DIY: W203 Sedan Headlights Removal
Old 12-28-2006, 05:31 PM
rlee02135's Avatar
2004 C32 ///AMG
I replaced my Bi-Xenons with the Stock healights.
You can use this process to put in Bi-Xenons, Clear Headlights or Depo Projectors into your car.
Lets Start on the Driver's Side
1) Remove the 8mm screw in this hole
2) Remove the 8mm bolt here
3) Jack up the car and remove the wheel
4) Remove the bottom bumper cover by taking out a few push pins and some 8mm screws
5) Remove a few push-pins and 10mm nuts, then push aside the inner fender
6) Remove the T20 Torx screw under where the bumper meets the fender
7) Pull out the bumper-fender clip. You may need a screwdriver to pry it out
8) Remove the 8mm bolt on top of the headlight
9) Remove the 8mm bolt on the left side of the headlight
10) Pull the bumper down a little, and remove the 8mm bolt on the right side of the headlight
11) Unplug the connector from the headlight
rlee02135's Avatar
2004 C32 ///AMG
12) Take off the two T20 Torx screws and put the black piece on the new headlight
13) Place the headlight back in the hole carefully, and plug in the connector
14) Put the 8mm bolt back on top of the headlight
15) Put the 8mm bolt back on the left of the headlight
16) Put the 8mm and the plastic piece that goes with it back on the right side of the headlight
17) Make sure the fender clips on to the bumper
18) Put the bumper-fender clip back in, pushing towards the front of the car
19) Put the T20 Torx screw back into bumper-fender clip
20) Put the 8mm bolt back in here
21) Put the 8mm screw back in the hole
22) Put the wheel back on
Old 12-28-2006, 05:32 PM
rlee02135's Avatar
2004 C32 ///AMG
Result:
Now the Passenger Side
2) Remove this 8mm bolt
7) Pull out the bumper-fender clip. You may need a screwdriver to pry it out.
9) Remove the 8mm bolt on the right side of the headlight
10) Pull the bumper down a little, and remove the 8mm bolt on the left side of the headlight
ramin110 (07-07-2017)
rlee02135's Avatar
2004 C32 ///AMG
15) Put the 8mm bolt back on the right side of the headlight
Final Result:
Old 12-28-2006, 05:51 PM
Saprissa's Avatar
Location: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
ok, cool.
so why would I want to replace my BiX with stock headlights ?
Old 12-28-2006, 06:05 PM
rlee02135's Avatar
2004 C32 ///AMG
Originally Posted by Saprissa
ok, cool.
because BiX is so goddam ugly!
haha j/k man. im parting out and returning the car to stock
Old 12-28-2006, 06:08 PM
SUPR C's Avatar
02 C32, G60 Corrado
Thankyou very much. Are you interested in selling your Bi-xenons?
Old 12-28-2006, 06:15 PM
rlee02135's Avatar
2004 C32 ///AMG
they are already sold
Old 12-28-2006, 06:16 PM
M230K's Avatar
2012 MERCEDES CLS63 AMG
hes planning on leaving the w203 family
Old 12-28-2006, 06:23 PM
Super Moderator Alumni
drexappeal's Avatar
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Thanks for the DIY, rlee. This is going to be a sticky.
drex
Old 12-28-2006, 06:43 PM
SlvrC230SS's Avatar
2006 C230SS & 2009 E350
Thumbs up
Very nice instructions.
Old 12-28-2006, 07:05 PM
Saprissa's Avatar
Thumbs up
perfectO !!
nice job.... DIY with photos in true Saprissa fashion....
it brings a to my eye !
Old 12-28-2006, 07:36 PM
slammedcclass's Avatar
cclass05
looks like ur car wont be able to see any more
Old 01-12-2007, 02:34 PM
EnkeiDynamics's Avatar
02 C230 Coupe
Nice write-up hommie...what are you moving onto next?
Old 01-12-2007, 03:21 PM
NG C-Klasse's Avatar
02' C240 Luxury Model
Very similar to the install of my lights, only I didn't need to remove the wheel. I just turned it full lock towards the opposite side I was working on. The was plenty of room for me. Very cool of you to take pics of the process for those who aren't as mechanically inclined.
Old 01-13-2007, 12:13 AM
rlee02135's Avatar
2004 C32 ///AMG
s/c 330ci
Old 01-21-2007, 05:47 AM
hankeymeal's Avatar
Do I need any specialist help to set the ECU to xenon headlights?I'm using the halogen one right now.I also want to change my headlights.Thanks
Old 01-26-2007, 05:21 PM
Tangerine's Avatar
Is @ Home
Very nice write up. I see that you did the method of not removing the front bumper. I know its not necessary but do you know the extra steps that are needed if I do want to take of the bumper? Good luck on your 3 series.
Old 01-26-2007, 05:23 PM
rlee02135's Avatar
2004 C32 ///AMG
you need your mercedes dealer to set the xenons
i think you just remove the screws on both sides instead of just one, and the bumper will pull right offf
Old 01-26-2007, 06:19 PM
Almost a Member!
bnzct's Avatar
06 C230
Very nice post!!
I like it. Thanks!
Old 01-29-2007, 03:59 PM
sirenebekim's Avatar
this DIY helped me install my bix today in less than three hours.. Thanks rlee
Old 01-29-2007, 06:50 PM
mbarrad's Avatar
2005 C230SS
Did you have to go to the dealer and have them set Xenons=Not Present, or did they turn right on without any dealership efforts?
Old 01-29-2007, 07:27 PM
C24owner's Avatar
'08 E550 4Matic
No need to change anything.
Old 01-29-2007, 07:32 PM
rlee02135's Avatar
2004 C32 ///AMG
it depends...
i had stock halogens, so i had to set the Xenons at the dealer
if you have the frosty xenons, you don't need to set the xenons to present..
Old 01-29-2007, 08:38 PM
step three of your diy is optional...
Quick Reply: DIY: W203 Sedan Headlights Removal
