| Home | Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Vendor Directory |
| W211 AMG Discuss the W211 AMG's such as the E55 and the E63 |
| Welcome to MBWorld.org! |
Welcome to MBWorld, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today! |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | |||
Drives: 08 CLS63
KN Filters, CEL and OBDII Codes
__________________
#2 |
Drives: E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s, Sold Porsche to Brother
Too bad, you are not the first, and you won't be the last. Don't hold your breath waiting for K&N to make good.
Where in Florida do you plan to visit? |
#3 |
Drives: E55 AMG
I let mine sit in the sun a for a lil while before i put them in , sorry I dont know how to clean MAF sensors
__________________
#4 |
SPONSOR
Drives: S600TT, R350
Go back and re-check your install.
You have an air leak that's screwing up your MAF readings. There are two. One per each bank. It is not filters.
__________________
#5 | |
Drives: 08 CLS63
Quote:
__________________
#6 |
Drives: 2003 W211 E55
Make sure the plastic Y pipe is secured correctly, it may look like it is secured but there will be a leak.
Also hook up your scanner and let us know that the throttle position percentage is at idle.
__________________
"Lieber Nurburgring als Ehering" |
#7 | |
Drives: 2004 S600
Quote:
When will people learn that K&N's DON'T cause MAF malfunctions. Sorry its horse hockey. Been using them since mid 80's now, and its just BS. ![]() http://www.knfilters.com/MAF/3MAFSensorVideo.htm |
#8 |
Drives: E63
I put my K&N's in and threw a CEL the next day it was for a lean engine. I took them out and reset it. I'm waiting till I find out a solution before I put them back in? The car actually felt pretty good according to the butt dyno before I took them out.
__________________
2007 E63 (His) 2007 GL450 (Hers) 1970 CONV KARMANN GHIA (Hers again!!) |
#9 |
Drives: '86 190e restoration project, '08 Acura RDX, '09 C63 AMG
So far ok with my new K&Ns. I currently have them on the RDX and 63.
__________________
"Unofficial Member" of the Vancouver Benz crew. '09 C63 KLEEMANN MS-11S & K1. Charcoal delete w/K&Ns. SMERC upper strut bar. |
#10 |
Drives: E63
Did u leave the charcoal filters in the 63?
__________________
#11 | ||
Drives: CLS55 AMG 030
Quote:
Quote:
I've known many who have had their MAF fouled directly after installing K&N's or after cleaning and over oiling them. And do not trust that new filters are oiled properly. Before I ever install a K&N, I always blow them out with compressed air and then let them sit for a few days in the open air (engine side down) to coagulate. I can tell you for a fact, you'll get a lot of oil off them from brand new blowing them out. When I've done this I've never gotten a fouled MAF. Stick a paper towel behind them and blow it out and tell me oil doesn't come off them. You'll be surprised how much does. That video is very misleading. They even admit the sensor got fouled but then the oil gets drawn off them and they're very durable. They're right. They ARE very durable. That doesn't mean they can't foul ... it means they're not ruined. I've cleaned them by a simple alcohol bath. And let them dry. You still have to clear the CEL. I debated K&N's for this motor, but IMO the filter area is so over redundant, it's not worth the loss of filtration.
__________________
#12 |
__________________
#13 |
Drives: E63
Man, I threw a CEL the day after I put mine in? I asked about it before on here if the car will reset itself and I got mixed answers. So I took them out just to be safe until I can find out something definite.
__________________
#14 | |
Quote:
I've seen this many times. If you fouled your MAF you'll need to clean it.
__________________
#15 | |
Drives: E55, Renntech CL600(sold), GL450
Quote:
Many people falsley oil the backside of the filter so the oil gets sucked directly into the MAF. However, when installed correctly and not over oiled, there is nothing wrong with K&N's. I've gone through MAF's when using a paper filter so have tens of thousands of other people so you can't blame those failures on K&N. Some MAF's are just highly prone to failure. It's more than likely, in this case, that the reinstall was not done proprly and there is an air leak. |
#16 | |
Quote:
__________________
#17 |
Drives: 08 CLS63
Okay I've got an update. I took it in to the dealership to have it looked at. They also came to the conclusion that they are getting codes for an air intake leak. However, after inspecting everything they suspect it is a bogus code. They did however, find a service bulletin related to this issue and it recommends re-sealing the intake, at least that is what I was told. I'm going to take it in soon and have them complete this to see if it fixes the CEL. K&N filters or not, it is unusual for this to happen immediately after installing them.
__________________
#18 |
Drives: SL55, RX7, RX400h
55 engines have no MAF.
#19 |
Drives: 2004 E55 AMG
Have always used KNN, only issue I ever had was too much oil which got on the MAF on my GS400. This caused a small piece of debris which must have been in my airbox to stick to the hotwire preventing the car from running. A simple spray of cleaner solved it.
So far no CEL in my E55. |
#20 |
Drives: 2008 CLS63 AMG
Lexaltezza, any news? I installed my K&Ns and had the light pop up with the same codes... My car is at the dealers and they suspect a manifold leak
... All of this started randomly happening after I installed the K&Ns. Can you please keep me updated as we are having the same issue on the same car, lol!
__________________
Present - 2008 Mercedes CLS63 AMG - Silver on Black... Gone - 2005 Mercedes E55 AMG - Black on Black... Gone - 2006 BMW M5 SMG - Silverstone on Indianapolis Red, gone but will never be forgotten... Gone - 2003 Hummer H2 - Black on Beige... ***Mississauga Crew*** |
#21 |
What sensor might cause the false detection of a leak?
The MAF perhaps? I'm just sayin ...
__________________
#22 |
Drives: 2004 S600
#23 |
Should I just tell my dealer to replace the MAF? I honestly think that my manifold is fine...
__________________
#24 |
At $300+ a pop ... I'd clean them first. (2 on a 63? ... I find them online for $352 ea)
Problem is, even if they're clean and working properly, the code may have to be cleared. (Someone please correct me if I'm wrong on that) I believe, once a "serious" CEL code is triggered, you need to clear it. MAF sensors are usually located directly after the filters and before the Throttle body.
__________________
#25 | |
Quote:
![]() Should have it back tomorrow!
__________________
| Tags |
| 1137, air, circuit, flow, mass, obdii, volume |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
