| Home | Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Vendor Directory |
| W211 AMG Discuss the W211 AMG's such as the E55 and the E63 |
| Welcome to MBWorld.org! |
Welcome to MBWorld, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today! |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#26 | ||||
Drives: '05 C55(sold)'05 E55(sold)'06 911C4S(sold)'06 ML350 '06 CLS55(sold),buncha slo bikes
#27 |
Drives: CL65
Great write up!!!! I have just one serious and egregious omission.... bring you own Swedish Bikini Team pit crew. Other than that... outstanding!!!
Tom |
#28 |
Drives: E63 P30, CL500 Sport
Okay, I'm still a little confused on the whole street tire burn out issue
![]() So, people with street tires are supposed to do a mini-burn out but not in the water? Or avoid the burn out all together?
__________________
2007 E63 w/P30 ---> 12.22 @ 115.1 (100% STOCK - Seeking 12.1x @ 116)
#29 |
water issue first:
The tire treads can hold some water which *could* drip onto the starting line while your staged&present a traction issue when you launch when your rear tires accelerate over the water.It's mostly the fronts that will do this,as the water on the rears is flung off during the burnout. This is a HUGE issue when I run my bikes,I ALWAYS back into the water to avoid this. On the cars depending on which track your at you may not have room to simply drive around the water box(i.e. Atco)&back into it.When this situation arises what I will do is roll through the water&get the rears wet&then pull a few feet ahead&start my burnout. I then do whats called a "dry-hop" which is basically a practice launch before the staging line.This is a very good indicator of traction&for me determines how hard I can mash the gas off the line.The dry-hop also helps fling any water accumulation on the front tires. warming tires next: You have to find the right amount of time needed doing a burnout to get your tires up to temp(street tires not so much);my buddys use a laser pointed temp gauge&simply aim it at the tire to get a reading;it's also great to measure how hot the track surface is which plays an integral role in getting traction but that's a entirely different story. If you get street tires too hot you basically lose traction as they get "greasy" and slippery.The reason I spin my street tires is to clean the debris off&make sure there's no "boogers" on them(tiny balls of rubber stuck to the track as a result of burnouts).These will KILL your launch in a instant if they are clinging to your tires. Only practice will determine which heating method(if any) works best for each track/tire brand/weather conditions. Contrary to popular myth,dragracing is much more then simply mashing the gas&going fast in a straight line.Some people who've never done it think there is no skilled involved when thats actually the furthest from the truth |
#30 | |
Quote:
hmmm sounds like someones been sandbagging on skill level ![]() Great info here |
#31 |
Drives: 2009 GTR, 2005 K3 E55, 2007 RS4
Chicago, I'm impressed!!! that was a killer write-up.
Okay, why not the Enzom method? No preload....... roll off the brake and into the throttle. If I don't break into 11.5 or under this spring, I'll need to call you out. ![]() Thanks for the informative post.
__________________
2009 GTR, 2005 K3 E55, 2007 RS4, 2006 IS350
#32 | |
Quote:
Hmmm...... very interesting, I'll try that next time
__________________
#33 | |
SPONSOR
Drives: W211 E55
Quote:
Anything much above 1200 RPM and the computer freaks out and limits power. Consistent 1.6 60' times are one torque limiting software "feature" away, IMO.
__________________
#34 |
#35 |
Drives: 04 e55
This is really good stuff. Thank you guys for sharing your knowledge on the subject. I don't want to be "that" guy at the track. I am still hoping to go on Friday, but it isn't looking good.
I have 2 more stupid questions: 1. How much fuel do you guys try to have in the car when you run? It seems that too much fuel would cause you to be overweight. Not enough may cause you to lose traction. What do you guys do? 2. The helmet issue. I certainly respect that you guys absolutely recommend using a helmet. But, here's the deal for me. I may get to do this once or twice in my life. With all that I have going on in my life, I don't see this being a hobby for me. I really don't want to purchase a helmet for just a few times down the track. I know I'm cheap. What are my options here? I guess since I am in Oklahoma, I could get a piece of crap OU football helmet and wear that. All the rednecks here would love it. |
#36 | |
SPONSOR
Drives: W211 E55
Quote:
1) About 1/4 tank 2) Get a helmet. Borrow one, steal one, go on Craigslist and trade "favors" for one....do what ya gotta do.
__________________
#37 | |
Drives: 08 Evosport CLK 63 Blk Series
Quote:
Dude, you own a $65,000 automobile, go out an spend a couple hundred on a decent NEW helmet, that fits properly. Also, helmet fit is VERY important, so spend some time trying on several. Don't just buy the cheapest one on the rack! I don't buy cheap helmets, When I raced motorcycles I bought helmets that approached $1000.00, and that was 10 years ago. This is not an area you want to cut corners on. You know what they say, Cheap Helmet, Cheap Head! I would have to assume you can get a good helmet with the proper approvals and ratings for $150-$200, maybe less. I would also recomend a neck roll, they are $20.00.
