Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > E55 AMG, E63 AMG (W210, W211) > W211 AMG
Welcome to MBWorld.org!
Welcome to MBWorld,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-03-2009, 01:34 PM   #76
GARY JAVO's Avatar
Drives: 2003 S-600
Quote:
Originally Posted by blackbenzz View Post
Welcome to the site and glad to see you picked up a benz
Thanks for the welcome. Badass benz you have there!
To remove this ad, register today or login if you already are registered!
__________________
2003 S600 AMG (Want To Make Fast Not Sure Who To Use)
2001 Protomotive 996 Turbo
2002 Heffner Viper GTS "Big Red" (1101WHP on 93 Octane)
2008 Hayabusa (Basically Stock)
GARY JAVO is offline   Reply With Quote
Old 04-03-2009, 01:38 PM   #77
Drives: 2003 E55 570whp! Booyeah!!
Holy crap!! Are you THEE Gary Javo??!!!!!
I am a huge fan!!!
http://videos.streetfire.net/video/Another-8second-Viper-by_31362.htm
http://videos.streetfire.net/video/G...ike_109207.htm
__________________
Jakpro1 is offline   Reply With Quote
Old 04-03-2009, 01:48 PM   #78
Dsmed's Avatar
Drives: E55
Every V12tt car has a revised part# to run the same trans that's in the Maybach. The trans numbers did change so earlier cars might have a different one in them. I don't know what the difference would be. My guess would be clutch packs. I did notice if you look up individual parts a lot of the parts have the 240 (maybach) designation to them.
Dsmed is offline   Reply With Quote
Old 04-03-2009, 01:56 PM   #79
GARY JAVO's Avatar
Drives: 2003 S-600
Jak,
Thanks man. Looks like you guys have a great community over here. I'm trying to get up to speed with this Benz. This is my fastest pass to date. Not as fast as Marco , but moving out pretty good nonetheless.
http://garyjavo.com/videos/2007%20vi...n/8.57pass.wmv
Sorry for the partial thread hijack.
GJ
__________________
Old 04-03-2009, 03:38 PM   #80
Drives: SL600
Quote:
Originally Posted by JAYCL600 View Post
Rear end and axles will go before the tranny. In theory you wont ever break the tranny under normal driving conditions, as soon as enough power is applied the tires will break loose thus saving the tranny against the high TQ loads which are primarily in the lower RPM range. Track conditions with sticky tires and hard launches will usually result in the rear end or one of the axles letting go.
If that's the case then why is the Tranny always cited when they talk about the cars being limited.
Akademiks is offline   Reply With Quote
Old 04-03-2009, 03:44 PM   #81
Drives: SL600
Quote:
Originally Posted by MarkoCL65 View Post
You can do anything with enough money. There would be a substantial cost involved as the majority of the components would have to be fabricated. Items such as pedal cluster, fluid reservoir and hydraulic lines, bell housing, flywheel, transmission mounts, driveshaft, and possible exhaust mods. I imagine the downtime on a project like this would be almost a year. Then you have to get into endless hours figuring out how to have the TCU eliminated, or reworked, so that the ECU can continue to function properly. That in itself may be a "mission impossible".
As for the cost and down time, dang it. It'd be a good way to shed a couple pounds though lol
Ok, question, why can't we simply convert our cars to work without the ECU-- much like an old muscle car? I know Benzes are over-engineered but damn...
Old 04-03-2009, 04:10 PM   #82
V12Godspeed's Avatar
Drives: E55
Eveyrhting has a sensor in these cars. When it comes to electronics they are super sinsitive. Take my car for example...a little sensor broke (boost pressure sensor) albeit an important one and car completely losses power and runs like a 4cyl. Everything must be working in sync since everything has a value or input.
__________________
Current:
04- E55- White/ Pano w/all options/ Stock for now...
Previous Rides:
05- CL65- "The Black Bison"
VRP 825 - 10.72 @ 128.08
http://www.youtube.com/watch?v=caoztJbtaZA
"Capo Regime North (Member# 3)"
Gone but not forgotten....
2004 E55 Evotech Stage 4+ - Silver
11.5 @ 120.96
http://www.youtube.com/watch?v=AgNFUdDMQHw
2002 C32- Black
V12Godspeed is offline   Reply With Quote
Old 04-03-2009, 04:15 PM   #83
Drives: E55
Quote:
Originally Posted by GARY JAVO View Post
Jak,
GJ
Gary, that pass was incredible. Just amazed on how you kept that thing straight. Insanely fast is an understatement.
