Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > E55 AMG, E63 AMG (W210, W211) > W211 AMG
Welcome to MBWorld.org!
Welcome to MBWorld,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 08-15-2009, 01:34 AM   #1
myfirste55's Avatar
Drives: E55
E55 oil change
Looking to change my own oil in my 03 E55.. Do you recommend? Or should I drop it at my mechanic? Also... What oil would the best oil be for 60k?
Thx
To remove this ad, register today or login if you already are registered!
myfirste55 is offline   Reply With Quote
Old 08-15-2009, 01:39 AM   #2
RenntechE55's Avatar
Drives: E55 AMG
I use 0w-40 but its almost worth it to take it to jiffy Lube I took my own oil and they changed it and provided the oil filter so they charged 32 buck which is cheap for a oil filter and change .
__________________
2005 S55 engine , 180mm LET pulley , VRP intake/ Python tubes , Floored Fab. LT's with Race cats. Floored Fab. HE/ CM30 pump 19" OZ Racing wheels , lowered with links........whats next??
RenntechE55 is online now   Reply With Quote
Old 08-15-2009, 03:01 AM   #3
Drives: 03 E55
Stright forward and for the most part easy to do, Filter is on top so you spill no oil! pull the plastic belly off and the oil pan has 2 sumps so 2 drain plugs. They say that the plug is one time use but I reused mine, I did apply teflon paste to the treads as there is a know issue of sepage. You might consider doing the trans wile your there, your under the milage but might be nice to knock it all out at once.
sneakyneon is offline   Reply With Quote
Old 08-15-2009, 10:03 AM   #4
Drives: W211 E55
what's the recommended tranny fluid?
Ammi is offline   Reply With Quote
Old 08-15-2009, 10:49 AM   #5
Drives: 03 E55
Quote:
Best bet is from the dealer, I've heard of some others for the 722. trans but belive it or not the MB fluid is less money.
Old 08-15-2009, 10:53 AM   #6
myfirste55's Avatar
Drives: E55
Quote:
when is Tranny do? I mean... how many miles?
Old 08-15-2009, 12:16 PM   #7
MJ50's Avatar
Drives: W203 & W211
Send a message via ICQ to MJ50 Send a message via AIM to MJ50 Send a message via MSN to MJ50 Send a message via Yahoo to MJ50
Quote:
dealer recommended at 40k miles...
__________________
2003 C240 MBenzNL (PTS, IMS, euro COMAND, folding/convex mirrors, euro bi-xenons, SAM, MHI, euro trunklid, euro mat, steering wheel, etc...)
2004 E55 MBenzNL (057,219,390,428,500,527,615,682,816,881,882,884, CLS63 IC, AMG Airbag, iPod, Euro Door Pins/Convex Mirrors/Trunklid), SL65 rims, RENNtech pulley
2004 ML350 MBenzNL (rearview mirror, AMG style steering wheel, euro convex mirror) SOLD
323.205.MJ50 Google Voice
MJ50 is offline   Reply With Quote
Old 08-16-2009, 02:57 AM   #8
Drives: W211 E55
you guys know how many quarts we need?
Old 08-16-2009, 02:10 PM   #9
Drives: 2004 E55 AMG
You'll need 9 quarts of oil, but I'm not sure on the tranny fluid. I'm curious about this myself, as my car is at 70k and has very likely never had the tranny serviced, and i'd like to do it myself in a couple months at my next oil change(no point in paying the stealer big $$$$ for removing a couple of bolts).
FWIW I have put 4,000 miles on the oil currently in my car, and according to the level display on the IC I'm not even down 0.1 quarts, which is pretty amazing to me.
izzyz28 is offline   Reply With Quote
Old 08-16-2009, 09:51 PM   #10
Estate55's Avatar
Drives: E55 Estate
Someone who has changed their own trans fluid should post it in the DIY sticky!
__________________
2006 E55 Estate
Lots Of Other Cars
Estate55 is offline   Reply With Quote
Old 08-17-2009, 02:22 AM   #11
Drives: 03 E55
Quote:
Ive done it, took 5 bottels. Really dont need a DIY thread if your machanicaly inclined, Remove belly pan remove drain plug drain fluid, remove trans pan bolts, pull the filter out, reverse the steps. Common sense should tell you the rest. Working on your car is not for every one, know your limitions.
you Do need to a dip stick to do this job .
Old 08-17-2009, 11:45 AM   #12
prodigymb's Avatar
Drives: E55
thats because you didnt flush out ALL the trans fluid. the full capacity is more then 5 bottles.
