| Home | Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Vendor Directory |
| W211 AMG Discuss the W211 AMG's such as the E55 and the E63 |
| Welcome to MBWorld.org! |
Welcome to MBWorld, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today! |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | |||
Drives: SL55, RX7, RX400h
IAT's at idle help
#2 |
bleed your IC system..
there is a write up.. how to do it.. its very easy. all cars IAT's goes up when idling.. there is simply not enough air to cool it down. bubbles in the system would cause the IAT to jump higher.
__________________
2002 C32 AMG -RennTech Springs -FM HE by Code3 Performance -SC Clutch Pulley by Code3 Performance + Intake -ECU tuning -18" C55 Wheels 2003 E55 AMG (Stage 1) -ASP Pulley -LET ECU Flash (OBD2) -FM HE by Code3 Performance -19" AMG CLS55 wheels |
#3 |
Drives: 2003 W211 E55
right on TopGun32
__________________
"Lieber Nurburgring als Ehering" |
#4 |
What do your IAT's peak at while idling for a long time?
The only time it hurts me is at the track. In the real world I don't sit at idle long enough for the IAT's to get out of control. My system is fully bled. I have done it more than few times now. Cheers
#5 |
i get this too in my car.
when the car is sitting in the staging lanes, no cool air (or in our case, hot air) passed across the heat exchanger. an increase in air volume across the heat exchanger is the reason why, as you pointed out, the IATs drop when you are driving back to the staging lanes (i, again, get my best results as well when slowly driving back to cool it down). IATs go up when the car is off b/c the intercooler system isn't actively cooling and all the heat of the engine is being released without being countered by the intercooler system. fan comes on at certain engine coolant temps along with the i/c pump. YES, you CAN run the i/c pump all the time and the fan on all the time. Hooleyboy ran the pump all the time....but as he was sitting in the staging lanes, his battery died from running it with his car off to keep the temps down. also, this will dramatically decrease the lifespan of the stock Bosch (and piece of crap) i/c pump and fan life as well. best bet is to upgrade the heat exchanger if you havent and split the coolant system into two separate circuits.
__________________
| 02 C32 AMG | SL55 Intake w/K&Ns | LET 185 Pulley | LET Tune | LET Heat Exchanger | Eurocharged Headers | Res Delete | NGK IX Iridiums | Magnecor KV85s | NW Pulley Saver | NW ISO Kit | Valentine1 | DashDyno SPD | CF Trunk Lip | Waiting Install: NW oil catch can Next: secondary cat delete, retune, coolant reservoir, intake/tb project, hooley button
#6 | |
Quote:
Before on a 85F degree day..it would hit 130+ after about 8 mins. This was before a proper split of the coolant lines and system not fully bled correctly. Just bigger HE and CM30 pump
__________________
#7 |
Drives: 2003 CL55
I was able to see a lot of IATS on cars with different mods this last weekend. So far, none of the 8-10 cars we checked IATS on could keep up with Shardul`s and my system..
Even cars with 172 pulley`s, heat exchangers were still higher. Even though we run 175 and 180mm.. Whithout going into all the different mods / cooling and other factors; to have a good system , it takes a few big things and all the samll things.. 1) Aux H/E ,high flow pump (we use Mezarie pumps) 2) Pump runs when key is on ( a must for colder weather low IAT goals or track). Do not need to run all the time but just cycle on and off every 10 minutes or so. 3) Split system on E-class (mine is not split but different) 4) 160 T stat The above simple cooling mods neted about 20 deg. lower IAT`s on average over cars with just larger H/E or added H/E.. The big catch, is that it can be 30-40 deg. cooler on the start of a run from idle!!!! That is huge for 60 ft Tq/power..
__________________
CL55, 1/4 mile time 11.61@120.26mph,1.75 sixty(12/5/08). ASP 180mm pulley, LET tune, 82mm TB, CF airbox, Aux.Garrett H/E, Meziere 20 gpm I/C pump, filters, Nitto Invos 275/40/18 rear (street tires), Wiseco Forged pistons/Nikasil coated bore. New ET`s coming soon! |
| Tags |
| amg, bleeding, e55, ic, idle, power, system, w211 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
