*** VR530 for AMG 63s ***
Many of you have followed our development of power parts for M156 engine in the past several months.
https://mbworld.org/forums/w211-amg/202131-amg-63-r-d-1-a.html
Here are the first fruits of our effort.
VR530, as the name implies, brings 63s to 530HP/485TQ.
To assist us in testing the components we were graciously lended a beatiful, white CLS63 by local MBworld member - John.
First we established a baseline. CLS had Powerchip software and charcoal filters were removed. Powerchip flashed the car back to stock and we reinstalled stock filters.
On M156 power steering pulley is made out of plastic and is very close to power steering fluid reservoir. No gains to be had. Alternator and water pump, on other hand, are heavy, cast iron pieces with room to play. Using T6061 billet aluminum and increasing pulleys sizes by roughly 10% we cut stock pulleys weight by half.
UD pulleys were the first to be installed and dynoed. I was not expecting much gains, but I was pleasantly surprised. Although there was only a small 3HP peak gain, HP under the curve has come up, which helps acceleration.
Since it is very easy to swap out filters on 63s, we went ahead and installed our new HiFlow Air Filters and removed stock charcoal filters. The gains were impressive as 63 was being suffocated by the stock filters combination.
To help alleviate this problem, I have produced a set of phenolic spacers that insulate intake manifold from the cylinder heads and prevent heat transfer from the heads. As the result there is 15-25F reduction in IAT and a significantly more consistent car.
Phenolic Heat Spacers (PHC) come with two sets of intake gaskets and new manifold bolts.
Now, however, since we did lower IATs with Phenolic Heat Spacers, true IAT will be a lot closer to ambient. To relocate IAT sensor upfront we simply left original sensor in it's place, spliced an extension harness with water proof connectors and added another IAT sensor now mounted up front by the driver side foglamp.
On the dyno, 63 loved it. IAT was the same as ambient and added 3 degrees of timing pushed total gains to 24HP.
VR530
1. Underdrive Pulleys Kit - $239
2. HiFLow Air Filters - $179
3. Phenolic Heat Spacers - $289
4. Intake Air Temperature Sensor with relocating harness - $129
Total - $836, Package Savings of $87
$749
$999 Installed.
Great job. Now I need to get these parts for my car.
I already have air filters. How much for rest of parts?(do you have package deals?) How long will it take to install them? Are these parts will void factory warranty? Thanks for making parts for 63 engine
Keep up the Great work Vadim!
I'll see you in a few weeks. Can I reserve a parking stall?
Best,
RoydRage
The install shouldn't take long at all, based on the list of stuff. I'd assume 2 - 3 hours, but dunno.
Warranty is a trickier topic than that. Keep in mind that each component on the car has a specification that it must meet. In this case, your pulleys will not weigh as much as they are spec'd to (which is actually the object of the mod). So, if an out of spec component (some mods) is SHOWN to have attributed to the demise of any component on your car, then that component will no longer have a warranty.
As always, I'd have a good relationship with my dealer or go to a mod friendly dealership. SoCal is pretty mod friendly in general.
Did Rick notice any gains with his RT Headers? i'd assume similar, if they are shorties.
As a matter of fact, I'm going to see my SA tomorrow to drop off some nice premium cigars to show my appreciation for my recent warranty repairs to my car. He takes care of me so showing that I'm not a total dick can only help in any future repairs that may fall into the gray area of warranty coverage.
It's no guarantee but it won't hurt me trying to grease the wheel a bit...
Anyone wishing to purchase this package can paypal the funds to sales@vrptuning.com.
If you wish to schedule an appointment to have the parts installed, either email myself (victor@vrptuning.com) or Vadim (vadim@vrptuning.com) and we'll get you booked in..
Now that we have all the small stuff out of the way, the more interesting 63 stuff will be coming..
Thanks everyone!
Going under the knife during the transformation will be uncomfortable for my SL55 at first. She will need support from the SL65 Monster to ensure all is well.
It takes an SL Monster to know Another....