__________________
2003 E55 AMG 11.44@123.4
2007 VW GTI GT2871R @ 22PSI
1993 Accord H23 EVOIII 16G @ 9PSI
prodigymb is offline   Reply With Quote
Old 08-18-2009, 09:05 PM   #13
Drives: 2005 E55
Quote:
correct. i recently took mine to the dealer for tranny service and they used a bottle of ATF cleaner, followed by six 6-packs of ATF.
of course this was a flush and not a drain and fill.
O-55 is offline   Reply With Quote
Old 08-19-2009, 12:21 PM   #14
TopEndS62's Avatar
Drives: 2005 BLK/BLK E-Double Nickel.
Is it safe to flush the transmission?(keep hearing mixed stories)... Sorry for the question but this is my first automatic car that i will work on and i am mechanically inclined..
__________________
Photobucket
2005 M. BENZ E55 AMG(Lifetime labor warranty(ME))
A BUNCH OF BMWs(SOLD)
Alot of ACURAS(SOLD)
TopEndS62 is offline   Reply With Quote
Old 08-19-2009, 12:32 PM   #15
I've done it and it takes 5 quarts. Friggin' bonehead stealer parts counter advised 7 quarts so that's what I poured in. After a test drive and a TON of smoke from overfilling it, I bought the $$ dipstick and verified I was WAY over the max. I drained part of the fluid..about 2 quarts. So, essentially I did a partial "flush" as well
Jeff
Racerxjling is online now   Reply With Quote
Old 08-20-2009, 04:48 AM   #16
Drives: 03 E55
Well this statment seems to be lacking any usefullness, - guess if you want to spend a few grand on shop grade transmission flush machine then by all means. How ever if all you want to do is drain the 80 percent of the fluid and replace the trans filter in your own garage with you own basic hand tools then I promise you its 5 bottles of MB fluid. I'm pretty sure this thred was a guy asking for DIY info. Instead of open ended statments that don't help please share you personal exspeirance to help out.
Old 08-20-2009, 09:27 AM   #17
I agree. He knew I was a do it yourselfer so highly unlikely I have a flush machine (although I do have a lift in the garage After draining fluid, I BELIEVE I netted only 3.5 to 4 quarts. IOW, I would start with 3.5 to maybe 4 qts and then measure it with the dipstick. As a side note, I am not sure it was mentioned but to buy a new washer and maybe even a drain plug for peace of mind.
Jeff
Old 08-20-2009, 11:08 PM   #18
Drives: 2005 E55
Quote:
i havent had any issues since my transmission service (3 months ago). car shifts smoothly and i am getting better MPG than before (avg 16.5 - 17 city). not a huge improvement, but i didnt buy the car for being a fuel miser anyway.
as for the 7 quarts mentioned earlier, was the torque converter drained as well? i know earlier gerneration MBs have a drain plug for the torque converter. not sure if ours do as well...just a thought.
FYI - Auto Trans takes 8.0 US qts...page 469 of the good book
Old 08-28-2009, 03:14 PM   #19
Drives: 03 E55
Where are the two drain plugs i can only find one?
c43amgedmonton1 is offline   Reply With Quote
Old 08-28-2009, 04:20 PM   #20
ZGlide's Avatar
Drives: 2005 E55
Does the differential need to have its fluid changed too?
ZGlide is online now   Reply With Quote
Old 08-28-2009, 04:28 PM   #21
kjlindgr's Avatar
Drives: FD3S, E55 AMG, DMax
Quote:
The second one is in the front of the oil pan.
kjlindgr is offline   Reply With Quote
Old 08-28-2009, 04:35 PM   #22
kjlindgr's Avatar
Found this DIY article on the interweb for changing the trans fluid. It indicates aforementioned torque converter drain plug too. Keep in mind that this is a generic 722.6 trans with no mention of torque converter model.
http://www.peachparts.com/Wikka/Trans7226Fluid
Old 08-28-2009, 05:00 PM   #23
Drives: 03 E55
Quote:
Thanks i found it just had to remove another shroud.
Old 08-28-2009, 05:02 PM   #24
kjlindgr's Avatar
Yup, I remember that now too. You'll be surprised at how much oil gets left behind in the front of the sump.
Old 08-29-2009, 11:20 PM   #25
Drives: 2005 E55 AMG
Do it yourself. Whatever you do don't take it to jiffy lube, those guys are *** clueless.
GRAFH is offline   Reply With Quote
Tags
03, 1999, amg, benz, change, diy, e55, filter, mercedes, oil, removal, tool, trans, w211, weight
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