__________________
Current:
Previous Rides:
11.5 @ 120.96
2002 C32- Black
Old 04-03-2009, 04:29 PM   #84
TMC M5's Avatar
Drives: CL65
I think people mention limitation with the tranny in two ways:
1. AMG engineers limiting the torque output from an unfettered 885lbs-ft of TQ to a "puny" 738lbs-ft to protect the tranny.
2. The actual torque limiting software in the TCU which cuts power to "safely" allow the tranny to shift under load.
You have to remember that no regular production car in the world has as much torque as the 65 engine does coming right from the factory. These are luxury cars and there wasn't a justification to having maximum torque available. I think the AMG enginners were overly conservative in their concern for the tranny itself. The 738lbs-ft tq figure seems like an odd figure at first blush, but it actually converts into 1,000 Newton Meters of torque (metric measure). That makes it seem somewhat arbitrary, like the AMG engineers said
"zer is no need to put all za POWER through zee tranny, zee tyres will melt like zee Hindenburgh....we will limit zee torque of 1,200 newton meters to 1,000 Newton meters...da...zat is a good number...no one makes even close to 1,000 newton meters of torque..."
Tom
__________________
Consigliere V12TT La Cosa Nostra
TMC M5 is offline   Reply With Quote
Old 04-03-2009, 04:46 PM   #85
GARY JAVO's Avatar
Drives: 2003 S-600
Godspeed - Thanks man. The car had A LOT left in her, but the track just wasn't holding the power that day. Oh well.
__________________
Old 04-03-2009, 04:48 PM   #86
bobgodd's Avatar
Drives: 2004 E55
Quote:
I would imagine that if one were open to losing a lot of the functionality or luxuries provided by the stock computer, a stand alone engine management system would be ideal. If you could tune the engine and all driving parameters "out" of the stock ecu, then you could use a total different system for the cars driveline. I have no intimate knowledge of tuning vehicles, but if a tuner can tune out sensors such as O2 sensors, I think it could be possible to tune out other sensors.
If there is no computer telling the sensors what to do, they cease to function. Your crank position sensor or say your boost pressure sensor can break or fail and it wouldn't have any effect on the car because there is no computer sending messages based on those readings.
bobgodd is offline   Reply With Quote
Old 04-03-2009, 05:24 PM   #87
Drives: ES300/LX470/240SX
Quote:
Originally Posted by LTHL VPR View Post
Thanks for doing the research. Is this for a new one or a rebuilt one? What about cost for installation. Still expensive piece if you explode one with too much torque
You are most welcome That was off an MB Online parts site, NEW.
E55AMGFan is offline   Reply With Quote
Old 04-03-2009, 05:26 PM   #88
^ I remember you from the killer vipers you've owned! Welcome to the site and glad to see you picked up a benz
Exactly the same reason how come I recognized the name as well, That TT Viper was insane!
Old 04-03-2009, 05:33 PM   #89
Drives: SL600
Right, I get what you mean about the sensors, but if you take the sensors out then they can't tell the car to limit anything right-- or recognize anythings "wrong" (ie: insane amount of power to tranny sets off check engine light)? Like, the car would work like a old muscle car basically... or am I missing something here? Pardon my ignorance, I'm not much of a tuner.
Old 04-03-2009, 05:36 PM   #90
AMGfan's Avatar
Drives: 06 SL65 / 04 E55 / 04 Cadillac Deville (AMG è la mia Famiglia la Bestia è la mia protezione)
Isn't this still an option for the 65? Victor can you confirm?
*** VRP Bullet Trans ***
__________________
Capo Regime Central Florida (Member #4)...Mi ha dato un'offerta che non potrei rifiutare.
AMGfan is offline   Reply With Quote
Old 04-03-2009, 05:38 PM   #91
Drives: SL600
Quote:
Originally Posted by AMGfan View Post
Is 1200 lbs enough for our cars?
Old 04-03-2009, 07:26 PM   #92
Oxygen's Avatar
Drives: w220 S600 V12 Biturbo - TUNED
Send a message via AIM to Oxygen
Quote:
Originally Posted by Thericker View Post
That's great info, the previous "parts & tranny costs" post makes it look like the 65/600 share the same tranny? Could you ask your tech to verify or does someone have definitive info on the matter?
