjoy your posts, my friend. Don't be a stranger.
__________________
#20 |
Super Moderator
Drives: K Car
Some dishwashers (most actually) have an access panel at the bottom (under the door) that you can remove to access the bottom side of the dishwasher. You can normally service the water connection and the drain connection through here. You can also normally adjust the front two legs this way. There should be no need to even have to remove the dishwasher from it's cubby.
#21 | |
Super Moderator
Quote:
__________________
#22 |
Super Moderator
Drives: K Car
Depending on the dishwasher, if you know when in the cycle that the dishwasher is supposed to drain, you might be able to hear the pump turn on. Of course, running the pump with a clog for very long will not be too good for the pump. If you can't hear it, then all you can really do is check the hose for a clog. If there is no clog, then you have a bigger problem.
#23 |
Super Moderator
Drives: K Car
There may be a couple of screws you have to remove to open the panel.
#24 |
Drives: 2003 CLK500
so you are asking "what do you do when the dishwasher doesnt work?"
i say smack her. |
#25 |
Drives: 2007 CLS63 AMG; Ford F-150 ; BMW K1200R
While we're on this topic. You know why wedding dresses are white right? ..... Cause the dishwasher should match the refrigerator.
__________________
07 CLS63 AMG
| Tags |
| 2001, chef, directions, dishwasher, drain, fix, ge, magic, plunge, profile, pumping, sink, step, tie, water, wont |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
