Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > S-Class (W126)
S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Welcome to MBWorld.org!
Welcome to MBWorld,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 10-08-2007, 06:18 PM   #1
Bigraven's Avatar
Drives: 1986 Mercedes 420SEL; 1987 Mercedes 300TD; 2000 Mercedes E320
Send a message via AIM to Bigraven
Exclamation Uncontrollable Idle - 420SEL
Hello everyone,
I've recently encountered a problem with my '86 420SEL. When I get it started, it goes into a frenzy of an idle. It tops at 2500rpm. I've replaced the Idle control valve and switched out the fuel pump relay. Yet, the problem still continues. I'm in the process of taking out the idle control unit, but first I have to find one in my local salvage yard. A few question that have risen in my search for the mysterious idle problem.
1.) Which cars have the same Idle control unit as my '86 420SEL and where is the unit located on those other cars? I know that the unit is located in the passenger side footwell.
2.) What other problems, besides the Idle control unit, may be causing this very high idle?
If any help, the car has 206,000+ miles on it. Any help would be much appreciated.
Regards,
Allen
To remove this ad, register today or login if you already are registered!
Bigraven is offline   Reply With Quote
Old 10-12-2007, 07:25 AM   #2
Send a message via AIM to Untertürkheim
When is the last time you changed your fuel filter?
Untertürkheim is offline   Reply With Quote
Old 10-12-2007, 05:13 PM   #3
Drives: 1991 560SEC Teal 1989 420SEL Ice Blue 1984 500SEC White
Check your OVP relay. It has a red 10 amp fuse on it. Sometimes they blow, but usually the over voltage protection relay goes bad.
Bruce
BENZITCH is offline   Reply With Quote
Old 10-13-2007, 02:16 PM   #4
Bigraven's Avatar
Quote:
The original owner said he replaced the fuel filter about a year before I purchased it as a regular maintenance that he did for the car. From what I can tell, the fuel filter, pump, and relay have all been replaced and are in excellent working order. Car was purchased for $300 on August 15, 2007. Everything is PERFECT except for this high idle.
@BENZITCH
From various other forums that I've asked this same question, nothing leads to the OVP relay. From searching this forum and many others, some sort of dash light will be lit when the car is running (correct me if i'm wrong). There is no light on the dash, so i'm doubting that it could be the ovp relay.
Edit: I checked the fuse in the OVP relay. It wasn't blown out or shown any signs of wear and tear over the years. I've also replaced the fuse in it as well. Still no luck.
Old 10-15-2007, 01:44 PM   #5
Try removing the OVP and see if the idle changes. If the idle remains the same than I would think it is still the OVP.
Have a friend with a similar car? Swap his out and see.
As far as the lights do you have an air bag and abs?
Old 10-15-2007, 10:22 PM   #6
Bigraven's Avatar
I'll see if I can get an OVP from a buddy of mine and test it out, who knows, it just might help it. I do have an air bag and abs.
Old 10-26-2007, 12:54 PM   #7
Drives: 86' 420sel & 91' 300E
Have you resolved this issue? I'm having the same problem with my 86' 420 SEL & would appreciate the benefit of your response......
TerryJ
tbjcc001 is offline   Reply With Quote
Old 10-28-2007, 04:14 PM   #8
Bigraven's Avatar
Quote:
TerryJ
Hi Terry,
I've accumulated a collection of 4 idle speed controls, 3 idle control valves and 3 ovp relays; none of which seem to be my problem. I've also replaced the following: ignition control module, cap and rotor, spark plug wires, spark plugs, fuel pump relay, fuel pump, vacuum hoses, and a new ABS unit (ABS brakes weren't functioning as they were supposed to). I'm getting so many parts from the junkyard I could build an entirely new engine. Although, I have yet to replace the throttle position switch. That is my next step.
None of the replacement parts seem to have effected the idle of my benz. At start it goes for a straight shoot to 4000rpm and keeps going. If your idle isn't as erratic as my idle is, then possible problems with your idle are in descending order with most common problem first:
1. Idle control valve (piston inside gets stuck, try cleaning in a tub full of carb cleaner and leave overnight)
2. Idle speed control (little box inside the passenger footwell)
3. OVP relay (little silver box with a red fuse inside with a "10" on it)
4. Throttle position switch
5. Worn injectors
6. Broken/brittle/missing/disconnected vaccum hose(s)
Sorry for my lack of information on this. I've been at this for quite some time now with minimal success. I have, however, succeeded in replacing a majority of interior blemishes through my scavenging across junkyards and finding parts for my '87 diesel wagon.
Old 01-13-2008, 09:44 PM   #9
Drives: 420sel 500sel
Has any one removed the cruise control and throttle linkage rods? It may be that they are reversed at the control unit for the cc. I've experienced a similar start and straight to very high rpms problem.
novone is offline   Reply With Quote
Old 10-21-2009, 07:55 PM   #10
Drives: 1986 420 SEL
I have the same problem with my 1986 420 sel. did u fix it? Can u tell me how?
digital10 is offline   Reply With Quote
Old 11-15-2009, 11:40 PM   #11
Drives: 380sl
Gentlemen,
Test your COLD START VALVE! the described condition for RPM variation is normally caused by an open position stuck cold start valve which enables a steady stream of fuel to be injected into the intake manifold. Suitable remedies are: i) discontinue electrical source; ii) discontinue fule delivery and see if variation still occur.
Best,
Vic
victan is offline   Reply With Quote
Tags
1987, 420, 420sel, 420selovp, control, fuel, high, idle, location, mercedes, module, pump, relay, sel, w126
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