I checked and it looks like the following cars:
Maybach 57/62
SL600/65
S600/65
CL600/65
Share the following transmission: 722.649 / W5A900 - Part Number A240 270 05 00
I also checked out the SL65 AMG Black Series ( VIN: WDBSK79F79F155818 ) and I see the same exact components.
Also looking at the components internally the clutch packs contain the same parts internally across all the above models.
With big thanks to Marcin (DSMED) I have successfully transfered the AMG "Speedshift" programming from V12Godspeed's CL65 TCU to my S600's TCU and the car now has "M" mode available along with the 65 shift program.
__________________
| Photos | TTMotorsports Team #27 | ν = μ / ρ, [m² s-1] | '05 Mercedes-Benz S600 - 5.5L 36V SOHC V12 Biturbo
Designed & Built @ TTMotorsports | ///AMG | RENNtech | PES | Meisterschaft | Snow Performance | BMC | Rädenergie
Oxygen is offline   Reply With Quote
Old 04-03-2009, 10:40 PM   #93
Thericker's Avatar
Drives: W220 S430 w/Supercharger C6 Corvette blk on blk 2005 SL600 Twin Turbo AMG body blk on blk loaded!
Quote:
Maybach 57/62
SL600/65
S600/65
CL600/65
WoW!! too kool, thank you for gathering info. OK...How much for this factory AMG tcu speedshift program? & contact info? Did the programming change or lift any of the Torque limiters?
Somebody needs to get a hold of Jay's AMG tuned CL600 we need that file damnit!!
__________________
http://mbworld.org/forums/image.php?type=sigpic&userid=13476&dateline=1226297708
'05 SL600 BITURBO 19x10.5 19x8.5 whls/Custom 3" DP's w/Hi-Flo cats/AMG quad tip cat-back 3" straight pipes/Custom CAI/Rear IC Reservoir 5.5 gall alum tank w/CM30-Pump/Powerchip TT Dyno-Tune
Thericker is offline   Reply With Quote
Old 04-04-2009, 03:57 AM   #94
Gondon's Avatar
Drives: 02 S500 Sport
WOW Insane Cam view of the Viper.
Oxy when you getting the VRP 825 package?
__________________
[x] 35% Tints@ 212 Motoring
[x] MagnaFlow Quad Exhaust
[x] Updated HeadLights
[x] Updated TailLights
[x] Updated MirrorLights
[x] Clear SideMarker
[x] Akebono Brake Pads
[x] S65 GunMetals Rims
Gondon is offline   Reply With Quote
Old 04-04-2009, 11:08 AM   #95
Oxygen's Avatar
I did not pay anything-- Jody (V12Godspeed) gave me his physical TCU. I copied EVERYTHING off of it, coded with my VIN, wiped my TCU and flashed it with Jody's VIN coded file.
Find a friend with a SL65 and a friend that's nasty with SDS and you're in the "600 with 65 transmission" club.
I'd love JayCL's TCU!
As far as torque limits- how ever the limits are setup for the 65 that's how it is. Like I said the tranny mechanically is identical, just the TCU programming is different.
__________________
Old 04-04-2009, 11:22 AM   #96
GARY JAVO's Avatar
Drives: 2003 S-600
What differences have you noticed with in the M mode?
__________________
Old 04-04-2009, 11:46 AM   #97
Oxygen's Avatar
Behaves like any AMG car in M mode. No automatic upshifts and hits the limiter at around 5900 RPM.
Also the shift buttons on the steering wheel are enabled (if equipped with AMG steering wheel)
__________________
Old 04-04-2009, 11:50 AM   #98
GARY JAVO's Avatar
Drives: 2003 S-600
That's badass.
__________________
Old 04-04-2009, 01:26 PM   #99
Drives: E55
Quote:
Agreed. Only if you have a stand alone correct? Not on our ECU's. It could definitely be done.
__________________
Current:
Previous Rides:
11.5 @ 120.96
2002 C32- Black
Old 04-04-2009, 01:29 PM   #100
Drives: E55
I am so glad this worked for you buddy!
__________________
Current:
Previous Rides:
11.5 @ 120.96
2002 C32- Black
Tags
2005, 5900, benz, biturbo, bleeding, build, intercooler, intercoolers, mercedes, package, pump, sl600, sl65, v12, vrp
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
