ESP Problem-- 1st thread
Hello everyone, I am new here. I really like this website.
I own a 2001 C240
Today, I took my car to the shop to have a o2 sensor and a mass air meter installed. When I picked the car up, it was shifting rather hard into the gears during my city travel. However, on the interstate, this problem went away. After I got off the interstate, the problem was gone and it was shifting like normal.
A few seconds later, the warning light saying to take the car to the shop b/c of a ESP malfunction; and the car wouldn't move. THe engine was still running fine, but the car wouldn't go over 4mph.. It was just enough to make it to a parking lot, etc.
I pulled over, put on my flashers, and turned off the car. I started it back up, and all was fine. No light, perfect operation. About every 10 miles the light came back on, but only during city driving.Once I got back to the interstate, it was fine.
My question is, What the hell is wrong with my car? I know esp problems are expensive, and I would really appreciate another opinion than the person I'm paying to fix it. The mechanic said it might be the air mass meter, because the part number was one digit off, and it could have put the computer into limp mode--- but we have no clue how this relates to the esp...
I have stff and found something that mentioned about a wire harness or possible sensor replacement... Any idea how much this was?
Thanks in advance
I own a 2001 C240
Thanks in advance
my car is still at the shop.. waiting sucks
my guy couldn't get me in until a week later when i made the original appointment, so now my car sits in his lot until he can work it in between appointments.... forced under carnel knowledge
still in shop...
THIS SUCKS
am i looking at thousands or hundreds of dollars to fix this?
Also, I changed my cd player recently. Its the alpine model audio 10 mf2199. Its a little bit small, so i used a single din mounting kit to mount it. Could this have thrown off the esp? Maybe a different speed volume interface or something?
THIS SUCKS
Something Slow
i had the same problem
https://mbworld.org/forums/showthread.php?t=121626
i read through your thread and it appears as if it was the electronic control module for the transmission?
Update on my situation, I talked to the mechanic today. He said the BAS switch code came up. I asked him about the wireharness, he said that unless the wire wrap was falling off I dont have a problem. He checked mine out because he knew of the problem, and said it was fine. However, your transmission code makes sense because when I first started the car the thing shifted really hard, it actually threw me back into my seat.
ive also read about recalls that pertain to the specific item, if certain codes are read. I've also read about the same instance, with the accelerator position sensor being the culprit. I have no clue. I dont think my mechanic does either. Should I seek a new mechanic?
ok so i got the car back today, the mechanic said he couldn't find anything wrong. The car did it again, and theres a new code in my obdII scanner--- it says "2036 : No or incorrect CAN message from control unit n47-5 (ESP control module)(p0600)
does anyone have info on what i should do? Replace the ESP control module? Or is it a sensor elsewhere?
update, i think i have found the malfunctioning part according to the error.
I cleaned out the motor bay with compressed air, i might have knocked a wire loose. I will check it in the morning.
However, can anyone confirm that the control unit is the computer in the front with the metal lines running into the top? Theres a black flat storage area that at an up and down placement. Its marked, ESP.
Is this the control module as the code calls for above?
2003 C32
4mph? when the error happens, your car feels like it is surging/jerking forward slightly with no throttle response? ESP warning kicks in and then check engine light?
Your error codes and description closely matches what's on my invoice details. Fault code C1024 - CAN communication system with engine system is faulty.
just happened to me couple days ago - dealer replaced throttle actuator and updated software on ME control unit and TCM.
do you have a sprintbooster plugged in? i took mine out before sending the car in. going to leave it out for a while, car feels significantly better, as if i had a SB plugged in.
FYI, was told the actuator is about $700. labor took a while too - most of the day (no estimate since it's all covered under warranty).
Which move point A to point B.
was it like, not changing the gear (only stay at gear number 1) and rpm range high? i have once after i raced with my friends. i just unplug the battery and wait like 5 minutes (to restart the computer) and i plug in it again. after that no problem. my car even running better now ( i hope ).
still in shop...
