Sponsored by: CARiD
self-illuminated door sills
Old May 30, 2014 | 02:39 PM
seals9121's Avatar
Cayman S 987.2 / C63 507
NO , not an ad.
Just had the finished sample from the factory, Friend provide me with these set FOR FREE!!! YO ! can't wait to share.
it's just final test process.
same material, same finish, OEM fitment. no wiring or modification needed.
no plug just play.
battery powered LED last for 3 years after that just change battery easy ...painless...
Tell me what you guys think about it.
Attached Thumbnails self-illuminated door sills-smallsize.jpg   self-illuminated door sills-smallsizeoff.jpg
Old May 30, 2014 | 08:23 PM
alanme123's Avatar
2012 E350
Are these aftermarket or OEM sills?
Looks good btw!
Old May 30, 2014 | 09:55 PM
PeterUbers's Avatar
Looks less bright than oem illuminated sills... How do yours know if door open or closed
Old May 30, 2014 | 10:24 PM
seals9121's Avatar
a little bit darken due to the voltage. But it's bright enough still. I'm very please with the final result.
it came with a small magnet attach to the edge of the door. when you open the door it will trigger. after 5 minutes it will turn off even if the door is not close.
Old Jun 1, 2014 | 03:55 PM
fleebugs's Avatar
Would you mind sharing where you got them from? And do they have similar items for the 2014 coupes (C207)?
Thanks!
Old Jun 1, 2014 | 07:17 PM
screw991le's Avatar
2010 E63 AMG
Cool
Old Jun 3, 2014 | 03:55 PM
seals9121's Avatar
Thanks!
I'm new to the forum I don't know if the forum allow me to just post the link here. I will pm you the link instead
Old Jun 5, 2014 | 05:52 PM
fleebugs's Avatar
Hi seals9121, yes please PM me the link. Appreciated!
Old Jun 6, 2014 | 12:53 AM
Arrie's Avatar
2010 E550, 273 Engine: 2012 S550, 278 Engine
There are some sticky links here just for the purpose of sell some parts. Against that it should not be a problem to post the link so please do so. If you still cannot please PM me too.
Old Jun 6, 2014 | 01:43 AM
seals9121's Avatar
eBay item number:121352695755
I only have few sample and need to test around now before I really help to sell the products. so far it works great.
Old Jun 6, 2014 | 03:24 AM
alanme123's Avatar
2012 E350
If this works as good as you say it does, then I regret in getting my other aftermarket sills.. had to spend money to get it wired because I didn't know how
Old Jun 6, 2014 | 08:05 AM
hyperion667's Avatar
2012 CLS63
a bit redundant eh?
Old Jul 14, 2014 | 07:52 AM
NiW's Avatar
NiW
E63 AMG
Any of these with AMG logo?
Old Jul 14, 2014 | 10:59 AM
dbldpr's Avatar
Veteran: Navy
I noticed that the lighted ones are wider than the original ones. Did that cause any type of problem since you are right at the edge of the sill? Also when you have to change the battery will the sill plate bind when you need to remove it? Will they be damaged from removing to change the battery?
