| Home | Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Vendor Directory |
| W211 AMG Discuss the W211 AMG's such as the E55 and the E63 |
| Welcome to MBWorld.org! |
Welcome to MBWorld, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today! |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | |||
Drives: 03 e55
undertray removal
#2 |
Drives: E55 AMG
I have had mine off for some time now and I cant really see a difference.
__________________
#3 |
Drives: 2006 E55
Doesn't that play a huge part in aerodynamics?
__________________
-Rear Cat Delete -Res. Delete -172mm LET Pulley -Eurocharged Heat Exchanger -Eurocharged Custom Tune -CM90 Johnson Pump - -10 thermostat mod -S55 Driver's Side intake tube -K&N's -5% Tint 35% windshield -Mandrus Millenium Wheels -Nitto 555R's 285/35/18 -Front and Rear EBC Yellow Stuff Pads "It's more like a Hammer, a bit clumsy, but it will still kill you." |
#4 |
Drives: 2004 E55 , 2009 E350 , 2004 Acura Tsx
The only problem with removing the tray is that it is designed to direct the airflow underneath the car and by removing that you will alter the airflow.
__________________
The Fastest Stock Powered E55 on DR's 121.18 in the USA The Quickest Stock Powered E55 on DR's on the West Coast 11.91 (for now, go get it Max) |
#5 |
Drives: shrimp boat
seriouly, how many time do you drive fast enough for "aerodynamics" to come in and affect your driving. I take mine off during the summer and put them back in the winter. I do not drive my car in the winter, but on the really nice winter day I may take the E out. On the side note, it help a lot when you work on your car if you do not have the under trays. I constantly drop my tools, nuts, bolts,.....so it really help not having the trays there.
#6 |
Drives: 2003 W211 E55
I have cut an opening in the first under tray below the heat exchanger. I don't know if it helps. The reason I did this is because I saw the undertray of a S65 and it had openings on the tray under the heat exchanger.
__________________
"Lieber Nurburgring als Ehering" |
#7 |
Drives: 2006 E55 Designo 1991 190E 2.3 2000 BMW 740i 1987 PORSHCE 928S4
I keep it off in the summer and put it on for the winter. I've been told it keeps the heat off your engine during the summer. I also belive it helps with aero dynamic. I'm sure MB did not put this cover for show, it has some added value.
#8 |
Drives: 03 e55
I figured the heat will excavate rather quickly when the vehicle is in motion. Even sitting idling it should help somewhat.
Spotting a leaking oil drain plug will also be very simple since that's what I'm dealing with right now. Anyone ever use teflon tape on the drain plugs?
#9 | |
Drives: 2006 E55
Quote:
See Thread "TOP SPEED"
__________________
#10 |
Drives: 2008 e63 amg
it actually cut my 1/4 mile times 3 tenths and picked up 2mph !!!!!!
LOL JK
__________________
#11 |
I would leave them alone... gets your engine dirty quicker and more water exposure. Specially if you live in desert areas or in windy locations.
Instead, remove the vent plastic cover on your hood and remove the sound pading on your hood.. I would only remove maybe during 1/4 track times.. where top speed is not a factor.
__________________
2002 C32 AMG -SC Clutch Pulley by Code3 Performance + Intake -ECU tuning and FM H/E -18" C55 Wheels 2003 E55 AMG (Stage 1) -ASP Pulley -LET ECU Flash (OBD2) -FM H/E -19" AMG CLS55 wheels 2008 Toyota Land Cruiser 4x4 (200 Series) -Stock |
#12 |
Drives: 03 E55, 93 Maxima SE
Enjoy having road debris smacking your 3 oil pans much? Not to mention the sensors and boots hiding down there. Leave it on.
Oh and the engine doesnt generate that much heat when you're standing still at idle, thats why its called idle, and why the fan turns on and off instead of running constantly.
__________________
#13 |
HOT air rises it doesn't escape fromt he bottom, this will not help get heat out of the car very much. It will hurt the Aerodynamics more.
#14 |
Drives: 2004 E55 AMG
The middle undertray contains ducts that route cold air to the alternator and something else on the other side of the engine. I leave mine on all the time, except when I'm changing the oil, which I just did about 2 hours ago. It takes all of 5 minutes to remove them, and I can't think of any benefit to leaving them off.
#15 | |
Quote:
__________________
| Tags |
| apr, undertray |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
