Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > SL55 AMG, SL63 AMG, SL65 AMG (R230)
SL55 AMG, SL63 AMG, SL65 AMG (R230) Discuss the SL55, SL63 and SL65 AMG.
Forum Sponsored by: The Workshop MB
Welcome to MBWorld.org!
Welcome to MBWorld,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 11-03-2009, 07:19 PM   #1
Drives: 2004 Sl55
Help with CEL on 04 Sl55. Engine hesitation/Vibration
I am new to this 2004 Sl55 with 78,000mi on it. I began to notice a vibration/misfire at around 2000rpm while driving and slight misfire at idle. Its a sort of hesitation at cruise, but at WOT i don't really feel it, and power comes on strong.
I thought it was possibly the spark plugs, so i replaced all 16 with OEM NGK laser plugs. I also replaced the air filters while i was in there..
Afterwards the problem still exists. I notice the vibration with the engine in Park/Neutral as well as drive @ 2000RPM. I then thought it might be the motor mounts, as they seem to be a common problem with these cars.
Yesterday I got a CEL to come on. I decided to run the car by Advance auto and AutoZone to have it scanned, and their Actron scanners couldn't connect.
I'm thinking the problem is either a coil pack, maf, or engine mounts.
Aside from going to the local dealer, how can i determine what the light is for?
Also, why won't the Actron scanners connect?
Any ideas what my problem could be?
To remove this ad, register today or login if you already are registered!
NikleinR6 is offline   Reply With Quote
Old 11-03-2009, 08:03 PM   #2
htn
Drives: sl55
you have any sort of third party warranty??????????
htn is offline   Reply With Quote
Old 11-03-2009, 08:28 PM   #3
Drives: 2004 Sl55
Quote:
Was actually looking into purchasing one before the problem began......
So No, at present i do not...
Old 11-03-2009, 08:37 PM   #4
jmf003's Avatar
Drives: '03 SL55
Unfortunately it could be anything, including things unrelated to the vibration.
My Actron CP9175 works fine on my SL55, for what it's worth.
If you can track down someone with a Star Diagnostics system that will certainly read the codes for you.
Good luck!
__________________
Lowest ET: 11.4 seconds
Best Trap: 126 mph
Mod list: VRP VR600 package (175mm crank pulley, 80mm TB, ECU tune, K&N filters, with Evosport shorty headers instead of VRP), PTE thermostat, Quaife LSD, SLR cams, VRP supplemental heat exchanger
jmf003 is offline   Reply With Quote
Old 11-04-2009, 02:09 AM   #5
PREMIUM SPONSOR
Drives: 09 CL65
Well, the harsh vibration and or booming sound in park/neutral @ around 2000 rpm, is in most cases (99.3% of the time) attributed to the rear engine mount (transmission mount), at our mileage, its probably original and should be replaced, afterwards you will notice the concern gone.....
The misfire is another story....
The fault codes, well you will need a star or xentry mercedes benz platform scanner/laptop to get the most accurate information on the cel...
TheWorkshopMB is online now   Reply With Quote
Old 11-04-2009, 02:48 AM   #6
Drives: 2003 CLK500
I would venture out a guess and say its the MAF sensor. Just as the other's have stated, hook it up to Star and it will definitely tell you. Good luck!
__________________
-Jon
kiamcoj is online now   Reply With Quote
Old 11-04-2009, 08:03 AM   #7
Drives: 2004 Sl55
Thanks guys..
I have a buddy that has a different obd2 scanner so i will try it tomorrow.
I would really like to have my own, so i really didn't want to give the dealer 100+ to scan the car, and would rather use the money to purchase a compatible scanner for myself.
Maybe a ScanGuage2 is in my near future..
If his scanner doesn't work, I will most likely take it to the dealer so i can begin to get this problem sorted.
Also, i don't think i am going to drive the car much until i figure out if it is some sort of misfire. I would hate for 1 cylinder to not be firing, and have piston wash as the result >lead to ring failure, gas in the oil, and eventually bearing failure as well.
Maybe someone can answer this for me> Why do we have 2 spark plugs per cylinder? Is it for emission purposes, and both plugs fire at the same time for complete fuel burn? OR Is it for performance purposes, and 1 plug fires until you begin to build boost/accelerate hard and then the second plug comes online to prevent plug blowout??
Also, I was thinking of changing all the engine mounts and trans mount anyway. I have heard it is difficult, but not impossible. I have pulled and reinstalled engines countless times on different vehicles, so I guess i will see what i am getting myself into as i go.. I have heard the engine just has to be lifted a couple of inches in order to remove the mounts.
Any tips or tricks i should be aware of??
Nick
Old 11-04-2009, 06:44 PM   #8
benz_addict's Avatar
Drives: CL55 ///AMG
you might have a P0106 code, that is what I got on mine too. Same engines.
If it's not keep us updated!
__________________
CL55 AMG V8 Kompressor - ECU tune, primary cat delete, CM30 IC pump, 285/35/18 street setup
E430 4Matic - black/black 5% limo tints - winter killer
***Mississauga Crew***
benz_addict is offline   Reply With Quote
Old 11-05-2009, 07:37 PM   #9
Drives: 2004 Sl55
hmm
Well, I just got back into town... I started up the car to head over to my buddies house with the scanner, and the check engine light never came on???
I am really thinking i have some sort of misfire problem. How can i test the coil packs. On previous cars, i would just pull the plug, ground it, and look for spark. But i have not worked on this advanced type of vehicle yet..
Any ideas how to check the coil packs for proper operation?
Nick
Old 11-05-2009, 08:20 PM   #10
Drives: 2003 s600
spark plugs fire alternately, not at same time. prob helps them last longer. Any scan tool should read the codes. I had misfires on both banks and had to replace both coil packs. You are lucky, you can replace individual ones.
2003 S600 is offline   Reply With Quote
Tags
amg, check, engine, firing, maf, mercedes, misfire, order, sl55, vibration
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
