70 C / 160 F thermostat
Old May 13, 2006 | 07:08 PM
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Hi Folks:
I've been working on a 70c / 160 f replacement thermostat . So far it will fit a C-55 with a M-113 engine , The factory piece is 87 c / 189 f
Opinions , is it needed? Thanks ___PTE___
Old May 14, 2006 | 12:35 PM
Eurocharged Rick's Avatar
SPONSOR
i am wondering if it will trigger a check engine light? i would like to do this as well for the C32, but don't know if it will work without the computer freaking out because it never gets to that temperature anymore...
Old May 14, 2006 | 03:04 PM
PTE's Avatar
PTE
70 C / 160F thermostat
Look at all the post in E-55
https://mbworld.org/forums/members/25327-rflow306.html
Take Care Patrick T. Eves
Old May 15, 2006 | 08:18 AM
SPONSOR
do you have a different link? that just takes me to a member profile page...
Old May 15, 2006 | 08:34 AM
PTE's Avatar
PTE
thermostat
Quote:
Originally Posted by GTA23109a
Sounds great, but there are a couple pitfalls to watch out for.
First, it's going to suck in winter time as the car will have a hard time maintaining temperature. Been-there, done-that with other low-temp thermostat applications.
Second, the ECU calibration needs to be adjusted so the car doesn't get stuck in "cold-start" mode (for lack of a better description) and run rich as heck thinking it still needs to warm up.
If you can overcome these obstacles (mainly the second one) it could prove a very worthwhile, and cost-effective mod.
Quote from rfow 306 Below
PTE made one for me so I have been able to data log and get some feed back. The car idles at about 167-173 with the ac on and 188 to 192 ac off.
When cruising ac on or off, the temp drops to 165. According to my data logger cold start mode turns off at about 130-140 degrees. The o2 sensor voltage and fuel trim changes around there and looks identical to factory thermostat. Big thumbs up from me so far.
Old May 15, 2006 | 10:01 AM
SPONSOR
so what are you doing to get it to work? are you just drilling a stock thermostat?
Old May 15, 2006 | 10:49 AM
PTE's Avatar
PTE
Thermostat
Don't I wish it was that easly. It is a different return spring . Different vernathern center & valve. Plus some machining to get it all to fit. I do install a air bleed hole in the alum housing.
Old May 15, 2006 | 10:54 AM
SPONSOR
so will it fit the C32? what does it cost to put one together?
Old May 15, 2006 | 12:20 PM
Zeppelin's Avatar
C32
So what were the stock numbers? And are the stock numbers bad? How many horsepower do you expect from this, if any. And if none what is the point.
Old May 15, 2006 | 12:49 PM
PTE's Avatar
PTE
thermostat
The stock OEM is 87 C / 189 , the engine runs about 205 F . In traffic it really gets sluggish on a hot day here in Florida. H/P gain on cold or mild day not much , but on a hot day, you have enough reserve , that the motor runs more consentant, from stop light to stop light.
No big hp claims
Old May 15, 2006 | 12:57 PM
SPONSOR
the point is not to gain HP, it is consistency with the HP you have....your car runs different on a hot or cold day, this helps to bring more consistency to the performance of your car, especially for someone like me that lives in the humid south....
Old May 15, 2006 | 01:02 PM
SPONSOR
so will it work on a C32? what will it cost?
Old May 15, 2006 | 01:20 PM
PTE's Avatar
PTE
thermostat
Thanks PTE. Part number for a E-55 Compressor thermostat assy 113-203-02-75 $78.90
Part Number for a Clk -C 5.5 N/A
thermostat assy 112-203-02-75 $25.00
The only difference I can measure is the addition. bend & lenght in the neck to clear the compressor belt and $54.00?? . For the compressor one. left in the picture
Attached Thumbnails 70 C / 160 F thermostat-dsc00106.jpe   70 C / 160 F thermostat-dsc00107.jpe
Old May 15, 2006 | 04:24 PM
Zeppelin's Avatar
C32
No big hp claims
Just seems strange that a slight drop in water temp would affect the IAT temps that the ECU uses to reduce timing. Most of the lower temp stats I have run in cars do very little if anything. Once the car is up to temp the termostat is always open so it does not matter whether it is a 165 degree or a 195 degree stat they are both open and the temp on the gauge reads the same. I guess I have never had the problems that you have. I have run in 107 degree weather at a roadcourse for 20 strainght minutes at full throttle and never had the car overheat or lose power.
Old Oct 23, 2006 | 12:52 PM
SPONSOR
going to bring this back from the grave...PTE, did you ever figure out what it will take to get it to work on the C32? i want one, need one, just let me know what needs to happen to get this on my car...thanks
Old Oct 23, 2006 | 01:29 PM
PTE's Avatar
PTE
Back From the Grave??
Well this is what Happened. It took 6 weeks to get one for a C-32 , from the other side of the BLACK FOREST, By Stuttgart?? Germany. I finally Got it. Modded it . Sent it out . Wrote the Guy about 3 weeks , , He has decided to wait . Cold weather has set in ,In North Georga. I really didn't want put many out there. Without testing. I do not have excess to a C/SLK -32 . for testing. So I ordered another one ,3 weeks ago. I would rather know that it works , than disappoint a bunch of you.
Old Oct 23, 2006 | 02:24 PM
pshek's Avatar
2003 C-Class Sportcoupe
PTE,
Would you be able to use a thermostat from a C320 and modify that one for my C32 motor? I have my old C320 motor sitting in the shop, and the thermostat housing looks the same. It rarely gets very cold in California...
Old Oct 23, 2006 | 03:42 PM
SPONSOR
please let me be the guinea pig...it is always hot here in houston, just let me know what it costs when you get it modified and i will paypal you the money, i want this asap...thanks
Old Oct 23, 2006 | 05:37 PM
PTE's Avatar
PTE
160* thermostat
I'll order 2 more tomorrow , lets see what the Black Forest brings us??
Old Oct 24, 2006 | 12:19 AM
SPONSOR
awesome! thanks...
Old Oct 28, 2006 | 11:34 PM
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
Hi Folks:
I may want to try this for my Supercharged C55. PM me with the price and availablility.
Old Sep 20, 2007 | 09:30 AM
Haywood's Avatar
2005 Crossfire SRT-6
Guys, did you ever find a lower t-stat for the C32? I would be interested to put one in my Crossfire. Thanks.
Old Sep 20, 2007 | 09:39 AM
430's Avatar
430
SLK32
I have one installed on my SLK32. It is a great addition. Contact PTE about the thermostat.