__________________
#38 |
Go to www.summitracing.com
I just browsed their site and they have approved full-face helmets starting at $149.00, neck roll/braces starting at $29.00, nomax (fire retardant) gloves starting at $29.00 and fire retardant jackets starting at $46.00. For $250 bucks you can show up at the track and look like you know what you are doing and more importantly be safe and ready for whatever may happen. Safety equipment is like insurance, you hope you never have to rely on it, but if you do, it's nice to know you have it. I have a roll cage and 4-point racing harnesses in my car (driver and passenger), I think that shows my level of dedication and awareness to safety.
__________________
#39 |
Super Moderator
Drives: 2007 Porsche 997TT - 2009 BMW M3 - 2009 Nissan GT-R - 2009 Lexus IS-F
Stick time.
__________________
![]() Also: 2009 Lexus IS-F White on Black A Shake N' Bake sig V12TT Mafia Capo di Capi Re |
#40 | |
Drives: 04 e55
Quote:
Alright. I give in and I will get a helmet. It looks like I will have to dream up a story to my wife about how the helmet was thrown in when I bought the car. My rat hole of cash keeps getting smaller since I bought this car. Thank you for the link. |
#41 |
LOL! Cars are money pits! You should have no problem with a story, just explain to the wife how safe it will make you...Just don't let her find out how much the tires cost, if she ever sees you in the burn out box roasting your tires, that's when it will all come to an end! That's not rubber you smell at the drag strip, it's the scent of burning money!
__________________
#42 |
WOOOOOHOOO STICKY STICKY STICKY YEAHHHHH
I spent 500 dollars on a set of C class rims so I could try a new launch tech.. Thanks to the Admin for making this a sticky, great info here. Tip for today. 1. When letting the car cool , take off the oil cap and radiator cap. tip 2 2. When going to the starting line make sure you SCREW THE CAPS YOU REMOVED IN TIP ONE BACK ON!! |
#43 |
NEW NHRA RULES EFFECTIVE 3/28/2008
While talking with a friend yesterday that is a licenced NHRA driver, he mentioned some changes to "protective clothing" section of the 2008 NHRA Rule Book. The reason I mention this is that most NHRA sanctioned tracks adopt the NHRA Rule Book as "standard practice" even for private events and test & tune events. Their liability insurance usually requires it. Check with your local tracks to be sure. I already tried calling my local track for clarification (Route 66 Raceway Joliet, IL) this morning and left a message for their head tech person. I did see some of these changes on the NHRA web site under "Rules Revesions" but the verbage is unclear to me. It looks like they are requiring fire retardant 3.3 gloves, neck braces or skirted helmet and hood/mask for ALL open body/cockpit (cabrios) vehicles. It also appears they are requiring high top shoes or boots. It appears helmets have to be full-faced now as well and must run with sheild on the helmet. There were a number of other revisions listed on this page, that all become effective 3/28/2008. I would suggest calling your local track before heading out to an event just to make sure you have all the required equipment. Once I get a call back from the tech person I will let you all know what he tells me. I am trying to paste a link to the NHRA Rules revisions, but it is not working.
__________________
#44 |
Drives: 06 S65, 06 M3 CS(stick), 02 BMW X5 4.6iS, 07 R1 Raven, 08 F-450 4x4, 08 CooperS JCW
#45 | |
Quote:
Wayne OMG bro wow, I saw this happen today!!! Both cars dialed 10.09 Both cars left at .003 Both cars ran 10.091 LOL!!!!! I have no clue who "won". I really am learning alot and am the only AMG(Mercedes of any kind) in the Pacific division Summit Series. Man it is such a fun way to race and yes there are big cash prizes for the winners. I got some points today as I went 3 rounds. Lost by 2/100ths to a slower car :-(. Guys , if you want to race people there is no better way then heading down to your local track for a bracket race, wow it is just ridiculous. |
#46 | |
SPONSOR
Drives: W211 E55
Quote:
I remember (way back) being the only 5-speed in a field of automatics and feeling out of place.....until they handed me the check. ![]() Good job getting out there and representing the brand.
__________________
#47 | |
Drives: 2002 E55
Quote:
cool tips, thanks! |
#48 |
Wayne could you add a description of "Heads up" racing,
how do you run someone, what determines a win? Not bracket racing but "heads up" run whatcha brung.......... We seem to have some differing opinions on what constitutes a win........ |
#49 | |
Drives: 05 CL600 AMG tuned ECU/TCU
Quote:
__________________
![]() Member #1 Capo Di Tutti Capi V12TT La Cosa Nostra |
#50 | |
Quote:
Actually bracket racing allows the slow cars a chance, heads up the faster car even with a bad start should reel in the slower car. I think this is complex , here is why. Lets say for example you and I are @ MIR. I say , lets line em up. We both stage, we go light turns green you 60ft @1.65 and I get 1.85 my R/T is .002 and yours is .555, your 1/8th mi trap is 94.75 and mine is 91.9 your 1/4 mile trap is 123.7 and mine is 117.7 1/4 mi ET Jay= 11.291@123.7 Josh= 11.843@117.7 Who WON???
| Tags |
| automatic, bag, disengage, drag, esp, ice, race, racing, trans |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
