| Home | Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Vendor Directory |
| S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC |
| Welcome to MBWorld.org! |
Welcome to MBWorld, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today! |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | |||
Drives: 1992 400se
gauges flashing 400 se
#2 |
Drives: 92 500sel/01 320e wag
You could do either, but you must remember there is the odometer issue
http://mbcluster.com/ |
#3 |
Drives: 1994 e320 coupe sportline
ever remedied?
was this problem ever fixed in the later production years?
did this problem exist from the beginning of w 140 production until the 1999 end of model run. |
#4 |
There were three generations of the cluster, the early ones were replaced with the digital under warranty, and sold at reduced prices post warranty. That ended a while later, the problem all but disapeared, see link.
#5 |
Drives: 1992 400se
If I buy a cluster that has a small chip on the right side of the cluster not the clear glass . Can I use my old cluster the old frame you know the shell that fits in the dash
#6 | |
Drives: 1992 400se
cluster
Quote:
If I buy a used cluster. Can I use my old cluster shell and rebuild my cluster. Is there any special tools to rebuild the cluster . I found one with a small chip on the right side of black plastic.Looks like it got chiped when they removed it. Thank you |
#7 |
I would assume so if it is identical, I think the designs changed slightly. I sent mine to Programma (local) and got it back the next day, all bulbs changed, and the power transistors and capacitors, $350 with 2 or 3 year warranty. Breaking the glass is common even with the pulling hooks, i got mine out thru the A/C vent
http://v12uberalles.com/instrument_cluster_removal.htm |
| Tags |
| 1992, 400, 400se, benz, cluster, mercedes, se |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