THIS SUCKS
THIS SUCKS
well the mechanic that was working on it is going to check out what to do to resolve the error code I supplied him with my obdII scanner bought for 20 bucks on eshame.
i guess its the main control computer, because its going out intermitently, and as time progresses, less and less. I drove it once today for about a half of an hour, and nothing. I drove it in the rain today as well, which could have been a possible cause of failure, however, nothing happened!
I checked all of my wires in the floor, they are all snug and corrosion free, still smell new. I checked the wires to the brake pump in the engine bay, those are fine as well. I haven't checked the accelerator sensor, lateral/yaw sensor, or the steering wheel sensor yet. I do believe, that it would trip a code that would link specifically to each product; brakes, yaw, accelerator, steering,etc.
I'm at a lost moment with this car. I think my only option is to take it to a dealer and have them check it out, and then fix it myself. I dont want to buy unneeded items, and I'm not sure if my mechanic is going to fix it properly, since he stated there was no code present when he diagnosed it with his equipment. Still a chance the code was thrown after I brought the car home. Howeve, he had the car from friday until tuesday.
Yikes
Yikes
If your mechanic doesn't have the STAR diagnostic system, you should find another mechanic. You can't read CANBUS with a 20 dollar OBD scanner.
stupid me- i read the obd code wrong-- it said 203b not 2036-- accelerator sensor, went to dealer and picked up a replacement.. Is there anything special needed to install it, such as software, calibration, etc-. I know the pedal calibration technique, and the steering wheel as well. However, are there any other techniques I haven't listed for calibrating the esp?
ive searched and searched, can't find anything. The car did it to me again today, but its going in to the mechanic on tuesday. I'm going to have him replace this part, and see if it doesn't fix it. I dont know if its it or not, but it can't hurt to replace it. If it does it again, I will have no clue, and no choice but to take it to the dealer.
ok so i find out today there is a campaign
#2000110005
Replacement of Pedal Value Sensor (B37)
"This campaign has been initiated because it has been determined that under certain operating conditions the pedal value sensor (b37) mau fail, causing the engine to run in "limp home" mode or the check engine MIL (A1e26) to illuminate in the instrument cluster. This requires the replacement of the pedal value sensor."
Where did i get this info? I found it on the ground after I saw a big mercedes truck go flying by.
Could this be my problem??
Sunman, please help.
#2000110005
So, I just got the C class dvd repair manual today.
It's 60 bucks, ++ = 75 total including 3-5 day shipping.
So, here's what it says about your error.
It's rather unclear, but since you mentioned your machanic and MAF, and
it's mentioned here with a possible connection, well that'd be the first thing I'd do. 1st rule in mechanical stuff; always go back to the last thing you did.
And what was the last thing before the problem happened?
MAF replacement.
If your mechanic is using parts that are one digit off,
there's yer sign. 1 digit might as well be 1 billion. It's the same thing.
Wrong part.
And never do too many things without testing each one, lest you
end up with a huge mess if it doesn't work when you get done, and you'll end up putting the old parts back in one by one till you figger out which thing you did wrong. Not related to your problem, except the going back to the last thing you did part.
I better not keep posting these things, lest I get in trouble with mercedes and the site.
Call 1800mercedes and order the DVD.
The thing is awesome.
MAF replacement.
Wrong part.
I can't thank you enough. You led me to the right decision. I ordered the right part, which cost $200 more, tonight. Everything in that pdf made perfect sense. I am going to order the cd myself as well. THank you!
the mass air meter he replaced was from ebay, and one part# off, i ordered the right one from Duval and installed it today. Complete difference. Problem is possibly solved. We'll see how this plays out.. Again, BIG kudos and blessing to c230 sport coupe, w/ o your input i wouldn't have switched it back. You rule.
T H A N K Y O U !!!!!!!!!
whats the saying, 'act of random kindness'?
And especially it's nice to be appreciated for it.
Glad it all worked out.
Hopefully I'll get some extra good Karma credits...he he...
Life does seem to work that way.
I try to help out where I can, and I always seem to get help when I need it most, in random situations.
