Rattles, Ticking, knocking, rattling DIY FIX
Old 11-11-2004, 10:04 PM
Narcissus's Avatar
2001 C240 Tectite
Ok I hate rattles, I don't like loud music, and sometimes I even turn off the radio and the rattles were driving me nuts
I think I managed to fix most of them so I would like to sare these with you.
Please note that sound travels a lot so rattling coming from the roof might be coming from the floor
1) Rattlin/Vibrating mirror : Annoying vibrating sound, stops when you touch or move the mirror, applied a .5 x .5 inch piece of paper here
Old 11-11-2004, 10:07 PM
Narcissus's Avatar
2001 C240 Tectite
2 ) Squeaky seats : Squeeks when moving, or turning/braking hard
Applied some adhesive velcro backing (the fuzzy side )where the blue spots are, you may want to apply some other places but it is defintly caused by the plastic rubbing against the vinyl
Old 11-11-2004, 10:11 PM
Narcissus's Avatar
2001 C240 Tectite
3 ) ticking sound from passenger seat: coming from passenger headrest, touch the metal rods and the sound will stop
fix: pull out headrest and gently pry the 2 metal rods outward ( holding each metal rod with both hands, don't pull them apart or you will break the headrest) slide back into place
Attached Thumbnails Rattles, Ticking, knocking, rattling DIY FIX-seatpassenger.jpg
Old 11-11-2004, 10:18 PM
Narcissus's Avatar
2001 C240 Tectite
4) Rattle coming from what sounds like speedometer: When going over rough roads or braking:
Use a plastic wedge to create a small gap between the dash vinyl and the top vent/speaker looking thing and put a small piece of cardboard or the small foam that comes with electronic and computer stuff, apply on both side, don't be afraid the vinyl is extremely resistant and will form back, don't use any metal or you may cut it, alternativly you can use a plastic card , don't use a credit card cuz you might break it ( learned the hard way )
Old 11-11-2004, 10:21 PM
Narcissus's Avatar
2001 C240 Tectite
5) Rattling from what sounds like the speedometer when driving over rough roads or braking: I had a hard time fixing this one, tried removing the speedometer, foold around with it, only to find out it was coming from the center console, press on the part in blue, if it fixes the problem, apply some cardboard or hard foam beteen the carpet and the vinyl to apply some pressure
Old 11-11-2004, 10:29 PM
Narcissus's Avatar
2001 C240 Tectite
6 ) Vibration from back when listening to music with a lot of bass:
Turn off bass! Edited for DiamondNoir2k5 : This is a JOKE
or, open the medical kit compartment ( pre-2003 ) located in the rear and line the bottom with velcro backing ( again, the fuzzy type ) and wrap your med kit inside a thin blanket or an old t-shirt
Old 11-11-2004, 10:34 PM
Narcissus's Avatar
2001 C240 Tectite
7 ) ticking sound from center console when braking/turning
Apply some thin cardboard at a few places where the wood trim and the vinyl meets, also around the radio and climate control unit
Old 11-11-2004, 10:38 PM
Narcissus's Avatar
2001 C240 Tectite
8 ) Whistling sound from air vent:
Don't completly close the blue dial, leave it partly open
Attached Thumbnails Rattles, Ticking, knocking, rattling DIY FIX-502651_56_350.jpg
Old 11-11-2004, 10:42 PM
Narcissus's Avatar
2001 C240 Tectite
9 ) Screeching tires and ESP activating when turning at 100 mph or doing a burn out from dead stop
Slow down!!!! Edited For DiamondNoir2k5 : This is a joke
That about sums it up, if I find more I'll let you guys know, hope this will help at least one of you guys, I remember having the same issues with a loaner so I figured I'd post this... All these fixes are seamless sonoone but you will know they are there
Sorry for the low quality pictures but there are not from my car, they were taken from ebay
Old 11-11-2004, 10:50 PM
W0n6_3d4n's Avatar
C200K (w204)
1, 2, 4, 5, 7 apply to my car, i'll try that and see if it fixed the problem, thx for the finding, many people will find it very2 usefull.
Old 11-11-2004, 10:54 PM
Narcissus's Avatar
2001 C240 Tectite
Hope it does, especially #5 was the most annoying for me, it wasn't loud, and other people in the car couldn't hear it ( the though I was crazy ) but when I fixed it, it was like... ALLLLLLLLELUJAAAAAAAHHHHHH felt like the car was 10x stronger!!
