| Home | Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Vendor Directory |
| S-Class (W220) 1999-2006: S 320 CDI, S 320, S430, S 500, S 600 |
| Welcome to MBWorld.org! |
Welcome to MBWorld, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today! |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | |||
Leaking Antifreeze
#2 | |
Drives: MB
Quote:
#3 |
Location: Alabama gulf coast, formerly Charlottesville, Virginia
Drives: 2004 W220 (S430), 2001 R129 (SL500 Sport)
Now I'm confused. Are you losing coolant or engine oil? If you're losing coolant and it's not visibly leaking from somewhere or evaporating because of a leak in the pressure system, then it must be leaking into the engine. This will happen if you have a bad head gasket that allows coolant into the oil passages. Has he checked the dipstick for a white, frothy looking residue? If it's there, you got coolant in the lubricant. That's bad. If not, is the car running rough when it's cold? Heat would swell everything up and minimize coolant in the combustion process. That's bad. All that's speculation. If it's not leaking outside the engine, it's leaking inside the engine. QED. Good luck.
If you're losing lubricant, why would the dealer pressure check the cooling system?
__________________
"Don't pick a fight with an old man. If he is too old to fight, he'll just kill you."--John Steinbeck |
#4 |
He was down 2 quarts of antifreeze, not oil. The dealer looked at the dipstick a few times, probabally looking for what you described. There is no white smoke coming out the exhaust. I was hoping someone out there had a similar problem, sorry, but it would help figure this out.
#5 | |
Drives: MB
Quote:
__________________
๛╬๛ M▲XmIlIøN'_ §_▲๛╬๛ ![]() 06 GSXR 1000 (190 RWHP ) 07 JEEP SRT8 ( MODDED N/A) 12.77@106.24 / 1.802 60' / 0-60 4.0 FLAT Last edited by m4xm1l10n; 12-23-2008 at 02:45 AM. |
#6 |
i had the same problem on my 02 S500, leaked alot of antifreeze! problem solved after i used a heavy duty antifreeze. I guess the light (yellowish) antifreeze was to light.
#7 |
Do you have any idea where the antifreeze went? Also, what BRAND NAME of antifreeze did you use?
#8 |
Ah. As most of us are aware, MB is VERY particular about fluids for the W220. There are only one or two brands and types within brands of coolant that are recommended. I wanted to top up my catch tank when I bought mine and it took a lengthy search to find the aftermarket coolant specified (my dealership is an hour away), and it cost $17 or so for a gallon. If your friend is using the OTC stuff sold at Wal-Mart or AutoZone, that may be the problem, but I would have thought the dealership would have questioned him about the coolant he was using. It's still a mystery to me even at that.
__________________
#9 |
i used the heavy duty dark green antifreeze. purchased at pep boys
#10 |
They found the trouble. It was a bad thermostat that caused the top hose to leak. It was a real small leak and it took an overnite pressure test to find it.
| Tags |
| coolant, jeepsrt, losing |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