Old 11-11-2004, 10:56 PM
DiamondNoir2K5's Avatar
'05 C230K SS
Turn off my bass? Slow down? Have little pieces of cardboard sticking out all over the interior my car? This advice sucks.
Old 11-11-2004, 10:59 PM
Narcissus's Avatar
2001 C240 Tectite
Ok.. then.. here it is:
Disclaimer : Do not use 20x20 inches cardboard pieces for these fixes, make sure that the pieces fit completly between trims so to remain invisible and unknown to other people beside you. The turn off the bass and slow down parts were jokes, please do not leave your bass down and do not drive under the speed limit.Failure to follow these might result in you having cardboard pieces sticking all over your *******g interior and face injuries from friends who think you drive too slow and have a ghey sound system
Old 11-11-2004, 11:29 PM
Guest0001
Guest
Posts: n/a
I have 1,2,6,8.
Nice anaysis. I'll see what I Can do now.
Old 11-11-2004, 11:56 PM
elchinocache's Avatar
c240
i have 7 and 8. the solution for 8 works, all you need is to have the blue dial open a little. I'll try your solutions for 7 and see how it holds up.
Old 11-12-2004, 12:42 AM
Narcissus's Avatar
2001 C240 Tectite
Try number 5 first, I'm sure it will fix your problem... try to push on it when driving and I'm sure the ticking/rattling will stop, doing number 7 will further ensure the rattling will stop...
Old 11-12-2004, 12:47 AM
Narcissus's Avatar
2001 C240 Tectite
Sure, this comin from a guy who put blue putty in his car?
https://mbworld.org/forums/showthrea...+release+putty
Old 11-12-2004, 03:59 AM
W0n6_3d4n's Avatar
C200K (w204)
Try having 19 inch and coilover, those noise are amplify 10 times as much and as often, oh yeah i have two 15 inch sub in the trunk too , it rattle the sh*t out of the rear parcel. Dynamat seem to solve that problem though. This finding is priceless
Old 11-12-2004, 04:07 AM
Guest0001
Guest
Posts: n/a
The price of vanity.
Old 11-12-2004, 08:17 AM
taylor192
Guest
Posts: n/a
#2 is the most annoying.
I was able to solve some of the squeaks by lubricating the springs/hinges of the seat, yet the majority of the squeaks come from the vinyl rubbing seat.
Glad I have charcoal seats, the velcro fix will be easy and blend in.
Thanks!
Old 11-12-2004, 11:19 AM
Almost a Member!
f00b4r's Avatar
2001 C240
This is an awsome thread, thanks a bunch. The noise from the rear view mirror drives me nuts.
Old 11-12-2004, 12:46 PM
czachari's Avatar
2003 C230
How about a plastic creaking noise that seems to eminate from the passenger side?
Around the headrest area ? Or maybe the backset/ rear door area. Sounds like vinyl against plastic noise. Also, a ticking noise from inside the driver's seatbelt housing. I know it's in there because It's next to my freaking ear !
CZ
Old 11-12-2004, 03:18 PM
Narcissus's Avatar
2001 C240 Tectite
CZ
Do you hear the sound only when you have a passenger? if so the plastic migh be rubbing with the vinyl at the seat base... as for the seatbelt housing problem I think there was already a post about this, although I never experienced it, you might want to move the thing up or down, or pop out the plastic part and check for a loose screw.... Is your head resting on the headrest? that could be the cause, try moving your headrest forward or backward, up and down.. etc...
You'd be surprised how sounds travel inside your car, block your left ear and see if you can hear it from somewhere else....
Old 11-12-2004, 04:22 PM
kokketiel's Avatar
'01 ML430, '03 C320 Coupe MT, '14 GL450
Thumbs up I would vote for this thread as one of the top THREE useful ones!
Off-hand, I cannot think of a more useful thread.
Great work!
Old 11-13-2004, 10:51 AM
r_liebo's Avatar
2002 E55, Black on Black
Thumbs up Great Post!
Most helpful one I've ever seen on this board (especially from a non-modder like myself). I've got about 1/2 of these issues.
Can't wait to try the fixes. I listen to mostly sports talk radio instead of blasting the stereo, so these rattles are driving me nuts.
Quick Reply: Rattles, Ticking, knocking, rattling DIY FIX
